Question about Intel S5000PSL DP LGA771 MAX-32GB CPNT45NM DDR2 SATAX6 GBE2 45NM SATA-R Motherboard
Nedd motherboard manula or Front Control Panel connector diagram in order to connect power switch, pwr led, etc. for Intel S5000PSL motherboard
  • 1 more comment
  • pc2020 May 11, 2010
    I have already seen this reference. It tells you the location of the Front Control Panel Connector but does not provide a legend or diagram that shows you which connections goes where.
    Please locate a diagram that shows how to connect the PWR LED, PWR SW, HDD LED, & RESET SW, etc. to ht efront control panel header on the motherboard.
    Than you,
    Patrick
    I already have that document via the Internet. It shows the location of the Front Control Panel Connection on the motherboard, but it does not show where to connect the PWR LED, PWR SWITCH, HDD LED, & RESET SW, etc. to the connector. Please assist.
    Thank you,
    Patrick
    thanks, could not find 2nd document.
    Brigadier General:
  • 7,191 Answers
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on May 11, 2010
  • AliTech110
    AliTech110 May 11, 2010
    You can also view the front panel connections by downloading the Technical Product Specifications by clicking this link. The front panel connections are given on page 59 of this document.
    Thanks once again.
Power switch
You maybe able to download a motherboard manual from this WEB site and identify the connectors for the front panel.
http://devxstudis.org/int/intel+d865gkd+motherboard+manual.html
Jan 03, 2013 | IBM Computers & Internet
Gateway 500GR Mother board Connector S Wiring
You are correct so far.
This is a perfect example of using deductive reasoning based on intelligent thought.
'Armed' with that I can see you will go far in life.
Gateway Support > Gateway 500GR Desktop PC > Main Support page,
http://support.gateway.com/s/PC/R/3724/3724nv.shtml
Click on Components in the list.
Scroll down. Under the bold black heading - Motherboards - click on
102007 - Intel (Augsburg) No CPU Motherboard R0
Click on Specifications.
Chipset: Intel 915G Chipset
http://www.ascendtech.us/gateway-augsburg-intel-915g-motherboard_i_mb4gwaugsburg.aspx
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
In the photo the Front Panel header is marked by the letter S.
Let's go to Intel Support, and download the Product Guide for an Intel D915GAV motherboard,
http://www.intel.com/support/motherboards/desktop/sb/CS-012048.htm
Click on the blue -
Intel Desktop Board D915GAV Product Guide - (English) PDF
Scroll your mouse cursor to the bottom/middle of the page, to bring the 'ghosted out' navigation guide into view.
Click on the Adobe PDF icon to the far right.
(When you hover your mouse cursor over it, "Show Adobe Reader toolbar" is briefly shown)
Different design motherboard in the layout of certain headers, and connectors, but same Ol' Front Panel header pinout, Intel uses for 10 pin Front Panel header's.
Whether it is an Intel O.E.M. motherboard, or one they made for a pre-built computer manufacturer.
Front Panel header for Gateway 500GR, is next to the bottom edge of the motherboard, and all the way towards the right.
5 pins across the Top row, 4 pins across the bottom row.
Pins on the Top row are numbered ODD.
Pins on the Bottom row are numbered EVEN.
TOP row; Starting on the RIGHT side going towards the Left;
Pins 1, 3, 5, 7, and 9.
BOTTOM row; Starting on the Right side going towards the Left;
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode)
Pin 1 is for the Positive ( + ) wire. If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. No Connection. Pin reserved for the factory.
(5 Volts DC)
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) Again, there is No pin 10.
Regards,
joecoolvette
Aug 21, 2012 | Gateway Computers & Internet
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
I am having a problem connecting my power supply to my motherboard i can plug in everything except the one connectors that require a connection to a part called PWR-LED
Take a look at the picture below:
If I am right, the Front Panel connector should look similar as shown above (it's an assumption since you didn't mention the Motherboard's name and version). Look at the front panel connector on the motherboard carefully, you'll see similar name/indicator as you are seeing on the above picture like Pled, Hdled etc... I hope the front panel connector has 9 pins, and remember, one should be left without any connection.
Simply you have to connect the two female Pwr-Led to the Pled+ and Pled-, and Power to Pwr and Gnd, the same sequence with hard disk led and Reset switch as Hdled+ and Hdled- and Gnd and Reset respectively.
If the front panel connectors on your motherboard has less than 9 pins, then I am sorry, I have no idea about it and I am afraid if it exists or not.
If you still have the problem, let me know.
Good luck.
Aug 01, 2010 | Computers & Internet
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
Optimized intel server board 2000 Need Diagram for
On most motherboards the front panel connections are printed in the connectors on the motherboard. When you connect the various LED indicators and when you power up and they do not light up then just switch the connectors around, because they are are polarized.
You can go to the motherboard WEB site to download a manual, the manufacturer and model number is printed on the motherboard.
Jun 28, 2009 | Intel Computers & Internet
Can't Fix FRONT PANEL HEADER on my Motherboard
Here is a link to your motherboard manual:
D845PEBT2 Manual
Go to Page 33 for the Front Panel connections...with pictures. :-)
Thanks for using Fixya.
Jun 12, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
Hi u can easily solve this problem.
open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
mukesh_ibm@yahoo.com
May 12, 2009 | ASUS Computers & Internet
Front panel connectors
Pin Signal In/Out Description Pin Signal In/Out Description 1 HD_PWR Out Hard disk LED pull-up (330 ohm) to +5 V 2 HDR_BLNK_GRN Out Front panel green LED 3 HAD# Out Hard disk active LED 4 HDR_BLNK_YEL Out Front panel yellow LED 5 Gound Ground 6 FPBUT_IN In Power switch 7 FP_RESET# In Reset switch 8 Ground Ground 9 +5 V Out Reserved 10 N/C 11 Reserved In Reserved 12 Ground Ground 13 Ground Ground 14 (pin removed) Not connected 15 Reserved Out Reserved 16 +5 V Out Power
Hope this helps, , if so please rate accordingly.
Thanks,
David
Mar 12, 2009 | Intel Motherboard
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Jan 18, 2009 | E-Machines eMachines T3830 PC Desktop
Intel S5000PSL DP LGA771 MAX-32GB CPNT45NM DDR2 SATAX6 GBE2 45NM SATA-R Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
