Hoover oph714d washing machine code e03 and e16
Hi, my hoover oph714d washing machine come up with error code e03 with 37 mins left to wash. if you switch if off then on again it comes up e16. what do these codes mean, and can it be fixed
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
BIKER T
  • 909 Answers
SOURCE: Hoover oph714d - error code e16. What does it mean
Where in the program is this happening?
Posted on Sep 20, 2009
richroth
  • 9472 Answers
SOURCE: My Hoover VisionHD washing machine
E16 is for an "open circuit" on the heater.
Posted on Jan 03, 2011
FitzOriginal
  • 842 Answers
SOURCE: hoover washing machine Mod OPH 714D Error E16 in
After far more research than I usually have to do, It seems that E16 means "O/C Heater"
Which means that the heating element is open curcuit. Which menas......
Either the heater element has a wire off at the back, or more likely the heater element is burned out.
They are easy to replace. Pull the machine out and remove the rear inspection plate at the bottom of the body (I think this machine has one!, sorry if it doesn't).
At the bottom of the drum, you will see a atainless steel cover, about 4 inches limg and a third of an inch wide, with rounded ends. There will be 2 spade connectors with wires in them (1 either end of the plate) and a 10mm nut in the centre. The nut tightens up a squeeze plate inside that crushes up a rubber seal to hold it in place. Undo the nut fully (you may have to push the little stud bolt that is now exposed in a little to free it off) The element should now withdraw if you grab hold of the spade connectors and tug a little to break the seal before you withdraw it.
Replacement should be the reverse of removal.
Google "Hoover washing machine heating element" to find yourself one on line, or ho to your local Hoover parts stockist
Posted on Jun 30, 2011
Testimonial: "thanks for your help great, having more problems now so it has to go!"
  • 6277 Answers
SOURCE: my hoover dyn 8164d washing
Hoover's 'e03' states 'drain timeout'- probably a blocked filter or even jammed drain motor/pump.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 07, 2011
Hoover washing machine error code16 has come on
Hi!
Baically, Hoover washing machine error code E16 means that there are problems with the insulation of the heater. this may lead to the shutdown of the circuit breaker and other random errors, but this is difficult to prove without replacing the heating element.
Apr 27, 2017 | Hoover Washing Machines
I have a hoover silver pulse inverter e03 came up on the display then changed to e16, what do I need to do?
Hoover dyn8144 and related machines
Error code 03 followed sometimes by Error code 16
Check the usual drain pump and resistance of heating element
On my machine I've discovered that on the motor if the brushes are not bedded onto the commutator it will cause the above codes to display and stop the machine.
The problem is not related to the drain pump or heating element so the codes displayed are not correct. If the brushes are not bedded to the commutator the motor cannot get to spin speed but will happily wash away. Watch the machine during a quick wash to ensure it does actually spin
Jul 10, 2015 | Hoover Washing Machines
What does e16 mean please?
An E16 error code means there is a heater insulation problem which could cause the tripping of your fuse box and other random cycle errors, but it's hard to prove without the replacement of your heater.
For more information on other error codes , watch this video .
http://www.espares.co.uk/advice/0/2531/how-to-understand-hoover-and-candy-washing-machine-error-codes
May 15, 2015 | Hoover Washing Machines
Hoover dyn8164d had code E03 then E16 now E08
Hi.
These specific codes indicate the following:
E08 means that the Motor jammed or tacho fault
E16 means that the heating element is shorted or that there is a short in the circuit containing the element.
E03 This error code indicates that the water is not draining quickly enough.
Before doing anything it is worth removing the washing machine mains plug from the power outlet and leaving the machine disconnected for at least ten minutes. This will reset the codes if no faults still exist. Then plug the machine back in and select required wash routine. If all is well, well done you just needed to reset the machine. If a fault code is still showing then it would indicate there is still a problem in the area indicated.
You said you had checked that the filter was ok, it is also worth checking that your drainage hose is not blocked or
kinked.
Jan 11, 2014 | Washing Machines
Eo3 error message hoover washing machine
Unplug machine for 2 hours to reset the board electronics and re-plugin to load fresh computer code onto board.
Oct 15, 2013 | Hoover Washing Machines
Hoover optima oph714ds error code e14
hoover optima oph 7d14 working ok but at end of wash cycle error e14 comes up what does this mean
Dec 24, 2010 | Washing Machines
Error code E03 on washing machine
Sep 28, 2009 | Washing Machines
Washing Machines Logo
659 people viewed this question
Top Washing Machines Experts
