Question about Eureka Atlantis 2591A Upright Steam Vacuum
Smells hot My Eureka Atlantis has been used for only my home cleaning use and today i went to use it and it is NOT suctioning like it should and it smells very hot and need assistance.
    President:
  • 1,673 Answers
Sounds like you may have a bad motor. It is probably trying to work, that is why the suction is low and it gets warm. It will have to be replaced.
Posted on Mar 30, 2008
My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
GoVacuum.com
Apr 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
No suction or spray - Eureka Atlantis Steam Cleaner
I got the machine working. I think because it hadn't been used for awhile that the seals were dried out. I wet them and let it sit for awhile and then I could push the containers all the way in and seated them properly. Then it started working no problem and I got to clean my carpets.
Oct 05, 2009 | Eureka Atlantis 2591A Upright Steam Vacuum
Eureka 2961 BVZ no suction, burning smell
I have the same vacuum. The burning smell is letting you know that your belt is either broken or about to break. I have had mine for a year and have had to replace the belt 5 times. Now I have to replace the brush roller 'cause it broke under normal use. My next vacuum will be a Dyson Ball.
Jul 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka Atlantis 2590 Deep Steam Extractor will not spray
I cannot find a shampoo canister for my Eureka 2590 Series extractor. They are not made anymore.
Jun 07, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Eureka Atlantis Stopped Working
I would contact eureka for warranty repair. sounds like it there is something wrong with the mechanis of the unit. could be that water is making its way into the motor pump housing and causing damage to the pump
Aug 09, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Eureka Atlantis Rug shampooer wont **** up the water, how can I fix it. Thanks Dennee
make sure that the two slide-tabs on the front of the machine are all the way down so that they can hold the front see-through cover down and create suction at the front. I did the same thing. you can tell when they get moved while cleaning because you will hear a muffled pop like something just got sucked into the vacuum. It is just the sound of suction being broken.
Jul 17, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka Atlantis 2591A Upright Steam Vacuum Logo
143 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
