Question about Toshiba Satellite Pro A200-EZ2204X Notebook
The screen is offset slightly on the right hand side, how do i get the whole screen back
  • 1,675 Answers
Hi you should be able to...right click anywhere on the desktop, ( not on an icon ) click properties, then go to settings and then adjust the resolution settings and that should sort it out for you...hope that helps please vote thanks
Posted on May 11, 2010
Sony kdl52xbr4 tv has double vision on right side of screen perfect picture on left side is this a timing control board issue?
Fault with its T'Con board itself. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 14, 2015 | Sony Televison & Video
Word"print" vanished on window window to large fix it??
Try pressing the box next to the CROSS on the window, top right hand side. This will allow you to resize the window.
It will also give you two bars one on the right hand side and one on the bottom to move around the whole page, in case the word print has slipped off the screen display.
Dec 10, 2014 | Gateway Computers & Internet
Should the right hand needle be slightly longer than the left after changed? The right hand needle hangs a bit longer than the left. Is this correct?
Yes, needles are usually offset on sergers, one will be lower than the other.
You can download a manual from here: http://www.jukihome.com/products/mo644d.html its a pdf icon on left of screen, page 11 covers needles and the right needle is lower. It also says to change the right needle first, then the left one and to use a JL x 2 needle in the left side for heavy weight fabric.
Don't know with the Juki but I know my Bernette prefers the serger needles as they have a scarf/groove in the front as well as the back, ELX705, otherwise they are the same length as the standard domestic needle 130/705H.
Also, never unscrew the needle screw too far out, just enough to get the needles out and in, as there is sometimes a ballbearing up in the housing between the two needles and if you wind out the screws too far, this may drop out.
May 23, 2011 | Juki MO-644D Mechanical Sewing Machine
When I sharpen my chain with the timber tuff electric sharpener the chain cuts on an angle what am I doing wrong??
I will wager if you place a protractor on the bar you will find the right and left links are at slightly different angles (one side gets more bite). It only takes a little difference. The usual suspect is the guide on your sharpener. Some grinders require an offset because the wheel is offset more to one side than the other.
I hope you found this helpful.
Lou
Jan 18, 2010 | Electric Chainsaw Sharpener
Touch screen controls offset by an inch
To Try To Test It,Go To Main Menu Then,Seting Then,Systum Settings Then Move Over 1 Then, Press Dionostics Then Touch Screen
Jul 11, 2009 | Magellan Maestro 4040 GPS Receiver
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
Offset picture
You need to change the Display menu for picture mode to 16:9
no wide fit or scan fit.
Jan 28, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Convergence problem with Toshiba TV 42H83
I am still working on it! Need a technician in Alacante Spain!
Jul 25, 2008 | Televison & Video
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
93 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
