Question about Panasonic Lumix DMC-TZ3 Digital Camera
Lens Error I was looking through the pictures and then turned the camera off then on. And then it just said lens error. But I didn't do anything. The lens won't come out and I need it to be fixed but I don't know what to do.
    Novelist:
  • 172 Answers
Two things:
1. Remove the battery and put in back in after about a minute waiting time. See if this works when camea is in the Record Mode.
2. If not, with camera on, grasp it firmly with one hand and strike it on its edge on the heel of your other hand. This sometimes frees a momentarily stuck lens. BTW, this will sometimes work for other problems like lens cover not fully opening and freezing(lockup) of camera. Do this with camera on. Won't hurt camera when done against a firm but pliable surface like the heel of your hand.
Posted on Apr 05, 2008
It keeps saying lens error
Here are some troubleshooting steps for the lens error problem. And here's a video summary of those steps:
Jan 13, 2013 | Canon PowerShot S3 IS Digital Camera
My Canon Powershot SD 980 IS has suddenly given me a lens error camera restart message. I have changed batteries, called Canon, used compressed air, try restarting with a/v cable etc. Whassup with that. It...
Hello and Welcome to FixYa!
Sir/Ma'am Lens error is because of several reasons and there are several solutions to fix up the Lens ErrorYou have tried One of the most common solution which Fix up the lens error like lens error is solved by removing the batteries and replacing it with a new set of fully charge ones, or Lens error may also solved by compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or Lens error also mostly solves by Insert the cameras Audio/Video (AV) cable, and turn the camera on.
You have tried all these but but problem is still there so problem is quite complicated, well i am suggesting you some more solution which may fix up the Lens Error:-
First of all if your camera allows you to work for minute then try finding and selecting the "factory reset" option to set your camera back to its original factory condition. On some Canon cameras, this requires holding the menu button down with the camera powered on for up to 10 seconds. However note that a lens error might sometimes override the reset option, and thus the option might not appear. So if you find the option then by resetting your camera to Factory Setting may fix the problem
If problem is still there then Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time, This may also solve the problem
Mostly Lens Error is also happens when Lens Barrel is out of position so Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots and it may fix the problem
If problem is still there then there are some other solution too which remove the lens error but all of then are technical and if you try to follow them you enter into the realm of potentially damaging your camera. There is definitely some risk in them, So i recommend that if your camera is still under warranty, before trying any of these, please please first contact your camera's maker or service provider. It will solve your problem quite easily.
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind or if your camera is out of warranty and you can try some risky solutions.
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 02, 2011 | Canon PowerShot A460 Digital Camera
Lens error; restart camera
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jun 15, 2010 | Canon PowerShot SD600 Digital Camera
When I turn my camera on a message says lens error 16 and shuts off, if i want to take a picture. If I put the camera in play mode to review pictures its says lens error 21 but lets me look at the...
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 10, 2009 | Sanyo VPC-E760 Digital Camera
Lens Error on L18
Jun 23, 2009 | Nikon COOLPIX L18 Digital Camera
ERROR 99
if you have a DSLR and your'e getting this "error 99" it may be associated with the particular lens youre using. try turning off the camera and removing the battery, the lens, and the memory card. let it sit for half an hour. reinsert the battery only and depress the shutter button as if you were to take a normal picture. if error 99 occurs again, then the camera needs servicing. if it error 99 doesn't occur at this point, turn the camera off and install the memory card. format the memory card while it's in the camera and press the shutter button as if youw ere to take a normal picture again. if you see error 99, then the problem probably lies with the memory card. if it doesn't occur, turn off the camera and install the lens. again, power on the camera and press the shutter as if you are taking a normal picture. if the error occurs, then it's with the lens. try to clean the lens including the connection points both on the camera and the lens. if the error code still occurs, try different lens to narrow it down to which particular lens is giving the issue. if it happends with all the lens, then the camera needs to be serviced.
Sep 16, 2008 | Canon Cameras
Blurry picture nikon s200
It doesn't say lens error? but it won't focus? it is probably the same as the other people who do have lens error displayed on the screen, the lens is broken is what the repair company told me about my s200 when i told me lens error
Jul 22, 2008 | Nikon COOLPIX S200 Digital Camera
Lens Error
i had the same problem with lens is blurry and lens error message comes up. My solution might sound sillys but it works. tapping on the side of the camera, put some force to it.(with hands only).
Jun 16, 2008 | Nikon COOLPIX S9 Digital Camera
Lens
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Jan 05, 2008 | Casio Exilim EX-Z120 Digital Camera
Pentax Optio 60 LENS
The same thing happened with my camera, I gave it to a freind for her husband to look at it. He said when turning on face the lens side down (to the ground) when turning off hold lens side up right (to the sky). this worked for mine. I don't know if he did anything else to it but when I zoomed I got lens error. I did what he said and it took several tries but it did work... please post if this helps you.
Dec 13, 2007 | Pentax Optio 60 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
134 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
