Question about LG WM-2277HW Front Load Washer
I have a LG washer/dryer 8/4kg WD1481RD when it goes to spin cycle it vibrates terrible and makes a noise.. please help
Nzero
  • 78 Answers
SOURCE: Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Posted on Sep 01, 2008
SOURCE: vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 13, 2008
Karthik316
  • 187 Answers
SOURCE: During the spin cycle the washer will vibrate and move around. Happens on large and small loads.
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion
Posted on Apr 14, 2009
kevinj650
  • 82 Answers
SOURCE: washer vibrates terribly loud on high speed spin
Either bad motor, motor bearing, tub bearing or idler pulley (also broken motor mount). Unplug unit. Spin tub by hand. Try and feel if spins freely. If direct drive unit (no belts). Most likely tub bearing or motor. Remove rear panel. Inspect for damage (broken mounting parts). Turn tub by hand. Look for malfunction.
Posted on Jul 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: vibration on second floor laundry
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
SHAKES and VIBRATES - LG Front-loader shakes and vibrates terribly during the spin cycle. It is pounding against the walls and the dryer thats next to it. Its also very loud and it used to be super quiet...
try putting a lighter load in the washer,or you put some foam or something like that at each side of the machine to stop it hitting against the other things next to it.also try adjusting the feet at the bottom of the machine to level it out.
Jan 31, 2013 | Washing Machines
Unit is level, yet vibrates/thumps terribly at the beginning of spin and other cycles. It has moved itself several inches already,and I have no clue what is wrong with it..
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 22, 2011 | LG WM2277H Front Load Washer
Terrible noise when washing/spin cycle. clothes are still clean but hte noise is VERYLOUD! Any idea of the cause?
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Dec 05, 2010 | Westinghouse Washing Machines
Washer stinks terribly and has become so loud you can hardly be in the room when it is on.
Check out this tip I wrote about the noise and vibration thatfront load washers can make..
heatman101
Sep 18, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Severe vibration during spin cycle
reduce the amount of cloth and make sure the cloth don't fix in one corner
Mar 23, 2009 | LG WM-2277HW Front Load Washer
Vibration during spin cycle
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
TERRIBLE NOISE ON SPIN CYCLE
That is normal, after a little while all washers make that horrible noise you should be able to put up with it
Hope this helps! - Josh
Feb 03, 2008 | Frigidaire GLWS1233A Top Load Washer
LG WM-2277HW Front Load Washer Logo
147 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
