Question about D-Link DES-1024D Express EtherNetwork 24-Port 10/100 Switch (S2299467)
I want the default ip address, domain name and password of "dlink des 1024d switch"
    Sniper:
  • 135 Answers
Hi,You can get your expected domain name also getting hosting at just $1.99 per year from this http://www.tucktail.com/ site ,visit here for more details.All the best.
Posted on May 17, 2010
  • 74 Answers
By default ip is 192.168.0.1
and username and password admin
Posted on May 11, 2010
How to reset settings of DGS-1024D
n that case you have to rest the router. There two ways to do so:
Method1:
There is a small button at the back of the router labbelled as reset. Its very narrow you need to press and hold it for about 10 - 20 sec using a needle or any sharp objet.
Method2: If you are not able to find the button. You can use a we-based portal to do so. Connect your computer to the router and enter the IP mentioned at the bootom of the router in your internet browser. User name and password will be provided at the bottom of the router somewhere next to the IP address. Once you log in you can reset the router from there.
default IP: 192.168.1.1
Aug 09, 2013 | D-Link DES-1024D Express EtherNetwork...
No console port on D-link DES 1024D switch....how to see the configurations of the switch?
please try here:
manual source:
ftp10.dlink.com%2Fpdfs%2Fproducts%2FDES-1024D%2FDES-1024D_ds.pdf&rct=j&q=D-link%20DES%201024D%20switch&ei=ovVUTtePJe-GsAL-jrW9Bw&usg=AFQjCNFCXB5yxOjc5WcpSoSUGKmCpiJGag&cad=rja
Description
With Plug-&-Play functionality, the D-Link DES-1024D Un-managed switch expands your network and automatically detects your network speeds and adjusts for peak performance.
http://www.dlink.com/products/?pid=75
Aug 24, 2011 | Computers & Internet
I have dlink switch model DES-1024D i need default IP address
The default IP address for most D-Link switches is 10.90.90.90
Jun 13, 2011 | D-Link DES-1024D Express EtherNetwork...
My D-Link DES-1024D can't assign ip addresses to client computer automatically anymore. how will i resolve it?
You switch does not provide DHCP services (assigning of IP Addresses). That is done by either your router or a server on your network.
Mar 23, 2011 | D-Link DES 1024D (DES-1024D) 24x10/100...
What is the default IP address of D-LINK DES-1024D 24-PORT 10/100 Ethernet switch and how can it be reset? its unmanaged version! mine is stuck on 169.254.180.130, while my routers has a 192.168.1.1. only...
This issue is more on a hardware. 169.254.XXX.XXX refers to an INVALID IP ADDRESS. Here's what you can try:
>release the ip address by running command prompt:
>>>>Click START>type CMD on the search bar>type IPCONFIG /RELEASE and hit ENTER
>>>>ip address will be set to 0.0.0.0
>renew the ip address: by typing IPCONFIG /RENEW and hit ENTER
>>>>it will generate new sets of ip addresses
However, if it still gives you 169.254.XXX.XXX you need to flush the DNS by typing IPCONFIG /FLUSHDNS and hit ENTER and it will immediately tell you that the DNS had been successfully flushed.
>Check your ip address by typing IPCONFIG and hit ENTER
That's the best I could do for the issue that you have.Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Feb 03, 2011 | D-Link DES-1024D Express EtherNetwork...
Switch D-Link DES-1024R + My problem is not gateways automatic
No It's not virus . It is issue of ip address in your computer. You can set ip address with 2 method static and DHCP. For DHCP you need to enable it in router. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on DHCP and enable so you can get ip from router.Enable "ip get automatic in network adapter tcp ip property. If you want to ser static ip in tcp ip then gateway ip set to router ip if your router ip is 192.168.1.1 then your computer ip is 192.168.1.3 subnetmask 255.255.255.0 and gateway as 192.168.1.1 Then you can access internet Let me know if you need further assistance. Thanks for using FixYa.
Jul 19, 2010 | D-Link DES 1024R Plus (DES-1024R+/5)...
What is the default ip address for dlink 3226?
The Switch's factory default IP address is 10.90.90.90
with a subnet mask of 255.0.0.0 and a default gateway of 0.0.0.0.
Often set up by rs232 connection
See
ftp://files.dlink.com.au/products/DES-3226S/QuickInstallGuide/Generic_QIG_for_Managed_Switches_v1.03.pdf
and
http://support.dlink.com.au/Default.asp
Apr 20, 2010 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Ho to reset dlink3226 switch
Have you got a manual for the D-Link switch?
You may find the info in the manual, if you have lost the manual you can download a manual from this WEB site - Use this link :-
http://safemanuals.com/annexe_Reference%20Guide_D-LINK_DES-3226-_E.htm
Sep 17, 2009 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Username and password forD-Link DES-1008D
hello, no user name or password for dlink hub. the only thing i can help you with is default IP address for your computer(server) which is
IP:192.168.0.1
subnet:255.255.255.0
Dec 20, 2008 | D-Link DES-1008D 8-Port Ethernet Switch...
D-Link DES-1024D Express EtherNetwork 24-Port 10/100 Switch (S2299467) Logo
918 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
