Question about Medion MD-1704 PC Desktop
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
  • 344 Answers
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
Posted on May 11, 2010
    Guru:
  • 1,705 Answers
You connect the Tv sound out to your sound card.
The sound card will either be onboard (the motherboard) or a separate PCI card .
You can find it by looking at the back of your pc and you should see 3 Micro Jack inputs Green, Pink and Blue. There may be more, these are the main ones.
Green - Line out to speakers.
Pink - Line in from Microphone.
Blue - Auxiliary line in.
I'd connect the tv card to the Blue input.
If your TV card only has a Phono connection you're going to need a cable with Phono on one end and Micro jack (3.5mm) on the other.
Colour Function Connector symbol Pink Analog microphone audio input. 3.5 mm TRS A microphone Light blue Analog line level audio input. 3.5 mm TRS An arrow going into a circle Lime green Analog line level audio output for the main stereo signal (front speakers or headphones). 3.5 mm TRS Arrow going out one side of a circle into a wave Brown/Dark Analog line level audio output for a special panning,'Right-to-left speaker'. 3.5 mm TRS Black Analog line level audio output for surround speakers, typically rear stereo. 3.5 mm TRS Orange Analog line level audio output for center channel speaker and subwoofer 3.5 mm TRS Gold/Grey Game port / MIDI 15 pin D Arrow going out both sides into waves
  • Medion Master
  • 12,061 Answers
You need an Dual RCA to PHONO 3.5mm, this plugs into the EXTERNAL INPUT on the rear of the PC's sound system jacks.
How do I connect good mans sound bar to tv
Simply connect a dual RCA phono to phono lead to the 'Line out' sockets on the TV and the 'aux in' sockets on the bar.
Apr 05, 2015 | Toshiba 40BV700B 40 INCH Full HD Black LCD...
I want to connect my LG sound plate 240 to my home stereo. What leads do I need
stereo jack or phono leads from your tv to your stereo assuming you have a phono red and white aux input on the stereo
Dec 12, 2014 | LG Audio Players & Recorders
I HAVE A MEDION AKOYA P6620 MD97760 NOTEBOOK WHICH I CONNECTED TO A LCD HD DIGITAL EXTERNAL TV WITH A HDMI CABLE AS PER THE INSTRUCTIONS IN THE MANUAL. I GET THE VIDEO PERFECTLY BUT THERE IS NO SOUND....
sound is not transfered through hdmi from a laptop you will need another lead for sound which is a 3.5mm jack to rca / phono the phono plugs in to the red and white sockets on your tv
Sep 23, 2010 | Medion MD-40954 Notebook
My tv has one sub output socket,but my active sub woofer has a red and white input sockets.what lead do i need to connect it up with?
Sounds like the output on the TV is a phono socket or a jack and the inputs on the sub woofer take banana plugs. You need (or should make up) a lead with a phono or jack plug one and and two banana plugs the other end. (phono plug/socket has two connections and banana plugs just one)
If you can provide the model numbers of the two bits of equipment I can check this for you.
Mar 08, 2010 | Audio Players & Recorders
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Connecting my HP Pavillion DV9500 laptop to my Samsung PS-42Q96HD
Sound more like your problem is with the connection to the TV. Make sure the connection at the TV is to an 'input' connector and not 'output'. Also, from the TV menu, if you can select the output the laptop is using make sure the sound is stereo an not 5.1 or 7.1 or something to that effect. All other connections seem to be in good shape. Good luck.
Feb 03, 2009 | Humminbird Computers & Internet
How to connect loptop pc to Hitachi 42 inch LCD
Sounds to me like an audio 3.5mm jack to L-R phono leads. The single jack connector would need to go into your pc's line-out port on the soundcard and the red and white phono connections on the other end go to either your television or home theatre system.
Mar 14, 2008 | Televison & Video
Not getting sorround sound from my tv
only the hd channels get great surround sound. if your tv has an optical audio out and your surround has the optical in input. then i suggest buying a fiber optic wire for the audio you'll hear a big differance. just hope that the audio stays in sync unlike my cheap *** koss system
Dec 10, 2007 | Samsung HTP-1200 System
Medion MD-1704 PC Desktop Logo
298 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
