Question about Panasonic PV-DF2704 27 in. TV/VCR/DVD Combo
My dvd/tv combination will not play dvd I have tried the cd cleaning lense but it will not play the cleaning lense. What is the problem?
  • Panasonic Master
  • 12,061 Answers
Http://service.us.panasonic.com/OPERMANPDF/PVDF2004.PDF
http://www.nodevice.com/manual/newmans/panasonic/PV-DF204NASVCzip/get27160.html There above is a service manual, this will help you isolate and possibly repair More than likely it is the laser head assembly, as it usually is, this can be replaced relatively cheaply, if parts can be obtained, this is what you need a service manual to get the part numbers. You could also just replace the entire DVD unit, as that;s some times easier and less expensive.
http://www2.panasonic.com/consumer-electronics/support/TV-Combos/model.PV-DF2704
Posted on May 11, 2010
CD disk is plays, but DVD disk in no playing,,sometimes dvd plays,mostly no disk
try cleaning the laser lense
If you have a dirty lense it can still read cd because data is not as compressed on dvd, each byte of data takes up far less space on a dvd so the dirty lense might not pick it up whereas it might pick it up on a dvd
Jun 24, 2015 | Televison & Video
When I play a DVD, the picture is green with some blue accents
First check the cable from the dvd to the tv, if it only happens when you use the dvd player then it is the lead that is the problem, unplug the lead from both blow any dust of both the connectors and plugs, then replace them ensuring they are in as tight in as possible on both, if you still get the same problem i suggest getting a different cable and trying that.
The other thing that could coarse this is the lense inside the dvd, get hold of a dvd lense cleaner and give that a try, also clean the dvd disk itself.
Feb 09, 2010 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
I have LG CD RW/DVD CD-ROM Combo Driver and my problem is that i can play CDs. When i insert DVD its showing blank or no DVD in the drive. How can I slove this?
It is your lense related issue.
You can clean your lense with disk cleaner disk purchase disk cleaner disk and put in dvd rom then play it.then it clean your lense.
But if still problem remains then your lense has issue.
So if your dvd rom in warrenty then take it to service center and replaced it .
It is is not in warrenty then you need to repair or replaced lense.
Jul 31, 2009 | Computers & Internet
Dvd drive no longer plays dvds on emachines T3410
When the CD/Dvd Drive becomes old the Optical Lense is not strong enought to read DVD because DVD is more dense than CD track. You can Try to clean the lense. There are lense cleaner available on the market.
Jan 23, 2009 | E-Machines eMachines Desktop PC
Samsung DVD R130
PLEASE TRY TO CLEAN THE LENSE OF THE DVD PLAYER OR REPLACE THE LENSE
Aug 03, 2008 | Samsung DVD-R130 DVD Recorder
Mintek TV/DVD Combo
Hi have you tried using a dvd lense cleaner these are cheap to buy and will clean the laser lense this usually solves the problem but if not then the chances are your going to need to get the laser replaced.
Mar 26, 2008 | Mintek DTV-233 23 in. TV/DVD Combo
Dvd
Hi you have more than likely got one of the two main problems these type of combo tellys have the first and chapest problem is dust on the lense as its a combi with dvd they attract alot of dust as the static from telly draws all the dust into the dvd part and covers the lense in dust.
The first thing to try is buying a cd lense cleaner and run this through your dvd played dont buy a cheap one as they tend not to work after trying this if you still have no luck then the problem is going to be more expensive.
The second problem is going to be either the lense failing or the drive failing that spins the disk in either case you need to repalce the laser unit itself this is somethnig you cant do yourself as you need to get the new laser calibrated.
The problem with buying new laser nad getting it fitted is that the price of these tellys new would work out to about the same price of a new laser that is unless it just needs a good clean also check the actuall dvd is clean and free from scratch try playing music cd as this has less data and is easier for the laser to read so give it a try nad let me know how you get on ok
Feb 10, 2008 | Sylvania 6419 Combo
DVD player keeps skipping and gets very blocky looking and then sometimes it just stops I tried cleaning both the lenses of the dvd player with dvd lens cleaner disc and cleaning the dvds nothing seems too...
It sounds like the problem is with the DVD's you've been playing. I've gotten those problems before, but not on every DVD. How many different ones did you try playing?
Jun 16, 2007 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
No disc error showing up-takes 20 tries to bring up dvd
Maybe the laser is unable to focus on the smaller pits and lands of a DVD disk but can see the relatively large pits and lands from a CD just fine. This may be solved by using a CD/DVD cleaner disk. It's a disk with small brushes on it that attempt to brush dust from the laser's lense. They don't always work but that's what I'd try.
Dec 27, 2006 | Apex Digital AT2014DV 20 in. TV/DVD Combo
Panasonic PV-DF2704 27 in. TV/VCR/DVD Combo Logo
208 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
