Question about Gateway MX8738 Notebook
LAPTOP WILL NOT TURN ON . GATEWAY 8738. NO LEDS LIGHT ON FRONT. DOES NOTHING BATTERY IN BATTERY OUT. WILL NOT TURN ON. I SUSPECT MOTHER BOARD
    Guru:
  • 1,705 Answers
You could well be correct but just to make sure.
You need to beg, borrow or steal another known good power supply/charger unit and see if that works. You see if yours in faulty, its not charging the battery or supplying power to the laptop.
If nothing glows after that it could be the charger circuit on *********** board or just the power connector on the motherboard .
Posted on May 11, 2010
How do I re-boot and old linovo R61i laptop
take the new battery out
see if it will kick start just on mains power
if you hear a beep as it powers up mother board is ok
if the mother board is dead and no beeps it wont start up
try this each time from power up
if you hear a beep hold down
one of these F5 of F1 or F 12 wait to
see if a menu from the mother board itself is visabe
then follow the prompts
if nothing also suspect hard drive or chip failure
Jun 19, 2016 | Lenovo ThinkPad R61i Laptop
I have no led light on my e1705 when i press it and nothing comes on
Things to check:
1. AC adapter cord, esp close to the brick. Does the green light come on the brick? If not, replace the adapter.
2. Reseat battery. Check the battery charge by depressing the battery indicator button on the battery. Does it have a good charge? If so, then it could be the connection to the mother board causing the issue. If not, then replace the battery.
3. If both the battery is good and the AC adapter is good then you are looking at a mother board issue.
May 21, 2010 | Dell Inspiron E1705 Notebook
The laptop will not power on and has a fully charged battery. The power on button will not light when pushed. When plugged in the led light on the front edge of the laptop should start out pink then turn...
Hi
I presume you checked the DC power supply. Don't use a generic power supply on this model, because that will cause alot of different symptoms. I use the exact same model on service calls. A further way to test the mother board is to remove the CPU and memory. Carefully provide power and look for lights. If none, my next step would be to refloat the video chip. This requires special equipment. A replacement mother board without processor on eBay is $49.00 so it might be time to consider that. Good luck
May 05, 2010 | Gateway MX8738 Notebook
Gateway 450ROG, will not start. Red DVD/CD ROM
I have the very same problem, the Drive light turns red, the screen is "black" and the battery charging light indicator on the front is off. No differance if I'm traying to power up on battery or AC-adapter.
Before this problem appeared I had problems where the laptop was powering off, with no warning, and I had to restart it. This happened several times and was going on for about a week before it died totally. Can it be the CMOS battery on the mother board? Anyone having clue what the problem could be?
Mar 31, 2010 | Gateway 450ROG Notebook
My dell latitude won't turn on. The battery light is blinking on and off but it won't charge. I just bought a new charger I push the power button and it powers on and the led lights flash then it quits. Is...
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 04, 2009 | Dell Latitude D600 Notebook
We have proplem in power damage in mother board the led of power on is on put no power in screen and led of HDD is off model no 450 ROG
Remove the battery and power cable from the laptop. Press and Hold teh power button for 20 sec, connect the power chord and then try to turn on the computer
Sep 10, 2009 | Gateway 450ROG Notebook
Hp 1270n power problems
Sounds as if your power pack might have a problem.blown fuse ect.I whould remove the cmos battery and or change jumper pin setting to start fresh in the bios settings.after removng the cmos battery,Make sure to put it back in before you re boot your computer. Good Luck garydalel
Dec 29, 2007 | Gateway (4000811) Motherboard
Gateway MX8738 Notebook Logo
175 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
