Question about Canon iR 1600 Laser Photo Printer
DOUBLE SIDED COPYING
HOW DO I COPY 2NO SINGLE SHEETS ON ON ONE BIT OF PAPER WITH 1 SHEET ON EACH SIDE WITH MY COPIER CANON iR1600
  • 1,219 Answers
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
Posted on Jun 14, 2010
How can I print single sided copies?
There should be a copy options button on the screen (often the left hand side). If you are copying a double sided page to make single sided copies choose 2 sided to 1 sided.
Or if you are copying 1 sided to 1 sided, make sure this option is selected (it is usually the default). Hopefully this helps!
Mar 21, 2017 | Office Equipment & Supplies
What's your question?please how do I copy multiple copies with canoniR2000? mine copy's one n display incorrect paper size
Copying What You've Already Drawn ' SketchUp ...
https://help.sketchup.com/en/article/3000092
SketchUpWhen you copy and paste with the Move tool, you can make a single copy or createmultiple copies and tell SketchUp how to space them - if you know the ...
For Sale Canon IR2000 digital copier ' Facebook
https://www.facebook.com/media/set/?set=a.144875105642811...3
For Sale - Canon IR2000 digital copier Copy Speed 20 CPM First Copy ... Time 30 Sec Zoom 50-200% Duplexing Not supported Multiple Copies 1-99 Copier ...
Can I make multiple copies of the same DVD? - DVD-Cloner
www.dvd-cloner.com > DVD-Cloner Knowledge Base
Of course you can. Please use the option: "Number of copies" in the "Burn I/O" tab of the "Advanced setup" window. You can make multiple copies of the same ...
Canon Ir2000/2010/251/271Digital Copier - Buy and Sell Plus
www.buyandsellplus.com/.../Canon-Ir20002010251271Digital-Copier
Aug 28, 2012 - First Copy : Approx. 8.2 seconds. Max Copy / Orig. size : A3. Copying Resolution : 1200 x 600dpi. Multiple Copies : 1-99. Magnification Zoom ...
[PDF]iR2000/iR1600 Reference Guide - Canon
Dec 26, 2015 | Office Equipment & Supplies
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
I need to change our Canon IR2016 from A4 to A3, Also I need to activate 1 to double sided copies. I am looking on line for the user manual for the IR2016 but can't find
ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
Jan 19, 2011 | Office Equipment & Supplies
How can i copy automatically on both side(duplex)???
On the cotrol panel under the clear plastic cover you will find two sided options:
single sided to double sided
double sided to single sided
double sided to double sided
Aug 15, 2010 | Canon NP 6650II Copier
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
Double side to single copy w/o paper feeder
Try this.
Set the copy for duplex.
Put the drivers license on the glass.
press the start button.
Turn drivers license over.
Press the start button.
Should copy on both sides of sheet.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
How to use
Does the copier have a duplexer? Automatic 2-sided copying (duplexing) was an optional feature for the EP2030. If there is a drawer in the lower section of the copier labeled "duplex" then your unit has this feature.
To use it, simply select 1>2 (for single-sided originals) or 2>2 (for 2-sided originals) on the "Orig>Copy" section of the control panel (toward the left side).
If your copier is not equipped with a duplexer, the only way you can make 2-sided copies is to copy the first side and then load the copies back into the paper tray or the manual bypass on the right side of the unit.
Note the the copier copies on the bottom side of paper fed from the paper trays, and the top side of paper fed from the manual bypass.
You can download a .pdf file of an operator's manual for this copier from the Konica Minolta website.
Oct 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
CANON IR 2000
Canon iR1600/2000 not a double-sided copying machine. Can print one side then reverse copies in paper cassette and copy side 2 onto it.
Jan 31, 2007 | Canon imageRUNNER 2000 Copier
Canon iR 1600 Laser Photo Printer Logo
207 people viewed this question
old marine
old marine
