Question about Amana Refrigerators
Fridge freezer stops working although all lights are on and the motor is running? everythin defrosts and is wasted, it can stay off for a few hours or a couple of days, then it restarts on its own ?
  • Amana Master
  • 12,061 Answers
Http://www.servicematters.com/maytag_library/docs/16010154.pdf
  1. Your Amana refrigerator stopped. If this happens, make sure that there is power. It might be that your refrigerator doesn’t have enough power getting to it. The circuit breaker or a fuse might have been shut off. Check if there’s a shortage in power. Try plugging another appliance that you know is working just fine in the same outlet where your refrigerator is plugged into. If it doesn’t work, then you know it’s your power supply that’s the problem. Check your circuit breaker or contact an electrician if it’s something you know nothing about. On the other hand, if it’s not the power supply, check your Amana refrigerator if the light still comes on. Also, listen if you can hear a fan or motor as it is turned on. If you do hear something or the light still comes on then your refrigerator isn’t completely stopped. There is a specific problem that we should find about. Adjust the thermostat to the coldest setting, did it work? If not, it can either be a problem with the wiring, thermostat, defrost timer, compressor, relay, and/or overload. In this case, you should already be contacting a qualified repair technician.
  2. Now, if your refrigerator isn’t cooling, then you must check the thermostat knob and reset it to the proper setting. If it doesn’t fix it, make sure to check the compressor motor and see if it’s running. You should see it at the back of your refrigerator looking like a ball case near the bottom of the Amana refrigerator. If it is making a noise but still could not cool your fridge, then there can be a more serious problem in which case you must call a professional. If however, it seems to have stopped working even if there is power to your Amana refrigerator, and then you should check the thermostat, overload, capacitor, relay, defrost timer, and the condenser fan motor. Either way, calling a technician would be the best thing to do.
  3. If your Amana refrigerator’s cooling is poor then it could have a problem in its evaporator coils or condenser. The evaporator coils might have a heavy frost build up. You can only see the coils if you remove the panel inside your freezer. If the inside walls of your freezer has ice build-up, then your evaporator coils are probably filled with heavy frost too. Too much frost in the coils won’t allow air to be drawn over the coils. Thus, cooling in the refrigerator is limited. Defrost your fridge and see what difference it can make. On the other hand, you can also check your condenser and see if it is clogged with dirt, dust, or lint.
Posted on May 11, 2010
Fan in freezer has stopped working,have defrosted and fridge seems to be cooler.
Simply defrosting the freezer might solve your problem. Sometimes ice can form on the fan or fan motor, and of course, prevents the fan from turning.
If there is ice here, your refrigerator isn't defrosting properly. This sounds like a defrost problem that may need a part replaced. Check out this site for details and photos. Refrigerator Defrost Parts
May 07, 2014 | Refrigerators
Freezer defrosts all the time
The defrost timer is faulty
Jan 16, 2014 | Refrigerators
Proline fridge/freezer the fridge is frosting up at the back but food is not cold enough
Hi.
You have a problem with the defrost system. Try disconnecting power overnight and allowing fridge to defrost. The problem will not occur immediately after defrosting, but will probably restart after few days, when the evaporator coils freeze again. In that case the defrost system must be tested and repaired.
The defrost system comprises defrost thermostat, heater, defrost control and fan. The parts that fail more commonly are thermostat and heater. Both parts are located behind freezer firewall and tested reading impedance with a multimeter.
A test on the defrost system can be done by performing a complete defrost manually (remove food and leave power disconnected overnight). If the fridge restarts working after defrost, then problem was the defrost system. In that case the problem may return after few days or weeks, meaning that one part in the defrost system is faulty.Parts must be tested.
If the defrost makes no change, then there is a different problem. The damper ventilation system , the temperature control or the refrigerant gas pressure may be the problem. When the problem is one of these faults you get the compressor is running regularly, but will stay on most of the time.
If the motor is humming and clicking most of the time, but not properly starting, then the problem is usually the starter relay/capacitor. Relay and capacitors can be replaced to fix the problem.
Here a tip explaining how to deal with a similar problem on a different fridge model: Fridge not cooling. Procedure is similar on your model.
You can find parts and diagrams for most appliances here:
Where do I find parts and diagrams for my appliance?
Regards.
Aug 08, 2011 | Refrigerators
GE Refrigerator isn't cooling properly freezer is freezing ice
You have a defrost problem !
The fridge isn`t defrosting automatically . Although it`s likely the defrost timer motor seized , it could also be the defrost termination switch , also known as the DTS switch , (or limiter switch) ..... or the defrost heater itself .
Any one of those three will give you the exact same symptoms .
You can diagnose this problem yourself simply by emptying the fridge , unplugging it with the doors slightly open , and letting it defrost for a good 24 to 48 hours .
Plug it back in , and let it run for about 12 to 18 hours . If the temperatures are OK after that , and remain OK for a few days , the problem is exactly as I described .
A defrost timer is worth about $30 to $40 .......... a DTS about $10 to $12 ............. and a heater anywhere between $25 to $75 , depending on the model .
Jul 03, 2011 | GE Refrigerators
Hi we have a GBS22HCPABB fridge and the motor runs, frezzer works but fridge will not get cold just stopped
you have a few possibilities 1. a defrost problem restricting air flow from freezer to ref. 2. a bad freezer fan motor 3. a damper issue not opening to allow air to flow from freezer to frig. most all refrigerators generate the cooling from the freezer to the frig via the freezer fan motor
Mar 06, 2010 | Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Fridge freezer not working after power cut
If the fan motor is running at the compressor you should first replace the compressor start relay.
If the fan motor at the compressor is not running replace the defrost control.
Feb 21, 2009 | Freezers
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Jun 21, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
