Question about Electrolux EL1000A2 Pronto Bagless Stick Cyclonic Vacuum
Hi, I have not owned my electrolux pronto 2 in 1 for very long but the roller brush has stopped turning. The handheld part works and the green light is on. I have done a thorough cleaning of the roller brush and all other removable parts. What might be causing the roller brush to not work? Thanks, Jen
  • Anonymous Mar 24, 2014
    Are thre substitute roller brushes for the Electrolux Intensity EL5020? The part is ROLLER BRUSH 63322.
  • Electrolux Master
  • 8,404 Answers
Check the end cap bearings ... and replace the belt even though it may not be broken. Put a drop of sewing machine oil (no more) in each end cap bearing.
Posted on May 11, 2010
My electrolux vacuum has a red light that won't turn off and my brush roll won't work
Check the belt and the end bearings are free by hand. (electric off plug out) if not free remove plate to access roller/brush, remove clear any obstruction (Hair/string/thread) replace and test. ensure you site belt back on to spindle and roller/brush correctly...
Aug 22, 2014 | Electrolux Vacuums
The cleaning brush is not turning
Turn the unit bottom up, Looking at the roller to the one side is a screw cover, you can use a dime to unscrew the cover and pull the roller unit out ans check for miss-alignment of the gears.
Jan 25, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I have a electrolux Pronto 2 in 1 and the suction really never seems strong plus the brush in the base doesn't turn and the vacuum has been plugged in for two days. how can I get more suction and make the...
There is a filter inside the main filter. Once that filter gets clogged it will loose suction. Pull the filter and clean it, you can wash it by hand. Turn the unit roller side up and check for a small screw cover that you can use a dime to loosen. This cover is used to remove the roller unit. Once out check and clean then check the gear assy. for miss-alignment.
Jan 24, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Brush does not turn. suction with the handheld unit it fine but when used as a floor sweeper it hardly picks up anything
these stick mmachines do not have a tremendous amout of suction at the best of times but if it has a full bag, or full dirt container, or dirty exhaust fiters it will take away from the air flow as well. take a flashlight and look up in to the tube of the floor attachment to see if you can see something blocking the tube.If there is no obstructions it may have a roller bar that spins on the bottom , so turn it over and turn it on and if it has a roller bar and it is not spinning it probably needs abelt . If there is no roller bar and no blo0ckage chances are it is just weak at the floor tool as the air a further to travel all the way up from the floor so it takes away from the air flow again. good luck.
Oct 07, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
The brush on ours wont spin
Take out the brush roller. (turn the plastic lock mechanism with a coin or screwdriver, pull out the plastic holder, and the brush will pop out). The brush roller has two white caps on the ends. Chances are, one or both of these caps have moved out just a bit, putting too much force on the delicate motor. Simply push the caps back firmly into place. Make sure the brush and the surrounding area is clean, put back in and It should spin .
Feb 25, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I have a velocity pet lover 1900 only 2 months old
You have broken the rubber belt that drives the brush. Flip over and remove the old belt and replace it with a new one.
Jim
Jun 10, 2009 | Electrolux EL1000A2 Pronto Bagless Stick...
Roller/sweeper on my Electrolux Pronto
After 3 years my Pronto slowed down and needed new batteries. I just replaced all 8 internal batteries. It cost just under $30 with shipping and took 1 hour of soldering. If you're not handy with a soldering iron, don't attempt it. All of the batteries are soldered together in series. You need to order the 8 (4/5 Sc size, 2000 mAh) Nickel metal hydride (Ni-MH) batteries with tabs. The source I used was www.BatteryJunction.com. Here's a link to the battery page: http://www.batteryjunction.com/tenergy-45th-sc-1-2-2000-tabs.html
PS The vac now runs GREAT!
Russ
Feb 28, 2008 | Electrolux EL1000A2 Pronto Bagless Stick...
Roller problem
I have 3 Prontos, one in each part of the house. Two of mine had the rollers stop. I figured out the problem and it fixed both. Take the roller out by turning the plastic screw and popping the plate off. Pull all debris off the wheel that turns. Turn unit on and make sure this wheel is turning freely. Take the brush and look on the end with the square part. Take some pliers and gently pull this square piece off. I had to wiggle it a little, but it pops right off. Clean all debis (mine had several small dust balls and 1 long hair) in the square part and down in where the square part goes. Push the square part back on and put brush back in unit. This fixed both of mine. Hope it helps.
Dec 18, 2007 | Electrolux EL1000A2 Pronto Bagless Stick...
Electrolux EL1000A2 Pronto Bagless Stick Cyclonic Vacuum Logo
252 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
