Question about Refrigerators
Gas bottle really hot fridge/freezer not cooling
iwillfixforu
  • 619 Answers
SOURCE: getting very hot in the middle betweenthe fridge and freezer
The condenser fan located on the bottom near the compressor is not circulating well enough to keep the compressor at a good operating temperature causing the compressor to shut down for longer periods of time until cool enough to run again. Clean the coils good and replace condenser fan and you will be fine. The fan works as a cooler for the compressor. Imagine working in the yard on a hot day wearing a mask over your nose and mouth. Your body shuts down quicker because you have to take more rest due to the restriction of fresh air. Same applies to the compressor. Hope this helps. Rick
Posted on Apr 27, 2010
Testimonial: "Fan was not running at all ... big help ...thank you"
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
  • 68 Answers
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Posted on Mar 18, 2009
How do I run a diagnostic test on my fridge freezer?
I would check the coolant pressure is correct. You may need the services of an engineer with the correct equipment and gas bottle.
Aug 11, 2014 | Zanussi & Electrolux Fridge Freezer Handle...
Refrigerator is hot but the freezer is cold
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 12, 2013 | Sub-Zero 650 / O Bottom Freezer...
Ge tfg27pfxa profile with cooling problem
Remove the back panel in the freezer to see if the defrost heater is running continually.
Nov 06, 2012 | GE Refrigerators
My fridge isn't gettin cold, my freezer works ok, and the compressor is really hot...how can i fix this at home??
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 19, 2011 | Refrigerators
Hi at the back of my fridge freezer i think the compressor at the bottom is very hot, also the small pipes at the back is not heating as much as the compressor, actually anything but hot but not cold...
It possibly needs re gassing. Call a refridgeration expert in to look at it for you, there is nothing you can do without the gas bottles and evacuator.
Hope that helps.
Jan 04, 2011 | Microwave Ovens
My beko fridge freezer keeps turning itself off and when i pulled the fridge freezer out there is what looks like a fat gas bottle at the bottom and that was very hot i think the model is cg964d
These appliance work with a thermostat that is when ever they reach a certain temperature they do cut off power automatically..If you find that ice is melting then you need to start worry.By the way the fat gas bottle is an air compressor which helps to circulate the gas around the system...It's like the heart of the fridge.
Jun 15, 2009 | Freezers
Panel between fridge and freezer hot on Kenmore fridge
It is normal for that panel to get warm while the fridge is running. There is a hot gas tube from the compressor running through it to prevent frost built up. If it's feeling a little too hot try cleaning the coils under the fridge. This will allow the gasses to cool a little more efficiently thus allowing the fridge to cool quicker.
Nov 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Feb 28, 2008 | Refrigerators
Hotpoint ff175b fridge freezer
I had the same problem. Hotpoint told me it was the electronic card, and I waited 3 weeks for them to get one in stock. Just been fitted and made no difference, though the Hotpoint man told me it was fixed. I have just spent half an hour "shaking and whaking" various bits at the back of the fridge freezer and the compressor has finally kicked into life.
Concentrate your shaking and whacking on the black square thing to the left of the compressor.
Going to quit my job and become a freezer repair man.
Nov 28, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
523 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
