Question about Electronics - Others
Electric scheme for caravan chateau touring 320, manufacturing year 1976 1.There are not working in the same time , supplied at 220V , the lightning at 12V and the 12 V water pump. 2. Suppling only from the car battery of 12 V, through the cable, the 12 V lightning and the 12 V water pump are not working; there are working only the circulation lights (position, signaling, etc). 3.We cannot be sure that the refrigeratior is working during driving (supplied by the 12 V car battery). That is why the electric scheme is absolutely needed.
  • 1 more comment
  • danavioricap May 11, 2010
    The additional identifications details:
    Chateau caravan N.V. Hamont Belgie
    Chassis: 2776103
    Thank you and looking forward to your answer.
    Daniela
    Thank you for your prompt answer but, unfortunately I do not have any other information that the ones that I repeat below:
    This is a caravan which is drown up by the car; it is a Chateau touring 320 model, manufactured in 1976; on the plate there is mentioned only Chateau Caravan N.V. HAMONT Belgie. We bought it last year from a dealer near Antwerpen and, having only 750 Kg, no documents were needed and so, we received no documents mentioning, manufacturer or other information.
    We just found out that when supplied at 220V (i.e. in campings where we have this possibility) it is ok, lights, refrigerator and water pump work, but we cannot use in the same time the 12 V lightning and the water pump (which is also on 12V); respectively, the lightning and refrigerator work on 220V, and to have water we have to plug the pump cable into the transformer socket for 12 V.
    If supplied by cable from the car battery nothing works in the inside of the caravan (only the position lights at the exterior of the caravan work).
    Sorry, this is all the information I can provide.
    Daniela
  • danavioricap May 15, 2010
    As I wrote before, I need the wiring diagram for a caravan type Chateau tours 320 - Chateau caravan N.V. Hamont, Belgie, manufacturing year - 1976.It this a small caravan of 750 Kos weight, for 2 persons, endowed with refrigerator, gas stove, small bathroom with mobile WC seat.
    The problem is that being connected to 220V, all 220V lights and refrigerator work, but the water pump is on 12V and also, above the stove there is a 12V light bulb. Well, these last two do not work simultanously; there is a transformer under the sink and I can connect there, at the 12V socket, either the light, or the water pump.
    Another problem is that, if not connected at 220V, but connected to the car battery by the cable that is provided, only the trafic lights work; the refrigerator, having the switch on 12V position, does not work and also, the 12V light inside the carvan does not work. The light is not such a problem, but not having the refrigerator functioning if not connected at 220 V, this..is not ok.
    Do you think that it is possible to get help for solving these problems? Is it any way possible to get the wiring diagram for this caravan or similar? Thank you!
    Genius:
  • 1,478 Answers
I will like you to be more specific with the problem posted, which electric scheme is needed? Please give details on the kind of electric scheme that is needed.
Take care.
Posted on Aug 09, 2010
  • 821 Answers
Hello,please kindly visit the site below for a more comprehensive instruction,
www.western-towing.co.uk/.../Caravan_12S_wiring_diagram.html -
OR
www.practicalcaravan.com/a-z/index.html -
take care.
Posted on May 11, 2010
  • 2 more comments
  • Hammid Disu May 15, 2010
    hello,kindly visit the site below for the wiring diagram of your caravan chateau,
    www.exploroz.com/Vehicle/.../BatteryCharging.aspx
    OR
    laekenseherder.eu/kid.php?tam=83
    wish you good luck,
    take care.
    hello,please kindly visit any of the link below to get a comprehensive instruction for your caravan chateau.
    www.exploroz.com/Vehicle/.../BatteryCharging.aspx -
    http://www.thefind.com/cars/info-series-...
    wish you good luck,
    take care.
  • Hammid Disu Jun 10, 2010
    hello,you can kindly visit the site to get your wiring diagrams,
    http://www.western-towing.co.uk/acatalog...
    wish you good luck,
    take care.
  • Hammid Disu Jul 29, 2010
  • 1,871 Answers
Hello! Please identify the manufacturer of the caravan's chassis and motor home. There are many caravans using the name "Chateau". An example would be the 1976 Ford van with a Kit Manufacturing Company Motor Home installed called the "Chateau"...
Guru...............Saailer
  • 4 more comments
  • David Burbee
    David Burbee May 11, 2010
    Hello! I'm running into a language barrier...Can you tell me the make and model of the chassis as in...Who manufactured the truck that the caravan is built on...
    Saailer
  • David Burbee
    Hello! Thank you...The fact that it is towed as opposed to a self contained vehicle helps much...Let me see if I can locate a wiring diagram...Saailer
  • David Burbee
    Hello! I have sent a request to a company in the UK...When I receive an answer I'll send a comment...
    This could prove to be a difficult set of drawings to acquire...An option is to use another caravan as an example...The circuity is often very similar...
    I'll keep you posted...Saailer
    Thank you very much for your efforts. Hope to succeed in obtaining the drawings and find a solution for our caravan problems.
    Looking forward to further news from you,
    Regards, Daniela
    Thank you very much for your efforts. Hope you succeed in obtaining the drawings and find a solution for our caravan problems.
    Regards, Daniela
    (I repeated my message as I think it wasn't sent to you the first time; if it is a "double", please excuse)
  • David Burbee
    Hello! The following web site gives an example of how most caravans are wired...From this you can understand how yours is wired...The battery that is used is not like a car battery but one designed to deep cycle (be charged..then drained repeatedly without harm to the battery)...It can be charged in two ways...By the vehicle that is towing using its alternator or by the charger that is enabled when you are plugged into AC...From there to a fuse panel ...then on to lights, pumps, etc...
    If you have a voltmeter you can test to find where the +12 volts is being lost...If you do not have the ability, I'll walk you through it...When the van is plugged into 220 the voltage across the battery goes from around 12 volts to 14 volts...This indicates the battery is being supplied with a charge...+12 volts should be present at the fuse panel...
    Web site is www.ccis.com/home/mnemeth/12volt/12volt.htm
    Saailer
I have a 2 year old Meos 192B TV. It works perfectly on 220V but not on 12V. What could the problem be?
I suspect there is not enough power to run the TV. Does it work in your vehicle with the supplied power lead.
Jan 31, 2017 | Televison & Video
I need electric scheme for frontier power supply p4-500w
Contact the manufacturer. No schematics here.
May 12, 2015 | Computers & Internet
Schwinn bike serial numbers
The Schwinn Super Le Tours were made in Japan from 1976 to 1985. Your serial number "K6" would have been made in November 1976.
Jul 18, 2014 | Schwinn Cycling
Oven does not work,no display.
the display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Mar 06, 2010 | Whirlpool RBD305PD Electric Double Oven
Our brand new electric convection oven, kitchenaide won't heat. we are using it for the first time. Please help
First thing you need to know if your electrican hooked it up correctly It needs 220v to run heaters.if your getting only 120v the lights and all may work but no heat. Second, its under warentee from manufacture for a year. Call them.. If you messaround with it you may void warentee.
Nov 11, 2009 | KitchenAid KEBC101 Electric Single Oven
Using dryer in 220V country
There are two systems in use in the states
110v dryers are available that fit a standard 11v 15a socket
110/220v fit the oversize 'dryer' sockets, and they are two 110v phases 90 degreees apart
the motor runs of a single phase 110v.
there is 220v between the 'outside', the active lines of the two phases, at any time, but it is not useable to provide mechanical power as a single service, due to the complicated shape of the wave form when you add out of phase voltages together, but is ok to drive the heaters, they have no mechanical efficiency requirement
A 2 phase 110v heater it means 3kw can be supplied without a 30 amp circuit
but it becomes difficult to use a single phase 220-240v transformer to provide 2x110v 90degree 2 phase current unless you specially buy one in. .
High power applications in 220-240v are generally supplied by 415v 3 phase 60deg supplies,
Any transformer would be onsellable at the end of your posting, to your replacement, who would doubtless be in the same boat as you, with a heap of 'stuff' that needs to run.
UK Aus NZ may be sources of transformers, or dryers to suit.
check with Australian UK NZ suppliers as well as local Indian ones, as those countries are also nominal 240v single phase home suplies and they may have (1) the dryer, or (2)the transformer to suit the 110 2 phase dryer
Sep 10, 2008 | Kenmore 62602 Electric Dryer
Electronics - Others Logo
338 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
