Question about Eljer & Elongated Toilet Bowl
Low water level in bowl after flushing
After flushing new Eljer toilet the water level in the bowl is down in the throat. The water level in the tank is fine, 5/8" below overflow. I have to hold the flush lever down for 5 seconds so the bowl fills up.
    Problem Solver:
  • 12 Answers
The bowl that you have has the ptrap that's molded in the bowl was made differently when it was molded at the factory if this bothers you I would write Eljer to see if they would replace the bowl for you.
Posted on Nov 05, 2011
    Novelist:
  • 145 Answers
The small black tube that goes into the overflow is used to fill the bowl after flushing. Would check to make sure that water is coming out of that tube at full force or if its coming out at all.
Posted on May 18, 2010
Eljer toilet bolts rusted causing massive flooding
Turn off the water at the supply (under the toilet, usually).Flush the tank to remove all water from the tank.Disconnect the supply from the tank.Remove bolt caps or bolt covers from where the toilet bolts to the bathroom floor.Remove bolts from the floor flange. When you lift the toilet up, you'll see a metal or plastic flange. If the toilet has been there for a long time the bolts may not pull out of the flange easily. In this case you may have to use a small hacksaw to cut the bolt below the nut.Put newspaper or an old towel on the floor so you can place the old toilet on it. Lift the toilet off the flange.Take the new bowl (assuming this is a two-piece toilet) and turn it upside down. Position the wax ring on the horn of the outlet. Install new solid brass flange bolts, mount them and position them on the centerline on either side of the outlet.Push the bowl down over the bolts and seal the outlet. The wax will squeeze down and seal.Put the new bolts, washers and bolt caps on. You may have to trim the bolt with a hacksaw.Once the bolts are secure, mount the tank.Make sure the gasket between the tank and toilet is in place. Then position the tank on the bowl. Run bolts through the tank and secure. Don't over tighten (the tank can crack).Hook up the water supply line.Connect the supply to the line on the bottom of the tank.Turn on the water.Let the tank fill.Flush once or twice to make sure the water control is properly adjusted.Put the tank lid on.Enjoy.
ford performance chip.
May 25, 2012 | Eljer Home
Elijer Diplomat toilet flushes perfectly, but after the water in the bowl takes forever to fill up again. You have to wait 10-15 min. before the water is up to normal level and it will then flush...
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Jan 28, 2011 | Eljer Aqua-Saver 12" Two-Piece...
My eljer tank cracked and I need to install a new tank. How do I just install a new tank? The bowl is fine. Companies are trying to charge me about $300 to do this and I do not have the money. Please...
Let's assume you can buy the tank.
Installation of tank is simple.
If you can buy the eljer tank, you can buy whole new toilet with bowl and tank from home center.
We'll walk through instructions for both options.
1) How to replace tank on existing bowl.
-Tank is attached from underneath with two nuts.
-Turn off water, and hold flush valve down to drain tank
-Water connection is one nut. Follow supply line up to where it connects to tank. Loosen the nut that is around supply line just underneath tank. Pull nut downward and notice a black rubber washer that is probably stuck inside nut, or is stuck at bottom of tank. Make a note of where that nut is because it seals the water line to tank.
-You might also have a flex connector instead of supply tube. In that case, just unscrew flex connect from bottom of flush valve.
-Look beneath the tank and there are two nuts that hold tank to bowl.
-Take off these two nuts. A ratchet and socket is best tool, but you can use crescent wrench. -Notice these nuts are not exceptionally tight, but they are firm.
-Straddle the bowl and hold tank with two hands and lift up. Tank will come right up.
-Notice that on bottom of the tank: there are 2 bolts sticking out and there is a spongy rubber washer. This is the spud washer. Your new tank will have new washer. This washer seals tank to bowl so water doesn't leak when you flush.
-Notice round opening where flush water flows into bowl. Spud washer seals this hole. If you have experienced slow flushing, or if you have hard water, pour several cupfuls of CLR Calcium Lime Rust into the hole. CLR is sold at Home Depot by the gallon for $10.
-Open box to new tank. Find spud washer and fix it to bottom of new tank.
-Now a new tank is slippery, I want you to set boxes on floor nearby so if tank starts slipping, aim toward a box instead of hard tile floor.
-New tank comes with 2 new bolts, with nuts. Look at instruction sheet and see exactly how they want you to connect bolts to tank. Look carefully where they want you to put washers. These washer seal the tank when you tighten bolts.
-Now your spud washer is in place, the bolts are attached to tank and are sticking out of bottom of tank.
-Straddle bowl and lower new tank into place. Make sure spud washer lines up. Bolts line up. And flush valve lines up with supply tube. It's that easy.
-Tighten the nuts. Remember, not too tight. Toilet is not steel. And you can tighten more if there is seeping water.
-Now tank is in place. Raise nut and washer that are on supply tube and tighten nut onto bottom of flush valve. This nut is fairly tight. You might want to buy a new washer.
-If you have a flex line for the water supply, then just connect the flex line.
-Turn water ON a little bit at a time to avoid gusher if something is not correct.
-Use paper towels to check for dripping or seepage beneath tank. Tighten nuts appropriately to end seepage.
-Flush toilet and look for seepage around spud washer.
-You're done.
2) How to install new toilet.
-Remove old tank as shown above.
-Bowl is held to floor with two nuts.
-Ideal world those two nuts come right off and you lift bowl up off the floor.
-Real world, those nuts are rusted and you have to drill through side of the nut and bolt to break it off.
-Lift bowl up.
-Have cardboard ready next to toilet so you can set bowl on something. Or set it in bathtub.
-Bowl will be damp and wax ring is on bottom of bowl and will mess up the floor.
-Notice how the toilet bolts are set in the floor flange. Take photo if needed so you can put it back. It's real simple, but if you have never done this, a photo might help.
-Take putty knife and scrape wax ring off of floor flange. You want it smooth, but you don't clean it.
-New toilet comes with wax ring and bolts, but you might have to buy these at hardware store. Get wax right with gasket. The boxes are marked. Buy two of them.
-Set wax ring in center of floor flange. Gasket goes downward. Rounded side of wax ring goes up.
-Set new toilet bolts into floor flange. Keep bolts straight up using wax from the old wax ring, or from 2nd wax right you purchased.
-Keep bolts straight across from each other.
-Time to set the toilet.
-Stand in front of bowl and grab on either side at point where seat connects.
-Here's the fun part.
-Bowl has to go straight down onto wax ring so you have to be strong enough to hold tank level while aligning tank with bolts, without knocking the bolts down. Like a carnival game.
-Straddle walk toilet while holding it up high enough so it will not knock over the bolts.
-Lower bowl into place going straight down using bolts as guide. Lower a little bit and check one side for alignment and then check other side until bowl is going down and bolts fit through the holes.
-If bolt falls over or gets pushed away, straddle walk toilet back and set bolt straight up again.
-Once bowl is aligned, keep pushing straight down on bowl, and finally use your weight to push bowl to floor. Be careful to keep bowl perpendicular to wall so tank will sit straight.
-Attach bowl to floor with nuts and washers.
-Install tank as shown above.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on toilet or any do-it-yourself project.
Jan 12, 2011 | Eljer 141-0220-00 Toilet Tank White
Leaks from tank into bowl and when flush as it
Change the flapper with a generic one that will fit that toilet... the OEM flapper is **** and it does not allow for a good flush either...
heatman101
Aug 03, 2010 | Eljer Toilet Onepiece Canterbury ...
No water in bowl
check the water stopper in the bottom of the tank is it closing all the way.
Apr 25, 2010 | Eljer & Elongated Toilet Bowl
Not enough water in the bowl after flushing
I don't know what kind of toilet you have, but if it has a tank, then probably the tube that squirts water down the pipe into the bowl has come out. Take the top off the tank and as you watch, flush the toilet and make sure water is going thru the tube down into the pipe. good luck
Mar 07, 2010 | Eljer & Patriot& Elongated Toilet Bowl
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
Jan 19, 2010 | Eljer Aqua-Saver 12" Two-Piece...
In the tank, when I flush, water comes shooting out of the black plastic thing, about 2 feet high! How can I make this stop so it flushes properly again? (its an eljer 2001)
is the black thing between the the tank and the bowl?
if so, go to any of the home center or plumping store for the seal.
shunt off the water and unbolt the 3 bolts that holds the tank to the bowl from the buttom. you may need a flat screw driver to help hold the bolts. pull up the tank slowly, and lay it on the side, replace the seal, reseat the tank on to the bowl and tighten the bolts. make sure all bolts are equal pressure and the tank is level.
May 05, 2009 | Eljer & Patriot& Elongated Toilet Bowl
No back flush pressure
increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Oct 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Eljer & Elongated Toilet Bowl  Logo
913 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
