Question about Sony Playstation 3 (PS3) Console
No display when turned on - Sony Playstation 3 (PS3) Console
    President:
  • 1,139 Answers
Hi there, try the following steps :-
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep once when you first press it, then again 5 seconds later. When you hear this second beep let go of the power button.
Step 3. Wait for your PS3 to start up
Hope this helps and thank you for using FixYa
Posted on Sep 26, 2010
Display not working on g12
The Display button toggles the information shown on the LCD (or turns it off entirely). Make sure you haven't inadvertently pressed it and turned off the display. It works as follows:
Press once for Normal view in LCD viewfinder
Press twice to turn on Rule of Thirds grid lines
Press three times to turn off LCD display
Press and hold 1 sec. to decrease/increase LCD brightness
Jan 05, 2014 | Canon G12 Digital Camera
Previous homeowner turned off GE Spacesaver 2.0 microwave display and now we can't turn it back on. Tried directions given to press option button 5 times then #1 to turn display back on. Doesn't...
I was not aware you could turn off the display, maybe it is just a bad display and you need to replace the board??!!
Ive been repairing Microwaves for 37 years. i do not remember seeing one where you could just turn off the display.
Oct 16, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Proton pltv- 3250 32 "lcd tv a friend gave me
To turn on the TV:
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
Oct 13, 2010 | Protron PLTV-32 Television
Display light does not turn off in sigmatel t33i. When the phone is switched on, the display light turn's off, as the time setted in the settings. But after a incoming call or entering in multimedia, the...
Display light does not turn off in sigmatel t33i. When the phone is switched on, the display light turn's off, as the time setted in the settings. But after a incoming call or entering in multimedia, the display light does not turn off in the sigmatel fxd t33i..
May 04, 2010 | Cell Phones
I can find nowhere on the tv that has an on off button, just got this tv
of the display.
Allso go here for full manual:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Oct 29, 2009 | Protron PLTV-32 Television
Turn on the camera, no display, but it still takes pics
I have a Canon digital camera and can turn on an off the display. There should be a button in your Sony do activate the display. Cheers
May 23, 2009 | Sony Cameras
Nokia E66: Display issue (lining errors, turn on issues)
there is stripe inside the phone which is damaged , and has to be changed look for nokia care around
Jan 13, 2009 | Nokia E66 Smartphone
How to set a deh-p4000ub car radios clock
try this:
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
the clock display you wish to set.
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
You can turn the clock display on or off.
! Even when the sources are off, the clock
display appears on the display.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Aug 05, 2008 | Pioneer Audio Players & Recorders
Turning off recordng message.
You can turn the display off during playback mode, however, if the display was on during recording, that cannot be turned off. . 1. Press the DISPLAY button on the left side panel. 2. Each press of the button toggles the OSD function on and off. When you turn the OSD off : * In CAM mode: The STBY, REC, EASY.Q modes are always displayed on the OSD, even when the OSD is turned OFF and the key input is displayed for 3 seconds then turned off. * In PLAYER mode: When you press any Function button, the function is displayed on the OSD for 3 seconds before it turns off. Turning the DATE/TIME on/off * The DATE/TIME is not affected when the OSD function is switched ON or OFF. * To turn the DATE/TIME on or off, access the menu and change the DATE/TIME mode.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Playstation 3 (PS3) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
