Question about Sony MDS-JB940 Mini Disc Player
Din unlock c-17 on sony mini disc
Got my ps3 connected to my amp by optic connection tryed to recored music from my mp3 connected to my ps3 to mini disc
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
If “Din Unlock” flashes in the display
• The digital program source is not connected as you set
with INPUT
To continue, connect the program source properly.
• The program source is not on.
Turn on the program source.
Posted on May 30, 2010
Din unlock c71
the input source you have selected is not working. If digital it might be a copy guarded source which the deck cannot read...
If you get fancier and are trying to record the optical output from a newer device like a 5.1 or 7.1 receiver although the signal will go through the MD deck cannot decode the advanced optical signal. There are adaptor boxes on eBay which decode 5.1 & 7.1 optical signals to an optical signal the older MD can read and record from.
Try selecting another source like analog RCA. The digital stuff I mentioned applies to digital RCA and Optical Cables like toslink.
Feb 08, 2014 | Sony MDS-JE520 Mini Disc Player
Mini disk player JES510 want to record some midi tracks using the optical link. keeps saying din unlock & then if try says cannot record. How can I overcome this? Help appreciated.
Like most home recorders the minidisc will not let you make digital copies of a digital original. The idea is to prevent piracy of copyrighted material.
Unfortunately, that includes digital tracks you yourself made,
Just go through the analog inputs. It will sound fine.
PS - professional minidisc recorders will let you record digitally, but they are expensive.
Mar 11, 2011 | Sony MDS-JE480 Mini Disc Player
Why i am seeing DIN UNLOCK
If you are recording from a DIGITAL input like the OPTICAL or DIGITAL COAXIAL and their is no signal, or if it is a 'non-copyable' copy of a digital copy (from a mini-disc or protected audio CD-R) you will see this. You need to record using ANALOG inputs, then you won't have this DIN UNLOCK problem using analog. Double check your digital connections and make sure your digital source is set to 'play' and see if the DIN Unlock goes off. Otherwise, use analog reocrding only.
Jan 18, 2011 | HHB BurnIt CDR830 CD Recorder
I'm trying to record on to my mini disc recorded (sony MDS JB940) and it's flashing Din Unlock c71. how can i solve this problem?
"The definiton in the manual suggests you are trying to record a digital bitstream that is either dead or incompatible with the recorder."
That is completely wrong. DIN UNLOCK means what the first poster said - that you are trying to make a digital copy of a digital copy. You cannot (for legal reasons). Record via analog.
ABSOLUTELY DO NOT TRY TO CLEAN YOUR LENS WITH ALCOHOL AND A Q-TIP. It has nothing whatsoever to do with your problem and you may well damage or destroy the lens or the transport.
Oct 20, 2010 | Sony MDS-JB940 Mini Disc Player
How to transfer music from mini disc to computer
John,
Don't be jealous, just join in with the popular digital stage. (I still have my 10inch, 7in reel - reels, 160 cassettes, 300 Albums yes lp's , 25 mini disc and a large array of CDs yes about 75% is now on my 30gb Iriver) which is portable hard drive ....you too can (if your mini disc is a net version, which can connect to pc via optical this will save you alot of time)...if not we are talking real time...which can be fun too (I just finish recording 400 vhs movies to DVD..it was a new years resolution, recorded 1 -2 movies everyday after work)...so keep the mini disc in working order too...and a suggestion sony walkman x series 32gb or apple ipod touch 32 gb
Apr 01, 2010 | Sony MZ-N420D Personal MiniDisc Player
C71/DIN UNLOCK
The definiton in the manual suggests you are trying to record a digital bitstream that is either dead or incompatible with the recorder. Go analog.
What happens if you skip the receiver? Be advised that anything coming in digitally through a cable/satellite box may be muliti-channel and convertible by the player to its native 44.1 khz sampling rate.
Mar 31, 2010 | Sony RCD-W500C 5-Disc CD Recorder
SONY MDS-JE480 "C71 - DIN Unlock" persistent problem
I get the DIN UNLOCK with you try to make a copy of a digital copy.
Jun 29, 2009 | Sony MDS-JE470 Mini Disc Player
I have a minidisc model mds e10
it seems your MD unit is expecting a digital signal on the digital input causing this message to appear.
You need to connect a signal source to the digital input
or
connect an analog signal to an analog input and select the analog input as signal source.
In both cases the DIN UNLOCK message will then disappear.
Cheers
May 14, 2009 | Sony MDS-E10 Mini Disc Player
Can't plug optical cable on MDS-JE500
optical will work any way you connect................connect mini out( play mode) to cd-r rec (in) recording or cd player (out) to mini (swithch to record, optical/line in/mic) the optical cable you have should work if all connection are fitted well. i record cd to mini using optical and vice versa all the time. just make sure you are connected correctly to what you wanna do
Mar 01, 2009 | Sony MDS-JE520 Mini Disc Player
Sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
Nov 16, 2008 | Sony STR-DB930 Receiver
Sony MDS-JB940 Mini Disc Player Logo
472 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
