Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Will not pump water from reservoir to carafe - Black & Decker SpaceMaker ODC325 Coffee Maker
    New Friend:
  • 47 Answers
Try this solution. It should fix the problem.
Posted on Jun 11, 2011
Why do I get the Add Water error when my reservoir is full? If I am brewing a K-cup it works fine but if I try to brew a K-carafe pack it says Add Water even though the reservoir is full. This is my 6th...
I'm writing this same answer on all issues related to "add water" issues. We just purchased a brand new 2.0 yesterday and were trying to make our first cup but could not get past "add water". Among other instructions Customer Service said the water needed to be luke warm/ room temperature. We even microwaved the water jug for a minute but it didn't work. What did work was filling the reservoir half full of jug water and then adding nearly boiling water until the reservoir was at Max level. I pushed Continue and it began to work. I used a digital thermometer and saw the water temp was 113 degrees. I hope this helps you.
Nov 16, 2014 | Keurig 2.0 K550 Brewing System
How do I santized the fresh water tank in my raptor 365 LEV
You might as well sanitize the whole unit. Fill the carafe half with water, half with "cleaning vinegar." Run several brew cycles, pouring the hot vinegar-water mix back into the reservoir. Then empty the carafe, and fill it with fresh water, and run several brew cycles to rinse out all traces of vinegar.
I suppose you could use white vinegar, but the cleaning vinegar has a higher acidity.
Oct 06, 2014 | Coffee Makers & Espresso Machines
My 12 Cup grind and brew coffee maker needs a good cleaning. How do I do it?
To clean the inside of the coffee maker, fill the reservoir with water as you would to prepare coffee, except add 2 tablespoons of vinegar to the reservoir. Place a clean filter in the basket and run the solution through. When it is complete turn off the unit and let it cool for 2 minutes and then pour the hot solution back into the reservoir for a second run, you can reuse the filter that you placed in it the first time. After it is finished this second time, turn off the unit for 2 minutes and pour the used solution down they kitchen sink. Allow the carafe to cool for a couple of minutes and fill with cold water and run it through as you did the solution, but put a clean filter in this time. Repeat this one more time to remove the vinegar solution and discard the used filters. Once the carafe is cooled fill it about 1/3 full of water, add several ice cubes and 1 tablespoon of baking soda swirl this around in the carafe for a minute or so. Rinse the carafe and run it and the basket through a cycle in the dishwasher or wash by hand with warm soapy water. Rinse thoroughly and you're done. Good luck.
Aug 28, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
If Bunn unit has been stored for a while, how do i clean it and get it ready to use?
Hi, W/D here.
To get your Bunn working again, place a filter into the basket, fill the reservoir, and allow it to begin dispensing into the carafe. This will take several pots of water to get it filled and overflowing (dispensing). Plug it in, and let the reservoir heat up. It's not necessary at this point to have the heating plate turned on, but you can do so if desired to check that it is working, then turn it back off. Once you hear the reservoir heating up, pour in 8 ounces of white vinegar, and let the machine dispense into the carafe. Place an additional 8 ounces of white vinegar into the carafe, and pour back into the reservoir. Let the water heat up again, and let the vinegar solution sit in the reservoir for about 30 minutes. Top off the carafe with cool water and allow the carafe to cool with the warming plate turned off. After the 30 minutes, pour the contents of the carafe back into the reservoir, and it will dispense again. The water in the reservoir will heat up again. Check the coffee filter for residue. If you see a lot of grainy material, change the filter, and repeat the cycle until the filter comes out clean. Save your old filters as you go. Lay them out in order on paper towels, and you'll be able to mark your progress. When the filters clear up, discontinue recycling the vinegar solution and, instead, fill the reservoir with fresh water. The sediment has by now been freed up (de-scaled) and will continue to come off in smaller and smaller quantities. Each time you place fresh water in the machine, the dispensed liquid will smell less and less like vinegar. When no vinegar odor can be detected, you are finished.
Best regards, --W/D--
Apr 06, 2011 | Bunn BT10B Coffee Maker
If I put 6 cups of water in when it is done there is left only 4
The good news is there is nothing wrong with your coffee maker!
With any coffee maker that heats up the water, you're going to lose some of that water to the heating process (steam, etc.). You also don't get every bit of water out of the machine.
So that's why you need to look at the water reservoir level indications instead of using the graduations marked on the glass coffee carafe.
Typically, once you've figured out how you coffee maker works, I'd just "add" 2 more cups of water in the glass coffee carafe to get the amount of cups you want to brew.
I know my coffee maker is pretty close to exactly 2 cups shy of whatever I put in the glass carafe that I pour into my coffee maker. That's when I noticed the markings inside the water reservoir that didn't match the coffee pot. It was always 2 cups shy, so I just put 8 cups of water (using the carafe) to get 6 cups in the morning.
So I suggest you just you make these small adjustments to your water measuring and you'll get the right amount of brewed coffee out of your machine!
Hope you find this Very Helpful and best regards!
Sep 23, 2009 | Cuisinart DCC-1200 Coffee Maker
I can hearing brewing noise, but no water filling the carafe
IF UNIT IT`S MORE THAN 4-5YRS BUY A NEW MODEL, U SAVE SOME MONEY FOR THE NEXT 5YRS
Aug 19, 2009 | Coffee Makers & Espresso Machines
Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Don't understand how it works
This coffee maker has a hot water reservoir that heats and stores hot water so it can brew coffee faster. Once you fill the reservoir by pouring a potful of cold water into the top, you can turn on the switch at the side of the unit and in about 10 minutes the water in the reservoir will be hot. I usually leave this switch turned on to keep the water in the reservoir hot. The front switch turns on the pot warmer at the front of the unit, so it should be turned off unless you are making coffee or keeping a pot warm. To make a fresh pot, put a filter and ground coffee in the removable filter basket, slide the basket into the unit, place an empty carafe on the warming burner and using a separate container pour fresh water into the filler at the top of the unit. The fresh water displaces the hot water in the reservoir and voila, the coffee carafe starts to fill. The amount of fresh water you added is the amount of coffee you will end up with, less a little bit that might have evaporated if you only make coffee every morning or less often. Most units have a plunger under the filler lid that keeps the fresh water from going in to the hot water reservoir until you close the lid, so close it after pouring in the water. Also, turn off the front switch if the carafe is getting low or empty, as it can get hot enough to crack the carafe. If you're not going to be using the coffee maker for several days, turn off the side switch or unplug the unit to save energy and reduce evaporation from the reservoir. I love mine. It makes great coffee and is much quicker than the drip type.
Apr 14, 2009 | Bunn NHB Coffee Maker
Filling coffee resovoir after several days of non use while it has been plugged in
Water typically doesn't go bad in a reservoir, which is a closed container.
That said, if you're worried, run the unit until all of the water is in the carafe and out of the reservoir.
Turn off machine. Dump carafe contents in sink. clean with soap and water. Refill water in machine, place filter and coffee into machine and use as per normal.
Jun 18, 2008 | Bunn BT10B Coffee Maker
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Lyle Siemens
Lyle Siemens
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
