Question about Whirlpool AWOE8748 Front Load Washer
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Whirlpool washing machine model AWO/D 4605
The "Clean Pump" light is on, how do I clean it?
  • 69 Answers
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
The clean water pump is flashing on my whirlpool awo/d4505 washing machine where is the pump and how do i clean it ?
There should be a access panel on the front of the machine at floor level.
This will have a filter which you need to clean. This filter is on the input to the pump.
Feb 03, 2010 | Whirlpool Washing Machines
Whirlpool washing machine say clean pump/ modal awo/d 4605 how do i do that?
Unplug the machine.
Remove the bottom front panel.
The pump will be directly in front of you. Twist and pull and the pump filter will come out.
Jan 07, 2010 | Whirlpool Washing Machines
I have philips whirlpool awo/d 4605 model and its showing a light clean pump where do i find the pump???
The unit front portion either right side or left side you will find the small door you just open the door and remove the filter in anticlockwise direction it will come out just clean the filter and then close it safely
If you want to clean the pump you are suppose to open the back door of the unit and trace the outlet valve it will be connected to the pump after finding the pump just remove the hose from bothe side of the pump and clean the drain pump neatly and refix it
Jan 05, 2010 | Whirlpool Washing Machines
Clean pump light is flashing where is the pump so i can clean it
The pump is located in that bottom compartment under the door. There are two screws that you need to take out located in that tiny little opening and the panel will come right off. The pump is right there in front. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad I could help.
Jan 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Aug 06, 2008 | Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWOE8748 Front Load Washer Logo
4,713 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
