Question about Toshiba Televison & Video
I have a constant reminder on the screen that there is low signal strength and then the picture shows the usual thing that comes up when you change channels. It goes off and almost immediately comes on again, but there is no break up of the picture. Just occasionally the picture does break up but not very often. How do I get rid of this annying writing coming up on the screen. It is driving me mad.
  • colinsweeney May 11, 2010
    Not really. The picture does not break up with my current lead and I already have a booster in line. Checked everything as suggested but no improvement.
  • Toshiba Master
  • 13,433 Answers
Hey
the issue could be a poor connection between the tv and the wallsocket? antenna? what kind of antenna or tv system are you using?
If you are using a long extension cable for the tv antenna, you might need a signal amplifier to compensate for the long path of the cable.
also make sure that all the cables are properly connected at each end, use as short antenna cable as possible.
if you have a indoor antenna, move it around until you receive proper signal.
Posted on May 11, 2010
I cant get clear pictures on my other televisions,am on extra view
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 12, 2016 | Televison & Video
Flashing head message
This signal reminds you to replace the shaving heads of your shaver. New shaving heads guarantee continued optimal shaving performance.
What reminder signal your shaver gives depends on the model. Some shavers beep, while others show a flashing shaving head symbol on the display. Some with red half circle arrows, around the 3 shaving heads, or a flash of the 3 shaving heads. There are also models that beep and show a reminder signal on the display at the same time.
How to reset the reminder signal:
The replacement reminder is repeated at 7 to 10 successive shaves, depending on the model.
In some models, you can reset the razor. Press and hold the On/Off button for approximately 10 seconds.
If the shaving head symbol is shown in combination with an exclamation mark ("!") and a faucet symbol, it means that the shaving heads are blocked. When this happens, you have to clean the shaving heads or replace them. (Note: Only certain models have this feature)
Hope this helps, as mine is doing the same thing now.
Jun 22, 2013 | Philips Norelco 1250x Sensotouch 3d...
My signal strength is really bad on my TVs. Should I buy a new antenna?
The more tvs you have hooked up to the same antenna, the lower the signal strength. Therefore you should get an antenna amplifier or get a new antenna with a stronger signal.
Jan 31, 2013 | Electronics - Others
Cannot change channel on my Dynex DX-L26-10a TV
Try checking the signal strength then run the scan again.
Checking the DTV signal strength
You can check the DTV signal strength to determine if you need to adjust your antenna or digital cable input. The higher the signal strength, the less likely you are to experience picture degradation.To check the DTV signal strength:
1.Press MENU. The on-screen menu opens.
2.Press < or > to highlight Channel, then press v. The Channel menu opens. The DTV signal strength is shown at the bottom of the menu.
3.Press EXIT to close the menu.
Oct 26, 2012 | Dell Vostro 200 PC Desktop
Wireless Network Connection constantly reading low/vlow/no signal
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 04, 2010 | Computers & Internet
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
WS-65807 picture goes black when using HiDef Signal
Tank, If the unit operates correctly on DVD then we can assume that the signal chain and display is operational. Can you substitute the Directv receiver to rule the box out as part of the problem? I know they came out and checked but how exhausting was the testing? Have you checked signal strength on the directv on screen setup? Low or marginal signal strength could cause intermittent blanking. When the screen goes dark does the audio continue? please let us know..
Jun 11, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
