Question about Pioneer AVH-P6500DVD Car DVD Player
The screen has become very dull so it is not possible to see any menus or maps or images on it. Please advise the likely cause or how this can be remedied.
    Problem Solver:
  • 13 Answers
The bulbs inside screen are doing out send in to have replaced
Posted on May 12, 2010
I have a PTV916 Model # 60P8341A. I cleaned the lenses and the mirror inside the TV however, I can see alot of dust inside the actual lens. Is it possible to clean the inside of the lenses?
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Philips 50P8341 50" Rear Projection...
My garmin nuvi 1300 keeps saying "no map data available" I'm a truck driver and really need assistance asap..
There's a solution to your problem at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
The article deals with all possible reasons for there being no map data available but if your satnav is working other than that it may be just that the map is not selected. If you can get into the menus first try selecting the map by
pressing TOOLS
then SETTINGS or LOCALE on models that don't have a settings menu
Press MAP and then at the bottom of the screen press MAP INFO
Your map name should be there and a box with a tick beside the name.
If the box is not ticked press on the map name and it will cause the tick to appear. This might solve the problem. If not the map is probably locked. You'll find details of how to unlock the map at the above link.
Jan 06, 2011 | Garmin nuvi 1300 Car GPS Receiver
Double images, especially with red.
hi.
double image is caused by a faulty convergence circuitry. It needs repair, if you have a basic knowledge in electronics you can do it, just replace it with the new convergence kit.
Nov 22, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My tv is showing alot of red with blue blotches across the screan
Your TV most likely has fone of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 20, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Yellow tints on screen and color is faded.......
Jan 22, 2009 | Philips 55PW9363 55" Rear Projection...
Tv has a dinge look to the picture
Dec 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
White objects (especially text) on a black background produce a white halo effect around the white lettering. When playing a PS3 game I noticed that the blue color appeared black, as though I had no blue...
Aug 27, 2008 | Philips 9P6040C 60" Rear Projection...
I have a Phillips maganavox Projection TV I believe it is model 9P6040CI and the color is dull and I believe the red is going or gone. I've tried to tune it but will not let me
May 02, 2008 | Philips 9P6040C 60" Rear Projection...
Color problem after warm up.
The probelm is caused by either a bad color wheel sensor, color wheel or formatter board. I have the new redesigned sensor assembly and color wheels that I can sell. It is best if you send me the projector for proper diagnosis.
Apr 30, 2008 | HP vp6320 Multimedia Projector
Acer aspire 3680 MONITOR backlighting problem.
its u r laptop lcd problem.so please replace u r lcd
Jan 11, 2008 | Acer Aspire 3680 Laptop
Pioneer AVH-P6500DVD Car DVD Player Logo
79 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
