Question about HP Compaq nc6320 Notebook
HP Compaq nc6320 pc notebook issue
I am having similiar problem as was in the thread for the issue of been locked out of my HP Compaq nc6320 pc, The unit powers on no problem, but is not accepting my username and password, if I purchase a new hard drive and upload it will this solve the access issue?
The notebook powers on fine and then you come to the Windows XP Professional, Welcome to Windows and it requests, 'Press Ctrl-Alt-Delete to begin' which I do and then I come to which it then requests me to Log On to Windows, the username and password is not working with the details I entered and I unfortunatly puchased this second hand thinking I was getting a good deal. I would greatly appreciate your feedback on this.
  • 655 Answers
Paddy it seems windows login problem, may be you are not using correct user name or/and password or may be your password profile got currupted.
Anyway in your case as you have purchased it second hand, then you don't had have any specific program or file on the hard disk. So you can easily format your lap and installed new XP or Vista as per your requirement. It will solve your problem. But you should must have the device drivers to work and installed properly.
Yes if you will use new hard drive then you can install, but same things will be required as per above. So I will recommend you to install on same HDD don't buy new one.
If any problem, Just Ask me
Thanks
Iqbal
Posted on Mar 29, 2008
  • 3 more comments
  • Iqbal Husain
    Iqbal Husain Mar 30, 2008
    Re-installing the windows will fix your problem.
    Before re-install check out that you have all device drivers.
    If you are going to install windows XP please disable the SATA interface in your BIOS otherwise XP will not detect your hard disk and 'No Hard Disk Present' error message will be raised.
    If any problem occurs. Just Ask me.
    Thanks
    Iqbal
  • Iqbal Husain
    paddy re-install windows, it will fix your problem.
    If you have any problem during installation, just ask me.
    Thanks
    Iqbal
  • Iqbal Husain
    Paddy you should re-install windows xp.
    Before installation, please check your BIOS if there is SATA enabled, make it disabled. Then try to install.
    If any problem occurs, just Ask me.
    Good Luck
    iqbal
  • Iqbal Husain
    paddy try to re-install your OS
    if any problem occurs, just Ask me
    thanks
    iqbal
  • Iqbal Husain
    Iqbal Husain Mar 31, 2008
    paddy as its a second hand, i don't think you need any software or data stored on it. If so, then i will recommend you to install a new and fresh OS on it of your hoice. To install OS you must have the Setup CD for XP Pro or Vista. (I prefer XP)
    Just boot from Setup CD and follow the on screen instructions.
    If still have problem, just Ask me..........n..:))
    Thanks
    Iqbal
  • 520 Answers
You maybe able to disable it in bios then at screen click cancel.
if not you can reset bios and all passwords by removing rtc battery located underneath keyboard.
if you need a service repair manual showing disassembly for ur model I can post u one
Posted on Mar 30, 2008
2 Suggested Answers
SOURCE:
  • 44 Answers
SOURCE: HP Compaq nc6320 pc notebook issue
it seems that its a not a problem with your hard disk at it load on to the windows succesfully. Chances are any one of these :-
1. Some one might have changed the user name or password.
2. The file that holds the password might be corrupted.
3.If you are using a network based login, ask your administrator for assistance.
The better solution is to Repair install or Re-Install the operating system...
( U might Lose your Data while doing it but not all the time)
Posted on Mar 28, 2008
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Hp compaq nc6320 no power
Have it checked in service. It seems to be motherboard problem
Jan 07, 2013 | HP Compaq nc6320 Notebook
Does an HP Compaq nc6320 have an keyboard lock button?
HI there,
No,Y do you want lock it?
Any specific reason?
Just lock your Laptop.
Post back for more solutions we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 10, 2011 | HP Compaq nc6320 Notebook
Power failer
You need to check the voltage on the power adapter. If it checks out, you will need to call HP because this is an issue that is typically caused by power surge and motherboard replacement is usually the solution.
Jul 15, 2009 | HP 413670-001 - HP Compaq nc6320, nx6310,...
HP Compaq nc6320 PC Notebook Problem
Try unplugging internal battery for a minute or two it worked for me.
Sep 01, 2008 | HP Compaq nc6320 Notebook
Describe your HP Compaq nc6320 PC Notebook Problem
i have a Compaq nc6320 when i plug in the power cord the electricity led doesn't want to turn on i have changed the cords and the adapters and i doesn't power on or even charge the battery, did any one have an idea what to do in this problem?
Mar 31, 2008 | HP Compaq nc6320 Notebook
Mar 28, 2008 | HP Compaq nc6320 Notebook
Compaq - will not turn on - plugged in?
Disconnect the AC adaptor, Take the battery out and press and hold the power button about 5 seconds. After that connect the AC adaptor and insert the battery turn it on. If issue persist please inform for further troubleshooting.
Good Luck
Mar 01, 2008 | HP Compaq nc6320 Notebook
HP Compaq nc6320 Boot Disk
in case you can get a non boot disk , u can install it by using a start up floppy disk for win9x
Nov 15, 2007 | HP Compaq nc6320 Notebook
HP Compaq nc6320 Notebook Logo
616 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
