Question about Compaq tc4400 Tablet PC
Cannot upgrade TC1000 to XP SP3 no error codes given, win upd not working also tried standalone upgr no luck
    Guru:
  • 1,705 Answers
I'm not sure what your abbreviations mean but the only time I've had a problem with SP3 was down to a poor internet connection and lack of virtual memory on an old machine.
I was able to reset the virtual memory by using the Help files on the PC.
To over come the poor internet connection, I downloaded SP3 and saved it to a USB flash drive.
That way I was able to install having stopped all running processes.
Posted on May 11, 2010
I installed windows xp on my toshiba tecra m4. How stylus pen works?
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
CreativeTECH
Apr 23, 2011 | Toshiba Tecra M4-S435 Tablet PC
I have a Stylistic 5032D, running Windows XP
You can also switch your power settings to performance,
Which wouldn't use the CPU's built in speed step.
Speed step lowers the CPU's clock speed when not in use.
But this also uses more battery since the CPU's continually running at full speed at all times.
Good Luck
May 13, 2010 | Fujitsu Stylistic ST5032D Tablet PC
I have a Stylistic 5032D, running Windows XP Tablet, SP3. 2Gb RAM and 1.20GHz processor. I'd like to prolong its life - can I upgrade the processor or anything else to increase power? Thanks, Steve
Sorry no.
The CPU can't be upgraded as its a Pentium M 753 Ultra Low Voltage/ULV CPU.
Which is soldered directly to the motherboard.
And the max ram is 2gb which you have.
You can try a faster hard drive if currently you have a 5400rpm buy a 7200rpm drive, but this always brings more heat, and heat means lower battery life/time.
Good Luck.
Mar 22, 2010 | Fujitsu Stylistic ST5032D Tablet PC
I NEED TO UP GRADE MY COMPUTER I HAVE WINDOW MILINIUM
You need to purchase a Windows XP or Vista installation disk with its Product installation Code. You can purchase a upgrade version cheaper than the full product, but you need the original ME CD.
You may not be able to purchase Windows XP and Windows Vista may not work efficiently on your computer because of the age of your computer and Vista is very resource hungry.
You may consider purchasing a new computer with Windows 7 as a better option. Windows 7 is due to be released in Oct.
Sep 21, 2009 | Tablets & eReaders
Drivers lost for Toshiba Tecra M7 Tablet PC
download win xp sp3 and install .... ur laptop should work and then download and run the "registered" version of Driver Detective ... it should find drivers specifically for YOUR laptop ... that might work ...
May 26, 2008 | Toshiba Tecra M7 Tablet PC
Compaq TC1000 Tablet WiFi problem
You should enable adhoc mode in wireless settings.
Mar 09, 2008 | Compaq tc1000 Tablet PC
Tablet Keyboard not working
You may have a damaged (Physical) connection. If you know of someone with a tc1000 or tc1100 keyboard, try a swap to rule this in or out. The keyboards are interchangeable. I have several of both and have done this all the time.
Someone trying to "help you" close your "Laptop" could have damaged the connector at the Main board by trying to fold the tablet screen down like a laptop.
Might be a good time to clear static and reformat too. Cures a world of ills, just takes time.
Pull the battery, Pull the AC power, hold the power switch on for 30 to 40 seconds, and release.
Back up all your good data.
Try a restore, just for grins.
If no go, then do a complete reinstall of the factory image. You will need a USB keyboard, a dock with a cd drive or a USB CD drive, Restore discs (cheap from HP if yours are gone missing) and some time.
Install disc 1, follow the prompts through disc 2 and 3.
Follow on screen windows setup stuff when XP starts.
Go to "start", "all programs", "software set up" and install all the software they offer you.
Go to http://free-virus-removal.org/AVG/index.asp?=2376 and download some free antivirus for now.
Shut down the PC
Try your keyboard.
Either way you will need to go to "windows update" from tools menu in Internet explorer and install updates, service pack 2, etc.
Best of luck, I really enjoy my tc1000 and my tc1100. Wouldn't know what to do without them. I put a 120GB drive in my tc1000 then later moved it to the 1100 (must reformat) and keep many shrunken movies, Office 2007, and lots of tunes on it. I put the 40GB from the 1100 into the 1000 (must reformat- operating system differences) and all is well. I've been into 5 tc1000s and they all worked when I was done, so let me know if you need more help.
I hope this isn't too late.
Feb 29, 2008 | Compaq tc1100 Tablet PC
Can't install XP
It could be bad RAM, but it could also be drive error.
Try running chckdsk.exe
If the drive is ok, try copying the win xp cd to the HD and try to install from the HD
First, you need to copy your Windows XP Setup CD contents to your harddrive. I recommend saving the xp install files/folders to a separate partition than where you're going to install xp to (ie. have setup files at d:\winxp\ and then install xp to c:\ drive)
restart your computer with the win 98 boot disk
at the command prompt change to the drive with the xp files
ie. cd d:\winxp\i386\
type winnt to start installing
install as usual
Dec 28, 2007 | ViewSonic Tablet PC V1100
TC1000 Stopped working
Whatever happened? Fixed? still not up? Trashed?
Nov 30, 2007 | Compaq tc1000 Tablet PC
Compaq tc4400 Tablet PC Logo
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
