This is a Hotpoint Aquarius WM62P washing machine. Last week, grease stains from the machine was found on some washed sheets. Since then, on spin the drum makes a pneumatic hammering sound. I have removed the top and found nothing adrift, but when the drum is turned there is someting loose between the cylinder and drum casing.
My hotpoint washing machine WF620, squeeks when it is washing and spinning
On most hotpoint wash machines you cant replace or grease the bearing you have to replace the whole drum which cost around 100 pounds from hotpoint and a couple of hours labour its a common problem on hotpoint machines.
hope this helps.
puggy
Jan 07, 2014 | Hotpoint Aquarius WD63 Front Load...
What is thebest tepmerature for white garments
Set your water temperature to "cold" on your clothes washer. Unless your clothes have oil or grease stains, cold water is usually adequate to clean white and colored clothes. In fact, washing clothes in cold water allows fabrics to retain their color and strength longer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 17, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi. i have had funny noises during last couple of washes. now washer wont drain programs are responding fine but washer keeps filling up and not draining.water backed up and came out of the drawer hotpoint...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WM62P will not operate.
yes.......could be the interlock.....
cheap part to try first..
cheers
Aug 03, 2017 | Electrolux Washing Machines
I have had aqarius a hotpoint aqarius 1000 wm62p
It has a wide variety of wash programmes for white cotton, colourfast cotton, polyester, non-colourfast cotton, wool blends and wool itself. These standard programmes take from an hour and a quarter to three-quarters of an hour to complete.
There is also a quick wash programme lasting just under half an hour for lightly soiled items and a pre wash soak for heavily soiled items. The machine has four buttons providing extra facilities that can be set independently of the main wash programmes to give you a more comprehensive range of settings.
There is a rinse hold button, which I find extremely useful. When set this holds the clothes in the final rinse water until you are ready to unload the machine. You then release the button, let the machine go through the final spin and then you can unload the machine. It means that you don’t leave damp washing in the machine for the time between the cycle finishing and you unloading the machine, which would make for very creased clothes. There is also a button to depress if you want to use the super rinse facility. This merely increases the volume of water in each rinse so that the clothes are rinsed more fully. I have never used this particular facility, as the ordinary rinses are fine for my needs.
The next button allows for a slow spin. I find that this one is really useful for the items that I need to iron as it means that they don’t come out of the washing machine as creased as they normally would on a faster spin. The only problem with this is of course that the clothes are not as dry as they would otherwise have been. The final button is used to set the economy wash feature. This means that the washing machine’s own heating system is not used and the wash is done with the water at the temperature entering the machine from your hot and cold water tanks. This of course means a cooler wash so it’s only suitable for lightly soiled items.
The door remains locked during the wash programmes so that it cannot be opened accidentally and it can be locked when not in use too if you have small children who might get into mischief! The other big selling point for this particular model is that it gauges the size of the load and uses the correct amount of water needed eliminating the need for the half-wash programme. This also means that it is both water and energy efficient
Mar 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
My washing machine has stopped spinning, for the last 4-5 washes it made quite a bit of noise when spinning the load and now it has stopped spinning completely. It makes the noise as if the motor is...
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Dec 31, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Brown staining of clothes,increased noise on spin cycle
that brown sludge is grease from the bearings and the noise is the bearings breaking up stop using the machine and get them replaced 2 supply and fit new bearings and drum support should nt cost more than £90 good luck not realy a job 4 a novice
Aug 06, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
