Question about Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio
It wont pick up any channels. only one channel gets static and thats it.
  • Uniden Master
  • 12,061 Answers
Http://www.retrevo.com/support/Uniden-PC68XL-2-way-Radios-manual/id/471dj697/t/2/
manual above. You MUST always check your antenna and antenna connection, this is the most common cause of no reception. If you are sure your antenna is OK, you should test it on another Know Good Antenna system, and if still no go. Them you need to get this unit looked at by a professional. You should contact Uniden, local or head office and ask for a referral to an authorised service agent. You can then always ask for a"Quote" for repair. I doubt that it would be too expensive, a repair if faulty, as there is not too much that goes wrong in these units.
Posted on May 11, 2010
Tv picking up channels except its all static, colorless, and loud static noise..
If the set was purchased in the USA it has the USA format which is NTSC--unless the signal is NTSC picture will be in black and white and no sound.
If the signal format there is PAL OR SECAM you will need a converter that takes that and outputs NTSC for the set to work properly there.
May 16, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
Uniden 30 ch scanner i have locked out all channels.
Each channel with the zeroes means that it is a blank - with nothing programmed into it. Going to any one of them and programming a frequency will get rid of the zeroes and switch off the lockout. It's picking up weather, so it's working. Sounds like you just need to find and program active frequencies for your area, and the place to find them is:
www.RadioReference.com
If you need it, you can download and print the manual for the BC60XLT-1 here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
I am positioned on a designated fm station and my sirius radio has allot of static
the problem with the static is that radio station you have it set to is picking up a signal on FM. it could be a dead channel in one location and it could be a live station a town or so away. try another pre set station. i tend to use 89.1 it is a dead channel in many areas around me. it could be a live station near you.
Dec 17, 2009 | Audio Players & Recorders
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Behringer xenyx 802 static in left output
if its only on left channel you have to change the ic output from that channel.
Jul 08, 2009 | Audio Players & Recorders
How to update digital channels correctly
the information I needed was in the FAQ's area. Thanks
Jun 05, 2009 | Sansui 19 in. LCD TV
Will not show anything but static
Make sure the TV tuning mode is set for "cable". This will be somewhere in the TV's setup menus; check your manual for all the details. If it's set for "air" as I suspect it is, only the first 13 channels will be found when connected to cable. Channels 14 and up don't get tuned in on "air". Once you've set the TV for cable, rescan channels and you should have 'em all.
Thanks for asking here. If this solution has been what you needed, please take a moment to rate it!
Mar 13, 2009 | Insignia IS-LCDTV32 32 in. Television
Uniden Bearcat BC60XLT 10 Channel 10 Band Radio Scanner with L/O on every channel #
http://www.uniden.com/pdf/BC860XLTom.pdf
Here is the link for your scanner manual. In it you will find everything you need to change the lock out and also to inpout channels and what not
Feb 10, 2009 | Computers & Internet
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio Logo
293 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
