Question about Technics SL-PG3 CD Player
I have a Techinics SL-PG3 CD Player connected to a amplifer & speakers. I would like to connect the cd player direct to my tv instead to play cd's and to listen to the cd on my tv is this possible ?
    Brigadier General:
  • 3,006 Answers
Generally, on most modern tv's the answer is yes. if you're connecting via an A/V amplifier then no problem at all but you stated that you're after a direct to tv connection.
But the answer depends entirely on the make and model of tv and whether it has standard left and right phono inputs. If it only has Scart sockets (UK/Europe only) then there are adapters which will do the job.
As you haven't given any details at all about your tv I cannot give you any more specific details.
Posted on May 11, 2010
How do I connect a cd player to both a tv and an audio amplifier so Ican play either Cd's or DVDs?
Does the TV have a line audio outpot (red and white jack)? If so feed the amplifier input from there.
Dec 23, 2012 | NAD C372 Amplifier
I got a mtx jackhammer 2400 watt amp. when i hooked it all up and turned it on i am just getting 12 volt on the speaker output wires and no sound. it is just compressing the speakers and that is it. any...
verify your amps input. hook up a portable cd player with a headphone to rca "y" adapter to the amp and try that, to make sure it isnt an issue with the reciever/cd deck oir the input circuit. if the amp works correctly with the protable cd player/ walkman.mp3 player whatever, instead of the car deck, then something is wrong with your decks audio output. if it does not work with a secondary input device then perhaps you have the power hooked wrong. there should be both a red and yellow power lead from the amp, the red should be connected directly to the battery, and the yellow to the "acc on" (any circuit that turns on only when the car or stereo is turned on, sometimes connected directly to the stereo). both can be connected directly to the battery, but the yellow would need a switch, in that case, to turn the amp off when not in use.
Mar 09, 2011 | Car Audio & Video
SUV500 2-Channel Amplifier: Hi! can I connect another technics cd-player,sl...
yes you can connect another cd player to the DAT input of your amp.
input connections like DAT, TUNER, CD, AUX etc (except phono) is just to differentiate between what sources are connected, the amp cannot tell what source is connected and will output the sound no problem.
as for the remote operation, if the 2 technics cd players are switched on at the same time they're going to do what you command from the remote together but you'll obviously be listening to 1 at a time.
May 17, 2010 | Technics SUV500 2-Channel Amplifier
Just wondered if i can connect my speakers straight to cd player or do i need to go through an amp Thanks
Component CD players like yours must be used with an amplifier. Their output is called "line level" and isn't beefy enough to drive speakers directly. An amplifier is needed to boost those line level signals to speaker level. The same is true for other components like tape decks, DVD players and so on. A CD player may have a headphone output jack, though, since headphones don't require the same power levels as speakers. So you could use the player by itself for headphone listening.
Hope this has cleared the air for you. Thanks for using Fixya!
Feb 10, 2010 | Teac CD-P1160 CD Player
I have a Pioneer DEH-p4800mp and I connected to amplifier when i stop the cd player does not stop the amplificator
Question? have you also connected the Remote cable from the CD player to the Amp? or have you only got 12v & gnd hooked into the amp? if so then the amp will be on all the time. the remote goes from the CD player to the amp, usually a blue cable from the back of the head unit.
Jan 12, 2010 | Pioneer DEH-P4800MP CD Player
Connecting to speakers
There is no built-in amplifier on your cd-player so you cannot connect speakers directly to the CD player unless they are self-powered(like the speakers for a computer) so you will need to connect the red and white rca jacks to the television's audio input jacks, an external stereo reciever, or self-powered speakers to get sound from the cd player.
Dec 21, 2009 | Symphonic CD5800 CD Player
Is there a way of connecting my ipod to my sherwood cd player?
The answer isn't with the CD player, it's with the amp.
Does the amp have selectable inputs, or does it just have one input for each channel?
If it's a simple power amp, then you'll have to unplug the CD player and connect your iPod to the amp inputs. I'm guessing that the CD player connects to the amp with RCA (phono) connectors like these ones.
If that's the case, you can get a cable (like this one at Radio Shack, but any office supply store will have one too) to connect your iPod to the amp.
Jul 31, 2009 | Sherwood CDC-5090R 5-Disc CD Changer
Cd player dosen't play with amp
hmmm...what cd player are you using?..
May 03, 2008 | Kenwood KDC-MP828 CD Player
Volume Control??
Unlike low-end hi-fi systems where you buy one box that does everything, the CD player you have is part of a component hi-fi system (i.e. you buy your CD player, tuner, amplifer etc. as separate items.) This is why there is no volume control. It needs to be connected to an amplifer. It's on the amp that you will find the volume control and where you connect the speakers. (When you connect it to your television, you are just using that amp in the TV instead.)
The CD player did originally ship with a remote control, but I don't know where you would be able to buy one on its own. You may find the the remote does allow you to alter the output level of the CD player, but you still need to connect it to a proper amp to get it to work.
Hope this helps,
Matt
Mar 27, 2008 | Technics SL-PD887 5-Disc CD Changer
Technics SL-PG3 CD Player Logo
120 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
