Question about Garden
I am trying to remove the cutter drive pulley from my greenfield ride on mower (will not move) tried puller with heat any ideas.
Hello Mate, I know its been awhile since you posted but the deck pulley has a left hand thread. hope this helps.
Posted on Aug 30, 2010
How to remove drive pulley from crankshaft
there if a bolt in the hole underneath the pulley put a socket on it and turn counter clockwise. if the pulley is stuck on the crank. you can heat up the center and use a wheel puller and hammer to pop it loose.
Jul 29, 2016 | Garden
Remove deck pulley from greenfield ride on
Most of these are pressed on in the factory. A gear puller should work,
Mar 13, 2014 | Mtd Garden
Have a Greenfield Evolution 2000 mower , the forward drive clutch is slipping badly on hills is ok on the flat, what is required to fix this problem. Can the clutch pads be replaced or are complete clutch...
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Oct 31, 2010 | Garden
Removing pulleys from riding mower
most of the time they can be removed with a little heat from a torch, i use a pnuematic air hammer aswell, the vibrations help loosen rust and corrosion.....if that dont work break out the 3 jawed puller....becarefull not to damage the pulley when using a puller. hope this helps and good luck
Nov 21, 2009 | Garden
We mow 2 acres with a Greenfield ride-on. Sometimes have to cut long grass by slipping the clutch to get slow forward speed. Problem is that the clutch system occasionally locks into forward or (worse...
Hi i have seen this with most greenfield models The only way to fix this problem is to replace the drive clutch assy as it ends up to costly to replace the worn parts : shaft,clutch plates & drive pulleys.
In most cases replacing these parts has led to a new assy six months later.
Mark.
Jul 18, 2009 | Garden
Can't get drive pulley off engine shaft? pullers not working, just deforming the pulley
several things did u check thoroughly for any set screws if no then heat pulley with propane torch (no shaft) when it is good and hot try pulling it then. when u heat metal expands and hole get a little bigger and u can get off , clean with wire brush and heat if needed to reinstall pulley, though if bent very much u need to straighten or replace
Jul 09, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Lawn tractor engine replacement
some pulley have grub screws on side as well as main bolt on bottom .sometimes heat is needed on pulley to make it expand
Nov 02, 2008 | Garden
Garden Logo
546 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
