Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
I need to know spark plug wiring - 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
    President:
  • 676 Answers
I have added an image that may help you.
Posted on May 12, 2010
What do I need to do to change spark plugs and wires on 1997 mountaineer
Spark plug wires just pull off and press back on. Make sure you grasp the wires by the rubber boot only. If you pull the wires by the wires, instead of using the boot, you can break the wires. Remove the plugs with a 3/8" ratchet, extension and a spark plug socket. I do not know if you have to remove anything to get access to the spark plugs and spark plug wires. You may need a universal joint to angle the ratchet.
May 15, 2014 | 1997 Mercury Mountaineer
How to change the spark plugs and wires
First you need to research your Make and Model vehicle and determine your spark plug size (5/8 or or larger) typically there are only 3 sizes but you'll need to know which as you will have to buy the Spark plug socket to remove them. Next you need to locate a online diagram or Haynes Manual to see if you yourself can reach or change the plugs and wires as some cars are built in such a way that only a Technician would know how to reach them properly. 3rd you will need to determine if the OEM wires (Original Equipment Manuafacturer) part is available (cheaper) or if you will have to buy a aftermarket set (Bosch or ACCEL). Removing plugs will require a Socket wrench, spark plug socket and extension. when putting in new plugs make sure you use Anti-sieze on the thread of the new plugs before installation (keeps from locking up into the head) also make sure you use Plug wire boot lubrication before putting in new wires (this helps make sure that future plug replacement is easy as it will help the boot slide on and off. That's it without knowing your exact make and model.
Feb 09, 2013 | 1996 Plymouth Voyager
Need to know where the spark plug wires go on the coil pack
WHAT SIZE ENGINE 2.4L 3.4L OR 3.1L NEED TO KNOW. BECAUSE EACH ENGINE SPARK PLUG WIRE FROM IGNITION COIL TO SPARK PLUGS TO THE ENGINE PLUGS GOING TO BE IN DIFFERENT SEQUENCES.
Aug 04, 2011 | 1999 Oldsmobile Alero
How do you properly replace spark plugs in a 96 dodge stratus?
pull off plug grabbing it as close to spark plug as you can. Using socket rotate counterclockwise and remove plug. Be careful putting plugs back in and thread by hand first. Then torque as plug box says as it depends on if you have a washer or not.
Dec 22, 2010 | 1996 Dodge Stratus
Do not know where to connect hour meter wire to the spark plug
One wire is the flexible silicone rubber wire from the spark plug to the ignition coil. You don't have to strip or connect the other wire, just wrap it around the spark plug wire a few turns.The current from the spark ignition will induce a signal into the hour meter that the meter uses to determine when the motor is on or off. I hope this helps and good luck.1b05a64.jpg
Oct 28, 2009 | 2006 kawasaki KX 250 F
Need to know correct wiring of the 8 spark plug wires
first you need to figure out which one is number 1. the firing order is counterclockwise 15426378
Sep 20, 2009 | 1997 Chevrolet Cavalier
Need to know where spark plugs are located in order to change
Follow the spark plug wires down into the engine, a soft tug should pull the wire loose from the plug and then you will need a spark plug socket to change them.
May 18, 2009 | 1999 Chevrolet Tracker
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
42 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
