Question about Kodak EasyShare M863 Digital Camera
When i turn my camera on its says memory card needs formatting but i have done this and it continues to say it
    President:
  • 2,976 Answers
Depending on the age and use of the card, it's worn out. They only have a limited life and each time you erase or format, you shorten it.
Posted on May 11, 2010
I keep getting a message that my memory card needs formatting. My internal memory is full. I have a Lexar multi-use 4GB SDHC card. I have no idea how to format it. I have tried everything in the...
Hello,you are on the safer side,all you need to do is just to visit the settings on your camera and go to memory card manager to format the memory card,if that is done you can now transfer datas into the memory card,but if the problem persist after then,i would suspect the memory card is corrupt,and if that arises,you will have to get another memory card to ease your stress and allow you enjoy the service of your digital camera as supposed.
wish you good luck,
Take care.
Dec 02, 2010 | Cameras
Can't get to set up menu with my new memory card in camera to set it up to use the memory card instead of the internal memory. Camera keeps saying memory card needs formatted-continue or cancel-I go to...
1. with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
2. insert the card and do the "format" thing again from the menu as you just did for the internal memory.
Sep 24, 2010 | Kodak EasyShare C743 Digital Camera
Will sdhc memory card work in my z700?it comes up card needs fomatting i press continue nothing happens
Sorry, I hate these questions because there's a yes and no answer. All brands of SD memory will work in your camera but when it comes to SDHC (High Capacity) some brands simply won't work whilst others do a great job. I can't say which ones don't but it's dependent on ther type of chip in the card.
Whatever you do, don't try to format the card on your computer it should always be done on your camera which you say you did, well done. But the fact it's not formatting is either due to the card being incompatible or damaged. Can you try it in a card reader on your computer to see if it will let you save data to it or download data from it? The memory cards are somewhat robust but simply turning your camera off whilst the card is being accessed can destroy the card completely.
My advice would be try the memory in another camera to see if it will format or try another card in your camera. Are you sure you are taking the correct steps in the camera format routine?
I wish you luck and hopefully a good format
Apr 20, 2010 | Kodak EasyShare Z700 Digital Camera
Won't turn turn on. A red and green light comes on, but nothing on the screen.
Step one: Reset the camera
  1. If you have an optional memory card installed, remove it.
    NOTE: Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.
  2. Remove all batteries from the camera for at least five seconds.
  3. Reinsert the batteries and close the Battery/Memory card door.
  4. After verifying that the camera works without an optional memory card, reinsert the card if you removed one in Step 2.
Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
  • If the is not resolved , continue with the next step.
Step two: Check for damage or corrosion on the batteries
  1. Open the Battery/Memory card door on the camera.
  2. Remove the batteries.
  3. If the batteries are damaged or show corrosion, replace the batteries.
Step three: Recharge the batteries
  1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
  2. Try turning the camera on after the batteries are fully charged or have been replaced.
Step five: Ensure the batteries are installed correctly
  1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
  2. Try turning the camera on.
Step six: Turn on the camera without the memory card
  2. Remove the batteries and optional memory card from the camera.
  3. Wait 15 seconds.
  4. Re-insert the batteries into the camera, but not the memory card.
  5. Try turning the camera on.
    • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
    WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
Step seven: Service the camera If the camera still will not turn on, service the camera.
Mar 04, 2010 | HP Photosmart E327 Digital Camera
Why My kodak dc280 can not read the memory card?
Try formatting your camera memory card If you own camera memory cards that have been used in other digital cameras, the card may not be properly formatted for use in your camera, or that data on the card may become corrupted. When these issues arise, your camera indicates that the camera memory card needs to be formatted.
When you format a camera memory card, all of the information on the card is erased. This includes any borders supplied on the card.
  1. Set the Mode dial to Camera Setup.
  2. Slide the POWER switch to the right to turn on the camera. The main Camera Setup screen appears.
  3. Press a updown_icon.gif button until the format_icon.gif icon is highlighted. format.gif
  4. Press the DO-IT button. The Format Memory Card screen appears.
  5. Press a updown_icon.gif button until CONTINUE FORMAT is highlighted.
  6. Press the DO-IT button to format the camera memory card and return to the main Camera Setup screen.
Dec 10, 2009 | Kodak DC280 Zoom Digital Camera
How did my pictures get deleted by formatting the card?
when you format something it deletes everything leaving it how it came from the factory, it's possible that you had corrupted files and the camera advised to format, next time cancel
Aug 04, 2009 | Sanyo VPC-E760 Digital Camera
Camera wont turn on
  1. Step one: Reset the camera
    1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
    2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
    3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
    4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
    Step four: Ensure the batteries are installed correctly
    Step five: Turn on the camera without the memory card
    3. Wait 15 seconds.
    Step six: Connect the camera to the optional AC power supply
    1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
    Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
    • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
    • Corrupt images on the memory card
    • More than 300 pictures on a memory card
    • Damaged batteries
    • Dead batteries
    • Incorrectly installed batteries
    • Damaged camera
Jul 19, 2009 | Leica C-Lux 1 Digital Camera
When i turn the camera on....it saids memory card requires formatting. then continues to say formatting will delete everything on memory card. i press continue and nothing happens. goes back to say memory...
Use a computer with memory card reader, and read the card using a computer.
If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
If you need to use the camera tonight, then buy a spare memory card.
If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
Regards
Jun 18, 2009 | Kodak EasyShare C875 Digital Camera
My Kodak EasyShare C315 needs formatting.
For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
Tami
Dec 27, 2008 | Holga Flash, 120 Medium Format Camera...
Memory card
this cam will work up to 2gb sd/mmc
what's the capacity of your card? if it's above that, it's really not gonna work with this cam
if your card is 2gb or lower
2 possibilities:
defective card - please try another card
camera memory reading problem - arrange repairs with kodak
Jan 20, 2008 | Kodak EasyShare C663 Digital Camera
Kodak EasyShare M863 Digital Camera Logo
52 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
