Question about Pure Digital Flip Video Ultra Camcorder
Low battery indicator? - Pure Digital Flip Video Ultra Camcorder
Cobra Mirco Talk CXT 195
pls check usb cable , replace with new gud quality short length usb cable n try to connect the same in back side USB port not front side ..
Jan 15, 2014 | Cobra Radio Communications
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Aug 21, 2017 | Health & Beauty
Package, manuel and receipt were accidentally thrown away and we don't know how to charge the radios. They work, but are running low on battery power! They have a power supply cord that you plug both...
From what I just read on the Cobra website, you may be misinterpreting the battery indicator lights:
My radio keeps showing low batteries
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Here is a link to the Manual for your radio:
https://www.cobra.com/downloads/manuals/PR260WX_MANL.pdf
It is a PDF file, which requires that you have Adobe Reader or equivalent installed on your computer for it to open and display properly. If you don't have it, it can be found here (it's free!):
http://get.adobe.com/reader/
Jul 16, 2011 | Cobra microTALK PR 260-2 WX Two Way Radio
I have the cobra CXT275 they have been on the desktop charger for 5 days. They won't charge over a 1/4 of the way how do I get the maximum charge?
Jan 12, 2011 | Cobra Two Way Radio
What does TX in a battery symbol mean?
For Models 88900/901 TX in a battery symbol is the Low battery indicator (Sensor)
RX in a battery symbol is Low battery indicator (atomic clock)
Source: Page 4 of the manual.
Jun 16, 2010 | SkyScan 86709 Atomic Wall Clock
How to set up show battery on nikon cameras s220
The camera will show a low-battery indicator when the batteries start to run down. The only indication of a full charge is the lack of the low-battery indicator on the screen. There is nothing you can set up.
Jan 31, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Low battery indicator with new batteries
Dear friend please go in setting option on your camera and select your battery type there. after that restart your camera. The indicator will stop showing low battery. But also confirm that your new battery are fully charged. Waiting for your feedback.
Jan 30, 2010 | Pentax *ist DL Digital Camera
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jun 17, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Pure Digital Flip Video Ultra Camcorder Logo
178 people viewed this question
Top Pure Digital Video Cameras Experts
Rommel Balcita
Ron Dufek
Ron Dufek
sharky633
sharky633
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
