Question about Cooktops
Electronic ignition button on gas hob won't depress. Can light burners with match. Problem appeared overnight - one day it worked, the next it didn't. Did the ''wreck-it fairy'' visit overnight?
Have you checked whether the main power switch is turned on? If power is off, the ignition will not work.
Posted on Jun 08, 2010
The burnere ignitions keep on clicking and it is making the hob slightly electrified. I have to turn it off at the fuse box. Can I disconnect the ignition electricity supply?
The electronic igniter is stuck on the "on" position. U can disconnect the wire going to it and it will stop and you can resort to using a match to light the burner. OR, you can clean out the igniter assembly since they often get all gunked up with grease, etc and restore it to proper operation.
Aug 24, 2015 | Cooktops
Westinghouse gas hob four burner only one igniting the other three only light with a match gas coming through but no spark
Clean the wires going to the ignitor of each burner, clean the burners as well. Chances are you have too much oil and dirt on them that is why your burners are not igniting.
Jan 27, 2014 | Cooktops
CDA gas hob ignition
try the fuse ..
Dec 27, 2013 | Cooktops
Cda gas hob Pilot light not sparking to light hob, can use a match to light burners no problem.
IS THE POWER TO THE HOB ON ?
IF SO IS THE FUSE OK ?
IS THE PLUG WIRED CORRECTLY ?
TRY THESE FIRST, IF NO JOY YOU CAN DOWNLOAD YOUR PRODUCT GUIDE FROM CDA ON LINE
Dec 27, 2013 | CDA 4X4SS Cooktop
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
GEXL44 burners light with match, but not with electronic ignition
if u push the knob there is a clicking sound, if no the problem is damage the ignition coil, need to replace it,or check the outlet,plug or its batery operatet ignition? replace the batery.
the ignition is power operated,check the power source.
tnx gerbee
Jun 22, 2009 | GE Profile JGP636 Gas Cooktop
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
One burner requires a match to light
had same problem. Used fine sandpaper on the little head (just above the white ceramic) that creates the spark. over the years the edges of the littel metal ring had gummed up but a 1 min sanding got it down to shinny metal and it sparked nicely.
Nov 30, 2008 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Burner/Flame
Hiya .. this could be due to a number of problems...... has the burner ever worked correctly?
Is the behaviour with only one ring?
1. If not... then it could be that the pipework to the hob itself has not been recuced sufficiently enough in pipe diameter to the regulator far enough back ...
2.The regulator is faulty... in which case it can be replaced... however consider the cost of a new regulator and labour to fix it .. against the cost of a whole new hob... which should include a regulator. Is the hob still under warranty... if so use that .. but you will normally have to provide some proof it has been fitted by someone suitably qualified.
3.the regulator may never have been fitted, which is dangerous and bad practice.
Either of these scenarios... please ensure that you use a suitably qualified gas engineeer... I dont wish to be alarmist... but gas leaks and faulty gas appliances do cause unnecessary deaths...and is a silent killer.
Regards Faggly
Mar 26, 2008 | Maytag MGC5430 Gas Cooktop
Cooktops Logo
174 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
