Question about Polycom SoundPoint IP 501 IP Phone
Polycom 501 displays "Checking application"
We have a Polycom 501 phone that displays the initial startup screen and then goes immediately to "Checking application". I have tried to do a 'reset' of it by pressing 4*68 while booting and then reset the basic information but there was no change.
Thanks in advance for any suggestions.
Robert
brodie7838
  • 11 Answers
SOURCE: i am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Posted on Jan 12, 2010
SOURCE: Dead Polycom 501
u have the cable plugged in backwards
check it
Posted on Jul 26, 2008
SOURCE: just installing polycom 501 phones with nextiva
Ohh this mean, you did not register this extension on your phone system. Create this extension on your phone system. Be sure that password given on Phonesystem is also configured on phone too.
Posted on Nov 14, 2008
corydzbinski
  • 7 Answers
SOURCE: failed to get boot parameters via DHCP
You didn't provide any information about your network which is ALWAYS required to provide any type of help, not to mention a solution.
"Failed to get boot parameters via DHCP, xxx seconds until reboot" simply means that the computer isn't getting an IP address from your router. Setting up your router is another entirely separate topic.
This is pretty simple though, one of three things is happening:
1. Your router is not properly configured to provide DHCP to the phone.
2. Your network cable is bad.
3. Your phone is bad (most likely the RJ45 port since the phone seems to work otherwise).
You can check for bad ports or cables by checking the port status within the router. If the port is lit up, most likely the cable and phone port are fine. This is not 100% though, replacing the cable should always be a consideration even with a lit port.
Posted on Jun 04, 2009
Testimonial: "thank you"
SOURCE: Making a Polycom SoundPoint 501 work on an Avaya IPO
As you have probably found, SIP phones are not supported until R5, which just came out.
Posted on Sep 27, 2009
Polcom phones stop ringing
go to this website and go to customer support www.polycom.com
Jun 24, 2008 | Polycom SoundPoint IP 501 IP Phone
I have a problem regarding my Polycom Soundpoint IP331. It doesn't boot anymore. It shows only an error which is error.cfg.
You need to reinstall all the files back onto the phone. You can get the files from the Polycom Website. You can also follow the instruction from my Polycom 501 Fixya blog to see how its done.
Jun 15, 2011 | Polycom SoundPoint IP 501 IP Phone
Can ping my polycom 501 but cannot open with my
Have you tried a factory reset from the menu interface? Be careful if you do, and only choose "Format File System" as a last resort, and only if you feel comfortable enough setting up a FTP/TFTP boot server to re-provision the phone, as this option will erase everything, and then all it'll do is get stuck in a boot cycle until reprovisioned.
Feb 22, 2010 | Polycom SoundPoint IP 501 IP Phone
Nov 11, 2008 | Polycom SoundPoint IP 501 IP Phone
Just installing polycom 501 phones with nextiva
Oct 19, 2008 | Polycom SoundPoint IP 501 IP Phone
Dead Polycom 501
check it
Jul 25, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom SoundPoint IP 501 IP Phone Logo
1,326 people viewed this question
Top Polycom Computers & Internet Experts
Michael Vincent Cruz
Joe Lane
Darren  Means
Darren Means
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
