HAVE SOUND BUT ONLY A BLUE RED AND GREEN LINE IN MIDDLE AND NOTHING ELSE CANT FIND MANUAL TO FIX PROB COULD YOU HELP PLEASE
  • 1,476 Answers
You have no vertical drive. I have a tip at http://www.fixya.com/TipsAndTricks/preview.aspx?thid=4736396 which explains the problem, how to fix it and where to get the parts. Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 11, 2010
Testimonial: "thanks will give it a go."
Picture is black and white, but I have sound. I have red, green and blue plugins. The green one is fine, but I'm not sure which spots to put the red and blue wires in to fix the color.
blue is always in the middle and the green / red are on the ends. Black / white means you have the wrong matching cables. You need to make sure to match red to red, green to green, blue to blue.
Sep 09, 2011 | Sceptre Televison & Video
I think i have a convergence problem with my 57f 500 tv it looks like 3d i went into the magic focus and did the manual thing and it seems like the only one that i cant get lined up is the red looks...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 01, 2011 | Hitachi 57F500 57" Rear Projection...
My Mits tv has sound no picture ! 3 concave lines,almost like a bowtie in middle of the screen red,green,blue. Please help ???
I would look for dry joints and poor plug socket connections around the line output section.
Mind your fingers!!!!!
Apr 17, 2011 | Televison & Video
Green colour and curved lines
PLEASE POST MODEL # for an accurate response!
But it sounds like a convergence problem.
Jul 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Looks like the picture is in 3D...magic focus won't adjust green
Replace Both of your STK ICs they are Big Black ICs Also CK and replace these resistors RK42 3.3 /RK46 1.8 /RK50 2.7/ RK54 1.5 RK54 1.5/ RK58 3.9 /RK62 2.2
Feb 15, 2009 | Hitachi 57F500 57" Rear Projection...
Green/Blue distorted Colors
Color issues are harder to solve without seeing the problem. It sound like the red amplifier on the crt board is bad. Is there any red in the picture at all? If not, that will be you problem
Nov 26, 2008 | Televison & Video
53 inch panasonic projection tv. have sound screen is black with red green and blue sqiggly line in middle. what is it and how much to fix
check the yoke plug solder joint, as the squiggly lines in the middle usually happens if the yoke is unplugged. So check the yoke plug connections.
Jul 06, 2008 | Televison & Video
Old Projection telvision on the fritz
you need to change the CONVERGENCE ICs , if you cant do it then it needs to be serviced by a HITACHI authorize service shop , hope this helps AJ
May 27, 2008 | Hitachi 51SWX20B 51" Rear Projection...
White screen with red and blue lines
Try removing the battery for a few seconds and see if that clears up the issue.
If it does, be aware that it's most likely a temporary fix. You'll want to go through the phone and clear out some of the memory (saved text message, call log, and even pictures if there are a lot of them). You might want to consider stopping in at your carrier's local store and getting the software flashed as well.
May 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
