Question about Canon imageRUNNER 5000 Copier
I have problem in canon ir5000i the problem is waiting to print error how to solve this problem
  • rashid majeed May 11, 2010
    what is error code ?
  • Canon Expert
  • 1,326 Answers
Have you deleted all the pendding jobs in your print Q and reboot your computer & copier? Some one may have sent a print job on a odd size paper? Did you see if some one sent a job to the by pass tray. Try to put paper there and let the job run out.. Good Luck
Posted on May 12, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Canon MP145 error E27
  1. plug off power cable
  2. press and hold stop/reset button
  3. plug on power cable
  4. press and hold power button(still hold stop/reset buttn)
  5. still hod power button, loose stop/reset button
  6. press stop/reset 2X then loose power button, wait until 0 displayed
  7. press stop/reset 1X
  8. press power button 1X, printer will print 1 time
  9. press stop/reset 2X
  10. press power button 1X,printer will print 1 time
  11. press stop/reset button 3X
  12. press power button 1X ( no print proses)
  13. press stop/reset 4X
  14. press power button longer than before for turn off printer, if print not turn off plug off power cable
  15. turn on printer and error 27 will disappear
i hope this helpfull
thanks for using fixya
Jan 25, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My canon mp258 displaying error 6 there for cannot make scaning and printing can i solve this prob????
Press and hold down the reset button and color or black button at the same time
and wait until the error dis appear.
Please accept this solution if my answer help solve your problem.
Thank you for using Fixya
Dec 06, 2010 | Canon Office Equipment & Supplies
I have error 746 in ir5000i
System software version 9.01 should be installed if the imageRunner does not have the upgraded controller kit.
Sep 13, 2010 | Canon imageRUNNER 5000 Copier
Ir5000i system software E602-01
The error code E602-01 means that the hard drive has a problem. The fix is to replace the hard drive, there are a few tricks to try, but may only hold off the replacing of the hard drive for a short time.
Sep 06, 2010 | Canon imageRUNNER 5000 Copier
My IR5000i just loading can't be ready
Check if u have toner on it most of the tyme they run like that when the toner runs out... any error code ?
Feb 19, 2010 | Canon Office Equipment & Supplies
Ir5000i error 602
Ask Canon. If you're authorized they should be able to help you get what you need.
If you're not a tech get a tech to do it.
Jun 10, 2009 | Canon imageRUNNER 5000 Copier
Document Security
you should be able to send a job to a mailbox and do a secure print that way.
Jun 02, 2009 | Canon imageRUNNER 5000 Copier
Hardisk ir5000/ir5000i
You need to have the hard drive "Flashed" with the correct software. They come from Canon blank, you need to find a tech to flash the HD for you. If your question is if one would work in the other copier, the aswer is yes, but you need to have the printting software on that HD if you want it to print.... Good Luck.... Just for your info. you may want to ask your question in English if you want a respones from one of the techs.
Dec 30, 2008 | Canon imageRUNNER 5000 Copier
Document in queue with "Waiting to print" then doesn't
i know what the problem may be call 0776 4303923
advise is free
Feb 13, 2008 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 5000 Copier Logo
138 people viewed this question
old marine
old marine
