Looking for water valve FCD 270A 220-240V 50-60 HZ WATER JUST KEEPS POURING IN WETHER THE MACHINE IS ON OR OFF WHEN CONNECTED TO THE WATER SUPPLY
catriver
  • 878 Answers
SOURCE: water filling
Before you replace the water valve itself, take the hot water hose off and inspect the screen at the valve inlet. There could be a lot of grit restricting it. If the screen is clear, than I would be in agreement with you that it is the valve itslef..hope this helps you.
Posted on Apr 26, 2006
gittos73
  • 244 Answers
SOURCE: power supply
no it should not but if it does yuo should be able to replace the mains filter to a higher power filter
Posted on Aug 19, 2007
  • 54 Answers
SOURCE: zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Posted on Feb 14, 2008
ngafm
  • 166 Answers
SOURCE: washing machine leaking at the connection to water pipe.
Hi vks1,
Your water is coming out into the washer even when you water supply is switched off at the pipe?
Disconnect the washer hose from the water pipe and see if the water still comes out of the water pipe even when the water valve is shut off!
If the answer is YES!
This is a plumbing malfunction.
The valve on your water pipe is not closing completely!
There is a washer in the water valve attached to the end of the valve stem that more than likely needs replacement.
And not a washer malfunction.
If I understand your explanation correctly this is the cause.
If this is not the problem then the washer has a water inlet that is stuck open.
But this dose not make sense if the external water valve is shut off there should not be water reaching the washer inlet faulty or not!
I believe I figured out the problem for you and you will be fine when the valve is fixed or the valve stem replaced!
Bless You,
ngafm
Let me know that you have succeeded!
Happy to of helped you.
Please give me a good rating before you sign off our site!
Thank You
Posted on Sep 10, 2008
  • 62 Answers
SOURCE: water will not shut off keeps filling and overflows
This is a fill valve gone out
Posted on Oct 20, 2008
Samsung front load washing machine, WF42H5200AF, less than 4 months old giving code 4e when warm or hot temperature is pushed. Can only wash in eco warm or cold. I have drained and cleaned out to front...
Error code 4E is a water supply error.
Check the following:
  • Foreign material is entering the water supply valve.
  • The water supply valve terminal is not connected.
    (Wire disconnected)
  • The warm water and rinse connectors are wrongly connected to each other.
  • This occurs if the PCB terminal from the drain hose to the
    detergent drawer is not connected. Check whether the transparent hose is folded or torn.
Possible Parts Affected are:
  • Water supply Valve
  • Main PCB
  • Obstruction of the water line.
To Check the water supply:
Check the resistance for the water supply valve. Resistance: 0.9~1.1k? between the terminals of the water supply valve
Jan 28, 2015 | Samsung Washing Machines
The drum doesn't fill up...the machine keeps on pouring in water but gets drained immediately nothing else happens
Drain section needs to be checked ---- the sensor nay not being sensing dry, shut off water supply ----- it may activate the 0 water level sensor ---- check for physical damage to the drainage valve .
Dec 28, 2012 | Dryers
The tub keeps filling with water. I must run drain/spin constantly to keep the water from coming out.
Hi There,
Either the hot or cold (or both) water inlet valves has failed and is locked open. Keep running the drain/spin as you are doing and shut off the water supply from the machine. After you have shut off the water supply and the machine has fully drained, switch the power OFF as well. There will be service valves for shutting off the water supply at the ends of the hoses connected to the back of the washing machine. Hopefully, whoever installed it hasn't located the valves behind the machine or you will need to pull the machine out to turn the water supply off - I've seen this done far too many times and it's not clever. The machine will then need to be inspected and will probably need to have at least one solenoid replaced.
Please post back if you need further assistance.
Regards,
BElectric
Nov 30, 2010 | Kenmore HE3T Washer
Machine keeps overflowing during wash cycle
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
May 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
Duet model ghw9400pw0 - hot water supply keeps dripping into drum area when cycle ends.
This sounds like a solenoid valve is malfunctioning -- may just need removing and cleaning or tightening -- solenoid valves are connected to the end of the water supply hose on back of machine.
Charlie
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water pouring from waterdispenser in side by side refrig
Dispenser leaking----Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser
Jul 01, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water keeps pouring into ice maker and doesn't shut off.
does water come into cabinet if the icemaker is unplugged? if so, the water valve is leaking thru and needs to be replaced
May 06, 2009 | Refrigerators
Doesnt stop pouring water
it is suppose to turn off, bad fill valve.
Nov 08, 2008 | Washing Machines
Washing machine nec nw-652
i am having the almost the same problem with what i have, if it is turn, the water will just keeping on pouring in non stop, it does matter wether it is wash, rinse, dry or spin the water will just keep on pouring in at all time, it is not a good machine at all.
Sep 09, 2007 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
