Question about Exercise & Fitness
I have a Maxpro 75151877 treadmill, the error says i need to check the speed signal feedback wire but i dont know what it is or what i need to be looking for. Anthony
    President:
  • 1,469 Answers
What do I do if an error message appears on my True treadmill? First determine which error message it is, and contact the dealer you purchased your unit from or an authorized True service provider.
To clear the error code you must cycle the unit power switch off and on 6 times, with the safety key inserted.
You ca also pull out the key, wait a few moments, and reinsert. If error message remains,
Call your dealer or authorized service company if the error persists.
To find a dealer:
Hope that helps.
Take care.
Posted on May 18, 2010
  • 1 more comment
  • akaplumbing May 18, 2010
    the error is E1
  • Egwe Emmanuel Onyedikachi
    Hi, you can use this link to download the guide to the solution.
    sportsartamerica.com/saf/support/.../Treadmill_ERR-1_Guidelines.pdf
    Hope it helps.
    Take care.
  • akaplumbing May 19, 2010
    i couldn't get into this link?
I have recently installed treadmill motor brushes but now treadmill is not calibrating,calibration takes start and when calibration comes to check the slow speed it stuck there and keep calibrating it
Hi There, Please check that you have the small feedback connectors snug and proper. Some treads have them on a front or rear roller and some also have a motor feedback. Or - Try to power down and back up and try to run treadmill normally, not in cal mode, and see if the unit responds to your speed selections correctly. During "calibrations" the upper board (usually) is looking for a specific feedback signal, if it cannot be found it usually stops the tread, but in cal mode it may sit there waiting for it's feedback sweet-spot before continuing. What make, year and model of tread?
Jun 02, 2016 | Exercise & Fitness
My treadmill not running after 7 seconds diplay shows L5
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It is common to see this error as and L5 error, but it is actually an LS error. The following information will define this error and give you the possible solutions to fix this issue.
LS Error with No Belt Movement on Landice Series Treadmills
LS Error on Landice L-Series Treadmills with No Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
Corrective Action A) Enter Open Loop Speed mode and set treadmill speed to confirm proper line voltage to pwm board and that the green BELTSW light is lit on the relay board. Replace upper display board or relay board if necessary.
B) Inspect speed control wiring and correct wiring if necessary:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
C) Inspect motor control wiring, checking wires from motor to A+ and A-. Correct wiring if necessary.
D) Inspect motor brushes verifying brushes slide freely, are at least 3/8" long, are curved and have no burns or cracks. Also check the brush springs and verify that the brush copper wire is not burned or broken. Replace both motor brushes if necessary.
E) Inspect motor turns and is not seized up or has a broken shaft. Replace motor if necessary. Also verify at least 90VDC present from the black (A+) wire and white (A-) wire from the pwm board to the drive motor. If voltage is present, replace pwm/relay combo board. If no voltage present, replace drive motor.
Details about LS Error on Landice Series Treadmills with Belt Movement
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
Correct speed control wiring if necessary.
Oct 13, 2015 | Exercise & Fitness
Error code 01A0
If you wish to get some details; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Oct 14, 2013 | Matrix T3Xi Treadmill
Maxpro vibelife V815 treadmill error
go for free download: www. fitness.manualsonline. com or www. iconservice. com.
Test every connector and tight very well, see the fuse inside, see the diagram attached for reed swithc and speed sensor, clean and tight the connector very well.
run the software calibration for diagnose and troubleshooting.
Apr 29, 2012 | Exercise & Fitness
I have MaxPro treadmill when I start to any prog. speed change suddenly to 14KM and you change back to any speed it goes back to 14 again
i dont know about yours but ours has panel that will light codes to call company on. it is on bottom under lid for motor. you can check there.
Feb 23, 2012 | Exercise & Fitness
My landice 8700 programable is showing an L5 error and does not run how do i replace the switch that is bad with this treamill it only has an up and down button for more or less speed
Mar 14, 2011 | Exercise & Fitness
I have a Landice L8 and the error code L5???
Jul 09, 2009 | Landice L8 LTD Cardio Trainer Treadmill
Landice treadmill 05 error code comes on when i hit start
Jun 28, 2009 | Landice L8 LTD Pro Sport Trainer Treadmill
Exercise & Fitness Logo
302 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
