Question about Dell Latitude D810 Notebook
Machine freezes when operated on battery. Works fine on ac adptor.
  • 68 Answers
Replace battery for sure , and check if it is genuine .
Posted on May 11, 2010
Testimonial: "Thanks for your prompt reply. Battery is genuine. Will try another battery."
  • Abdulhakim
    Abdulhakim May 11, 2010
    You are welcome , but it happens a lot , sorry if I'm not helping.
My toshiba Satelite A200 is hang when AC adaptor is insert
Inserting AC adaptor while computer is working on battery power, may indicate that an arcing occurred and cpu got wrong data to stop sequential operation. You may have to turn on AC adaptor, after it has been inserted into your laptop while using battery power.
Feb 08, 2012 | Computers & Internet
How do I charge the battery for this L200 camera? My daughter received this camera for Christmas, and I can't find anywhere the instructions for how to charge it! Please help! Thanks! Hollye F.
you have the usb cable and adptor right??connect the adaptor and usb then insert it to the camera then plug in to the ac line..but takenote.,the battery was inserted tot he unit..
Feb 20, 2011 | Samsung L200 Digital Camera
My computer do not turn on at all.. i got new bettery and got new ac adptor charger.. stil it wont turn on... when i plug the charger it shows the blue light .. but when i trun on the power button it turns...
Take your battery out and stick it back in... make sure it is locked and fitted in there properly.... nothing wrong with the hard drive or virus... maybe you have the wrong battery... or AC adaptor... hope this helps :)
Jan 09, 2011 | HP 435768-001 - Compaq Presario C300...
Nothing at all happening when i turn it on even when plugged into mains
Check your power adptor if it is working fine. If it is working, then check out the battery if it has drained out all power. If you can find any battery same as your laptop then try to check out with that. If it still remains dead, then you have tp open the system cover and check the internal fuse. You will fine this fuse near the input plug of your power adptor. It will be white and some visible amps will be rated, use your multimeter. There can be more problems but im just giving you basic hints if you can overcome this problem. Still can't get it done, consult with qualified IT technican. Thanks
May 15, 2010 | ASUS Eee PC 701 Notebook
Acer travelmate 4100 works fine with no battery
Try to use another OS, like Ubuntu Live, and see if the mouse and KB will freeze. If they wont freeze, It is better to reinstall the OS.
If they will freeze again with Ubuntu, then I am sorry to tell you that the battery life has finished.
The only thing to do is to replace it for another one new.
Thanks for rating!!
Apr 21, 2010 | Acer TravelMate 4100 Notebook
Ny laptop wont charge
the battery is dead and will need to be replaced.
Aug 15, 2009 | Computers & Internet
Acer 1642 freezes and will not power down unless battery is remov
sounds like a virus or malware, try this, go to spybot, search and destroy and download thier free program, also AVG. com, also free, and run them both in safe mode, also defrag your hard drive, start,programs, accesories, system tools, defrag, it may run several hours, let it a lone, first spybot, then avg, then defrag
Jan 03, 2009 | Acer Aspire 3000 Notebook
Problem with battery on Acer Travelmate 4060
There are probably some corrupt files on the harddrive or there is damage on the hard drive. I would suggest to try using the windows setup cd or sony recovery cd to restore the system back to normal, if the problem is not solved by that then you most likely have a hardware problem which is most likely in the harddrive, might have to replace it, they don't cost much.
if you press f8 in start up to get the advanced startup menu, select safe mode.
start in safe mode and login
then
press start -> now run -> type in Cmd -> Type in the shell window -> chkdsk /F /X /R C:
if asked select Y to perform the operation on next start up.
see if the problem is solved.
Nov 15, 2008 | Acer TravelMate 2300 Notebook
Camera wont turn on even with new batteries
In order to narrow down the issue, I suggest you the following steps. 1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera. If this doesn't fix the issue, Than.... 2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain. If this doesn't work. 3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not. This is the way to narrow down the issue. Thanks you.
Apr 08, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Dell Latitude D810 Notebook Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
