Question about HP Deskjet 3845 InkJet Printer
My HP 3845 lately prints grey instead of black, in 'Normal' as well as in 'Best' modes. Any idea why this could be?
    Sergeant:
  • 279 Answers
Go to Control panel
select printers
right click on your printer
select PRINTING PREFERENCES
Then on the next new window that opens up (the tab should default to PAPER/QUALITY) click on the LAST tab COLOR
Here you can see if maybe somehow your PRINT IN GRAYSCALE box is checked-uncheck it to correct your problem-click on OK at bottom to save the setting
Reply back if this does not correct it.
Hope this helps.
Posted on May 11, 2010
Hp dj 3050 print not dark enough
Have you tried changing your printer settings? It may be set to draft instead of normal.
Jan 10, 2014 | HP DeskJet F380 All-In-One Printer
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
My printer is printing grey instead of black on my Mac. It was fine, but now I can't figure out what's wrong. Ink levels are good. I did accidentally get water in the AC adapter. Could that be it? After...
No, the water has nothing to do with it. Somewhere in a print dialog or perhaps in the printer driver, something changed to grey.
Try printing an ordinary black text document. Before you click "Print", look for "properties" or "Printer setup". Somewhere in there something got changed. Perhaps you can find a "default" button in a dialog box to restore the printer to factory settings.
MIGHT help (probably not) to shut down the Mac, power down the printer, and then start both up. Just an idea.
Apr 18, 2017 | HP PhotoSmart C4480 All-in-One Printer ...
Black is printing gray
Has your printer defaulted to 'draft' printing? That's where grey printing seems to come from.
Feb 20, 2010 | HP DeskJet 9800 InkJet Printer
My hp deskjet 3845 is not printing, it says there is a document printing but i have cancelled all documents - any ideas?
Hi Jamie,
You best option is to reset the printer spooler. 1. First turn your pritner off. 2. Then in you PC, click on "start". 3. go to "run" 4. type in: CMD 5. This will bring you into a DOS window.. In the DOS window type: net stop spooler (press enter) 6. now type: net start spooler (press enter) 7. now type: exit (press enter) 8. Now turn on your printer.
This should have rested the printing system.
Regards, Ed
Nov 21, 2009 | HP Deskjet 3845 InkJet Printer
Printed material looks smeared, smudges on paper, gets worse if change print quality choice to "normal," "best."
This sounds like a bad ink cartridge or refill job. Often you can get a new printer, better than the old one, with cartridges, for the same price as the new cartridges.
Jun 20, 2009 | HP Deskjet 3845 InkJet Printer
Printer only prints out in blue
change the color cartridge and instead of Black,,use Photo Cartridge..
Nov 01, 2008 | HP Deskjet 3845 InkJet Printer
Hp deskjet 3845 won't print in color
When you click on "Print" and the window comes up, click on "Preferences".
Click on the "Color" tab. There should be an option to print in color or grayscale. Select "Color".
Oct 18, 2008 | HP Deskjet 3845 InkJet Printer
HP Deskjet 3845 print queue not clearing
Have you tried going to safe mode, turning off the printer and manually opening it at the control panel>printers... try and delete or cancel prinitng at these settings...
Dec 09, 2007 | HP Deskjet 3845 InkJet Printer
New black print cartridge not working
I only use refill HP inks. When the cartridge prints gray instead of sharp black it means the ink well is clogged. Yes, that can happen on a new cartridge. Sometimes it happens when they put too much ink in the cartridge, or even heat can make it not work. Also streaking black lines is the problem of the ink not coming out properly. Easiest thing to do is go to a refill station like Cartridge World and have them test it or clean it out. You can also make sure the printer, not the cartridge is clean. Ink builds up an pools. Get some Q-Tips and clean up all that spilled ink. Sometimes in the software it says you can clean the print head, do that too.
Sep 14, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Deskjet 3845 InkJet Printer Logo
295 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
