Question about Symbol LS 4071 Handheld
I am trying to find the software installation file for a 123scan LS4071-I1US
  • 3 more comments
  • Abdulhakim
    Abdulhakim May 11, 2010
    Did you attached it already to your PC and it is not detected or you want to search for the driver before doing that , because I assure you that I have Symbol barcode scanner in my shop and it is working without driver. respond ASAP.
  • Abdulhakim
    What OS installed on?
  • daniel_may May 11, 2010
    I am using windows XP
    I have it attached to the computer and it will scan, but it will only scan one number. It will not scan and input the entire barcode in the scan# box.
  • 68 Answers
OK try this trick . take any product lets say a tissue box and scan the barcode and see if it show the same problem?
if it is the same try to clean the scanner until we figure out something else.
if it reads it full the n the printed barcode are the damaged ones.
Posted on May 11, 2010
123scan - leanguage problem
http://www.motorola.com/web/Business/Products/Bar%20Code%20Scanning/Bar%20Code%20Scanners/General%20Purpose%20Scanners/DS9808/_Documents/_Static%20files/SYMBOL%20DS9808%20Quick%20Start%20Guide.pdf
there are bar codes for the country you are in underneth programing bar codes 3rd one down in the 3rd colom
if this helps you out pleazse take a moment to rate this. anything else i could assist you with?
Jan 14, 2013 | Symbol DS9808-SR00007NNWR - Motorola...
Symbol LS4071 not charging
I would suggest to replace the battery. Is it the smallest part and also only one which could degrade during the time.
Jul 13, 2010 | Symbol LS 4071 Handheld
Symbol barcode scanner LS4071 + base RL475
Hi, you will need the 25-17821-20 and STI80-0200R cables to connect to PS/2. You must have a PS/2 keyboard for this connection.
If you would prefer to connect to a USB port you should get the 25-17821-20 cable with the STI85-0200R.
The RL-475 was for the IBM, but it also supported Synapse which is the STI cable.
Nov 18, 2009 | Computers & Internet
Barcode reader language
Concerning the Z issue you should select german keyboard from 123scan
Else you will have to program macro to substitute the caracters
Sep 03, 2009 | Symbol LS2208-7AZK0100S Handheld
Suffix with 2 x ENTER
Try programming it by setting up a pair of ADF rules, each adding an "enter". This is done by scanning configuration barcodes from the manual in the correct sequence. You can get the manual here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Aug 27, 2009 | Symbol LS2208
Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Jul 27, 2009 | Symbol LS 4071 Handheld
Part of code
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS? I would like to recommend you to used visual basic 6.0 for better outcome.
Hope you like my solution please rate me Solved.
best regards,
Philip
Nov 02, 2007 | Symbol LS2208-1AZU0300S Handheld
123Scan File
P370 WILL NOT connect with your terminal or base, so forget about this intent and go for the goal which is loading your programming to your scanner. According to Motorola the work around is simple and faster than trying to resolve this.
Start with Reseting the scanner completly back to Defaults.
In the 123Scan, PRINT Barcodes and the rules ADF Rules of your programming.
Start scanning from
"Parameter Settings" until the last page barcode "Reset Scanner".
That is it. Problem solved.
You will need to do this for every new programming Rule.
Nov 18, 2006 | Symbol P370 Handheld
Symbol LS 4071 Handheld Logo
317 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
