Question about Magicard Tango +L Printer
Getting code Hi I got a problem with my Tango+l printer When I Give a print It will jam before platen Roller And it"s Print one color also and code comming code=02:11 pls Give me D solution of this Tanking you Riyaz Nadaf
3 Suggested Answers
magicard
  • 71 Answers
SOURCE: MagiCard Tango 2 Badge Printer
Hi There,
This is very a very common problem!
Fortunately, it's really easy to fix too;
Go to your 'Printers & Faxes' folder. Right-click on 'Magicard Printer Series'.
Select 'Properties'. Click on the 'Device Settings' tab.
Select the correct printer model in the drop-down list (Tango 2);
I suspect you currently have 'Tango' selected.
I hope this helps.
With Best Regards,
MC.
Posted on Nov 23, 2008
magicard
  • 71 Answers
SOURCE: my Magicard tango 2 is Locked
Hi There,
The printer will say 'Locked' if someone has removed a custom HoloKote key from the slot in the front of the printer. Have you ever had a custom key fitted to this slot?
First of all, make sure you have the very latest version of firmware installed in your printer. You can find this here;
http://www.magicardonline.net
Just enter your printer's serial number in the QuickSearch box.
If after updating the firmware, the printer is still saying it is locked, download and install the Magicard Support Utility (available from the same site. Run the Support Utility and select the 'Query Printer' tab.
Then press the query button. You can then save the result of this query as a text file. You can paste this into your reply. This may give a hint as to what the problem is.
With Best Regards,
MC.
Posted on Jul 29, 2009
When printing color the paper jams. This does not happen when printing black. How do I stop it from jamming when printing color.
Is that true for both print and copy job ?
Where does the jam happen ?
I am thinking if it is at the paper pickup roller area just as the job starts to print and not midway while printing, check the paper quality; dirty pickup roller; clean cork pad and try job from another tray
Sep 21, 2016 | Konica Minolta magicolor 1680MF -...
I keep getting wrinkled ribbon in my zebra XiIII printers Part seems to be caused by static, the ribbon will not rewind properly
Its probably not static. 1. Wipe the print head and platen roller with alcohol dampened qtip or lint free cloth. Print about 30 labels while gently pressing on the ribbon supply, causing it to drag a little and observe if the wrinkles stop. If so tighten the nut on the end of the ribbon supply a little at a time until wrinkles disappear. Check the head pressure toggles on top of the print head and make sure they are adjusted about the same. If you have been printing a lot of the same size labels, check the platen roller (white) at the point where the right edge of the label rides on it for a slight offset where the roller is worn down. If it is worn, the only fix is to replace the platen roller.
Feb 17, 2011 | Zebra Xi Series 170XiIII Thermal Label...
Printer will not print
There's a hidden sensor lever under the white guides behind the platen roller. Either a scrap of paper is holding it up, or it could be bent from pulling out a jam. It is a black lever behind the platen roller slightly to the right of center. You may need a shop to repair.
Apr 25, 2010 | Canon PIXMA MP150 All-In-One InkJet...
When i start printer E 3 error message is flashing I have removed paper and blown out with compressed air , there doesnt appear to be a paper jam , so what else could be the problem
Dec 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My canon i850 is blinking 3 orange lights at me and refusing to print. any ideas. tried turning on and off. removing print driver and re-installing thanks!
3 blinks is a line feed error, something stopping the platen roller from turning, look inside where the paper goes and see if something fell in like an ink pen, paper clip, just something that doesn't belong. The platen roller is the gray roller behind the carriage and sometimes you can see thru under the white plastic guides something jammed.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
Sato 408E problem
Using direct thermal labels it can dirt the printhead and platen roller, you must clean them with isopropyl alcohol and a flannel. Also adjust the darkness to less value to best print.
Roberto Martinez
Jun 29, 2009 | SATO CL408e Thermal Printer
Fargo 4250 card printer runs, but doesn't print.
take the ribbon out, and rewind it a little bit and see if you see print on it. if you dont, chances are your printhead is either bad or has loose cables going into it.
if you do see print, either your card is not aligning properly or the head lift motor might not be working (when the unit on, open the door, and press both buttons at the same time and see if the printhead does an up and down motion), platen roller is bad
May 12, 2009 | Fargo 4250 Thermal Printer
Flipper Error
Cleaned the rollers with an alcohol swab.
Feb 27, 2008 | Magicard Rio ID 2 Card Printer
Magicard Tango +L Printer Logo
35 people viewed this question
Top Magicard Office Equipment & Supplies Experts
Safe-Card ID...
Tom Chichester
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
