Question about Pyramid Krypton Headlight QR Handlebar Clamp Bicycle Bike
Need help installing a Pyramid Krypton Headlight manual for my Diamondback. I do not have a manual. It has a quick release bracket...
  • 21 Answers
The brackets for most lights are usually simply held in place by a screw. You would need to unscrew it, open the bracket, place it over the handlebar (don't forget to use the rubber strips between the bracket and the handlebar as this prevents the light from twisting), then you use the screw to tighten the bracket/clamp.
Posted on May 14, 2010
Replace headlight bulb
  1. INSTALLATION GUIDE:
  2. BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
  3. Parts Identification:
  4. Projector Headlight
  5. Halo & L.E.D.
  6. Bottom of the Headlight:
  7. Ballast Bracket, Halo Wires(red/black)
  8. Turn Signal Adaptor
  9. TOOLS REQUIRE
  10. 10mm - 8mm socket
  11. Philip Screwdriver
  12. Crimper/Pliers
  13. For more information about how to install your vehicle, come visit our youtube page on
  14. http://www.youtube.com/spyderauto
  15. Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
  16. Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
  17. Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
  18. Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
  19. Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
  20. Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
  21. STEP:
  22. Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
  23. Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
  24. Factory Xenon Headlight
  25. Spyder Projector Headlight using Factory Xenon Lights
  26. STEP:
  27. PLS VOTE ME
BMW e46 HID Headlight Replace
Nov 23, 2012 | 2000 GMC Denali
Seat keeps coming down
http://www.diamondback.com/downloads/owners-manuals/
See page 22...
http://www.diamondback.com/wp-content/uploads/2008/03/2012_OM_DIAMONDBACK.pdf
While you're at it, get a handle on how quick releases for the wheels work or more than your seat will be going down when you ride.
Jul 08, 2011 | Diamondback Sorrento 26" Mountain Bike
Need diamondback v link 3.1 owners manual
Cant find a manual for you but maybe this link can help you , http://www.diamondback.com (down loads) ( owners manuals)http://www.bikepedia.com
Jul 01, 2011 | Diamondback Cycling
Got a 1999 Diamondback Wildwood bike and was trying to take off the crankshaft and front sproket. Do I need a special tool for that? What's the trick?
Hi, yes you do need a special tool. It's called a Crank Arm Remover. The tool is basically a modified puller that threads first into the inside of the crank, (after the bottom bracket bolt is removed) where it is bolted to the bottom bracket. Then, a second bolt is then threaded inward against the tapered shaft of the bottom bracket. Slowly the crank will lift away from the tapered shaft of the bottom bracket. Hope this helps.
Nov 16, 2010 | Diamondback Cycling
How to take out and replace headlight bulbson 2002 passat
here are instructions from autozone.com
  1. Open the hood and if equipped with a rubber access cover, remove the cover over the back of the headlight assembly, and then disconnect the electrical connector from the bulb.
  2. If a rubber seal/cover is mounted around the bulb, disconnect the electrical connector from the bulb, and then remove the rubber seal/cover.
  3. Once the electrical connector has been disconnected, squeeze the ends of the retaining bracket inward, then pivot the retainer away from the rear of the headlight assembly.
  4. Grasp the bulb securely and remove, noting the location of the alignment tabs for installation. Allow the bulb to cool before removing it from the headlight assembly.
NOTE Do NOT touch the glass portion of the new bulb. This will shorten the life of the bulb.
Fig. On some models, a rubber cover is removed to access the bulb-1.8L Passat model shown
Fig. Once the cover is removed the wiring can be accessed and disconnected-1.8L Passat model shown
Fig. The bulb is retained by metal bracket. The ends are squeezed toward one another to release them from their retainers-1.8L Passat shown
To install:
  1. Install the new bulb into the headlight housing and squeeze the ends of the retaining bracket inward while pivoting the retainer toward the rear of the headlight assembly. Release the retaining bracket making sure it is fully seated in its retainer.
  2. The balance of assembly is in reverse order of removal.
Oct 19, 2010 | 2002 Volkswagen Passat
Replace headight assembly on 2005 buick lacrosse
The procedure to replace head light assembly on buick lacrosse is as follows:--- 1)To remove and replace the headlight assembly you will need to remove 1 retaining bolt on the top of the headlamp assembly and 2 sliding retainers at the rear. 2) The carefully Pull up the retainers and that will release the headlight assembly and allow you to pull it out the front. 3) When installing the new headlight assembly make sure you have it lined up correctly before trying to install the retainers, don't force them it may get cracked . 4) Both the cover and the bulb are removed by a standard twist to the counterclockwise and replaced by a twist to the clockwise. 5) Now to the dim light. You have to release the entire light assembly before you can remove the screw-on cover to reach the light. 6) On the rear edge of the light unit closest to the engine is a white locking tab. Pull that tab up just to the point where it releases…pull too far and it locks again. 7) Next, locate the other locking bracket which is a metal bracket in the center-rear of the light assembly. This bracket is held down by a screw. 8) Remove the screw with a 10mm wrench. Lift the bracket just like you did the white bracket. You should now be able to pull (or pry) the entire light unit forward a little. Depending on the size of your hands this might be enough. Note:-- The turn signal is part of the headlight assembly on your 2005 Buick LaCross. 9) To replace the headlight bulb you need to remove the front bumper cover. 10)To release the plastic bumper assembly to give you a little more space. This is done by removing two expansion locking pins, one that holds the little plastic strip down between the bright and dim lights and one that is located inside a rubber bumper on the engine side of the light unit. 11)To remove these locking pins, pull or pry up the little tab in the center of the pin. Thanks.
May 23, 2010 | 2005 Buick LaCrosse
How to install hid on a bmw 325xi 2006
INSTALLATION GUIDE:
Projector Headlight
Halo & L.E.D.
Turn Signal Adaptor
TOOLS REQUIRE
10mm - 8mm socket
Philip Screwdriver
Crimper/Pliers
STEP:
STEP:
pls vote an diam giving you link also for better help BMW e46 HID Headlight Replace
Oct 15, 2009 | 2003 BMW 325
I need krypton motherboard driver No. m7vkm400vga
go to http://www.viaarena.com/default.aspx?PageID=420&OSID=1&CatID=1160&SubCatID=102
click logo in center of page to download.
Passed this Krypton is defunct and I can't find any drivers anywhere but it is based on this chipset and this is the closest your going to find.
Mar 10, 2009 | Foxconn 661FX7MI-RS (661FX7MIS)...
Replace headlight
It is quick and extremely easy to replace the headlights on the envoys. Look at the top of the headlight assembly. you will see a kinda large lever you can pull up. Pull it up and the entire headlight assembly will be released from the car. Be prepared to hold it, and whatever you do, do not touch the new bulb with your bear hands!!. Kinda self explanitary once you get the bracket loose by pulling up the lever. Replace the bulb, and put the assembly back in the same way,, and press back down on the lever. Your done,, takes about 2 to 3 minutes.
Jul 18, 2008 | 2002 GMC Envoy
Pyramid Krypton Headlight QR Handlebar Clamp Bicycle Bike Logo
88 people viewed this question
Top Pyramid Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Pyramid Cycling Expert? Answer questions, earn points and help others
