Question about Toshiba TP43H60 43" Television
Toshiba TP43H60 Convergence
I have a Toshiba TP43H60,The convergence is off in the top left and top center,I replaced the convergence IC's (stk392-110)with no change.I checked the resistors around the IC'S.Still couldnt adjust the convergence correctly using the the remote,the red is the one with the problem;it is bent at top. I was going to order the service manual but is not avalable.
Has anybody had a similar problem?
  • Anonymous Apr 01, 2008
    i have a toshiba 42h81 and i have the same problem. i spent all day yesterday replacing the ic's and when i got them back in i noticed no change what-so-ever. the red gun only moves up and down and will not move side to side. there is also a slight bow on the left hand side in the red and a slight wave of blue at the top. also the blue in the lower right corner seems sit at an angle. i looked at all the resistors and didn't see any blown or blistered ones.
    what to do now?
  • Toshiba Master
  • 8,617 Answers
What year was your set manufactured. The other site I work for as atech has a vast collection of toshiba service info
Posted on Mar 29, 2008
SOURCE:
Toshiba Convergence
You have one or more bad convergence amplifiers. Best to replace both convergence output ICs as well as check low value resistors associated with them.
Oct 16, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba TP43H60 - Unable to adjust colors left/right
Have you tried to adjust in the customer menu or in the TECH menu? I can tell you how to get into the tech menu--if it will not adjust there you have a convergence circuit problem and I can tell you what is needed to repair the set.
SD TECH
Oct 08, 2009 | Toshiba TP43H60 43" Television
Toshiba TP43H60 Convergence Problem
This may sound odd but try moving the remote further from the set. I have seen similar issue with my 42H81.
Jun 01, 2009 | Toshiba TP43H60 43" Television
Toshiba big screen tv. tp43h60
Good Day;
I would suspect the convergence IC's, to confirm this unplug the convergence yoke, all three. If TV comes on IC's are bad. Also, check the little green pico fuses. Good Luck, big IRISH.
Nov 10, 2008 | Toshiba TP43H60 43" Television
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Additional info on Toshiba TP43H60
sounds like maybe a fusible resistor has opend. Did you remove one leg of the resistors out of circuit when you checked them? Also some toshiba models had fuseable links near the ICs some mounted between the fins on the heatsink and others were solderd directly to the circuit traces themselves.
Mar 31, 2008 | Toshiba TP43H60 43" Television
Additional info on Toshiba TP43H60 convergence
I am not sure what your needing help with , however its posted under convergence . Your set if having difficulty with aligning the colors will need to have both Convergence ICs replaced. This is an easy repair you need two STK392-110 Convergenve ICs. You can get them at the following link just click on the section titled Convergence IC and you will see your ICs listed there. They also include step by step instructions with pictures on how to remove the old and replace the new ICs as well as set you up with a free online chat session for support while your doing the repair. Heres the link.
http://servicemanuals.vstore.ca/
If you need any additional info please let me know.
Horizontal Curvature with convergence problem
DA, convergence circuit has failed, the IC`s and possibly a couple of support resistors need to be replaced, your right about it being a good set, 6 years is about average for convergence IC`s, call your local shops for a few estimates and get it fixed, it will run for a lot longer than 6 years, hope this is the advice your looking for, e-mail me if you have more questions, BMW Rider
Dec 10, 2007 | Toshiba 65H81 65" Rear Projection...
Toshiba TW56X81 Convergence issues
I retired from the TV repair business because if you are not an authorized repair service center most manufacturers will not even talk to you. If you are electronically inclined you can repair this tv. your problem is a bad convergence ic. you need to be able to locate it and replace it. it probably has about 15 or 18 legs that need to be unsoldered and a new replacement re-installed
Sep 29, 2007 | Toshiba TW56X81 56" Rear Projection...
Problem with green color
One of your convergence IC's has burned out and needs to be replaced. If the green color is sagging from the top or bottom then the IC that handles the Green Vertical (GV) is bad, and if the green has moved inward on the left or right sides then the IC that handles the Green Horizontal (GH) is bad. Toshiba projection TV's typically use the STK392-110, and it is a good idea to go ahead and replace both IC's with the updated STK392-150's. If you do not have experience replacing convergence IC's then have a qualified tech handle it for you.
Jul 02, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba TP43H60 43" Television Logo
136 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
