Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Y03 unit unequipped
We are having m70 controler in campro cpv-1100 machine in december 2009 we are faced that y03 unit unequipped. service engineers confirmed and replaced the y axis drive the machine is within warranty.
now we are facing the same problem that y03 unit unequipped within another six months.service enginer confirmed the drive fail again.
questions are is that mitsubishi controllers not suitable for india ?
if its no wat is the reason of the failure ? wat is the remedy .please reply us to take a necessary actions
Thanks & Regards,
R.Guna Sekaran.
Chief Executive.
Mobil No.9380296310,
Ph. No.044-42738161
M/s.Alltech Engineering ,
No.10, Pillayar koil 3rd Street,
Ekkattuthangal,
Chennai 600 032,
alltechmould@gmail.com,
techman
  • 3130 Answers
SOURCE: Mitsubishi WD 73727 73in
Contact Mitsubishi with the proof of this and demand a new TV set. Maybe it is the service shop causing this, your warranty should also be extended for the time you were out of the use of the TV set while waiting for parts. If this does not work, the state attorneys office should be able to get you a new set or at least this one repaired. Good Luck
Posted on Sep 27, 2007
  • 927 Answers
SOURCE: Mitsubishi WD-52525
Good Day;
A service manual will not help, but look for at other advice given and please respond.
Good Luck, big IRISH. PS: If again you need more info , come back.
Posted on Sep 23, 2008
  • 34 Answers
SOURCE: mitsubishi pajero io 1.8 GDI idle unstable
sounds like the cabbruter is losing pressure cheak tubes may be lose or damaged
Posted on Feb 24, 2009
SOURCE: 3rd lamp purchased within 2 yrs
There is a slight chance that you might have an issue with a defective ballast, I mean 3 lamps in 2 years, it's too much. The best way to go here is replacing the ballast, that might solve the issue.
Posted on Jul 25, 2009
  • 64 Answers
SOURCE: Same problem
It sounds like the classic "timer problem" that requires a "kit" (mostly capacitors) to repair it. To have someone do it (such as your service person) for you can be expensive and time consuming. Sets that are 5 or more years old usually have other problems too which, simply put, is a complete cleaning of all mirrors, fans, and filters.
Posted on Aug 01, 2009
Ducati hypermotard 1100 service manual 2009
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Ducati despair not for a mere $10 you can download another one. For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Ducati Hypermotard 1100
the official tips and tricks thread Speedzilla Motorcycle Message Forums
May 12, 2014 | 2009 Ducati Hypermotard 1100
Check engine light came on a 2007 1100 vstar
Hi, Anonymous ECM generated a fault code for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Check Engine Trouble Codes Star 1100 Wiki Knowledge Base
Re Check engine light CODES Road Star Forum Yamaha Road Star
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
May 08, 2014 | 2009 Yamaha V Star Classic
My 2009 950 v star will not come on . no lights horn or nothing
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.starbikeforums.com/forums/49-v-star/9371-good-battery-no-power-1100-v-star.html
Re My Yahama Star 1100 wont start Road Star Forum Yamaha Road Star
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
Yamaha STAR XVS950 Owner Manual
Apr 02, 2014 | 2009 Yamaha V Star 950 Tourer
2009 yamaha v star 1100 fuse location
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2009 yamaha star 1100 fuse location Google Search
http://www.starbikeforums.com/forums/49-v-star/8800-headlight-fuse-location-1999-vstar-1100-custom.html
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Jun 10, 2012 | 2009 Yamaha V Star 1100 Classic
Engine code po496 2006 chevy trailblazer
Diagnostic Test Code (DTC) P0496 means that there is purge flow through the Evaporative Emissions System (EVAP) during non-purge. The Powertrain Control Module (PCM) measures fuel tank pressure by reading the voltage from the Fuel Tank Pressure Sensor (FTP). The PCM controls the pressure by opening and closing the EVAP Canister Purge Solenoid Valve (CPV). It accomplishes this by grounding and un-grounding the control circuit to the CPV. When the CPV is open, engine vacuum is applied to the EVAP canister and ultimately, the fuel tank itself. When this happens the pressure inside the tank drops, causing a voltage change in the FTP sensor.
This code sets when there is a pressure drop in the tank when the CPV is commanded closed (there should not be any vacuum applied).
The code can actually be caused by several things. It could be caused by a faulty FTP sensor giving false readings to the PCM. It can be caused by a voltage drop in the FTP sensor circuit caused by wire corrosion or a bad/corroded connector, etc. It can be caused by a short to ground in the CPV control circuit, causing the CPV to be "ON" all the time. It can be caused by a CPV that is just plain stuck and will not close properly.
A faulty or "stuck" CPV is the most likely cause of the problem however, the rest of the circuits and sensor involved should be checked for proper operation before replacing any parts. (It would be a total waste of your money to replace the CPV only to find that you have a shorted control circuit.)
May 23, 2011 | 2006 Chevrolet Trailblazer
I want details of calls(incoming & outgoing) of my airtel no. 9779359212 for the month of 1st December. 2009 to 31st December. my email address is raaj.kumar49@yahoo.com
i want details of calls ( incoming and out going) of my air tel no 9629166265 for the month of january 2010 to tilldate. my email address is madhusamy_ 67@yahoo.com
Jan 20, 2010 | Nokia 6300 Cell Phone
VCR will not go to date 2009
I wish you luck on your search for an answer, but vcr's are programmed for a possible life expectancy.  So ur vcr was expecting to be in a landfill by january 2009 and according to its programming there is not a 2009.  Combo units at walmart are realativly cheap now a days I would recommend picking up a new one.
Jan 03, 2009 | Electronics - Others
My B100 Keurig stopped pumping water
This is a very common problem, just call Keurig tech support. Explain the problem and they will send you a replacement unit and you get to keep you old partially functional unit. I bought mine in December 2009 and I'm on my 3rd unit already. They keep having the same pump issue and Keurig just keeps sending me replacement units. Their customer service is great, but I'm beginning to question their quality control.
Aug 24, 2008 | Keurig B100 Coffee Maker
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
281 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
