Question about IBM ThinkPad DVD_ROM Ultrabay (73p3270) Internal DVD Drive
Dvd drive does not work on thinkpad R51
I bought the computer used and since I got it the dvd drive had a hard time reading discs. The drive use to start up after multiple tries (taking out the cd, putting it back in) and start spinning. Now it will not read anything at all. My computer is running on linux but used to have windows xp and the pcdoctor gave me multiple errors on it. I have reinstalled the drivers numerous times and I'm pretty computer savvy but this drive has stumped me. Please Help!
WhIzAtIt
  • 136 Answers
SOURCE: Having a trouble with my DVD-ROM - IBM ThinkPad T42
Internal the pickup assy. (the laser) there are three components that read the discs, one for DVD one for CD and one for the DVD-ROM its likely that the DVD-ROM laser has gone out. Take the drive out and get the part number and look it up online on ebay or the like :-)
Posted on Sep 15, 2007
fire sine
  • 382 Answers
SOURCE: Device clicks when I insert DVD and can't read the disk
Try cleaning the lens, when a drive clicks in a certain way, its trying to read the disk, especially if you place your habd on the drive and it feels like its speedin gup and slowing down. Those are signs of the computer recalibrating the laser, or attemptong to, to read the media.
Posted on Oct 28, 2007
SOURCE: CD / DVD player not listed as device on Windows Explorer
I also have the same problem. I've tried all the above plus some added info. The floppy still works when I swap it with the DVD. Occasionally it works for a short time right after a hard boot but soon after it appears to uninstall. I have searched the net for answers to this problem without success. I tried the registry correction without avail. There has been some online comments that the problem appeared after an auto update from uSoft. I believe the problem is software or firmware related.
Posted on Dec 28, 2007
  • 16 Answers
SOURCE: My thinkpad T42 will not read any cds
uninstall/reinstall driver
Posted on Feb 13, 2008
SOURCE: R40 Thinkpad CD drive
I also have an IBM R40 with a combo drive that showed the same symptoms. I switched the drive with two another two which I can assure that work 100% correctly, and the same problem happens. First the drive wasn't detected some of the times, or it got randomly "disconnected" while the laptop was on. Nowadays (about 1 year ago), the drive never gets detected, not by the BIOS or by the operating system (Linux, but also tried on Windows), even so, If I don't keep the drive disconnected, when the laptop boots the BIOS hangs for a long time like it was trying to detect the drive, but it doesn't. It turns out that is a system board problem. Hope this helps you on finding the solution. Regards
Posted on Aug 25, 2008
Cd/dvd not working
First try buying a CD/DVD Cleaner Disc. Let it try to run a few times; the lense could be just dirty. If that doesn't help, go to Amazon.com and look up your model of thinkpad and see how much a new drive for it will run ya!!! ^_^
Mar 06, 2014 | Lenovo ThinkPad Edge E430 3254
My cd/dvd/rw drive is not starting up when I put in any type of disc. (Thinkpad R51)
From the microsoft support website:
http://support.microsoft.com/kb/330135
This issue may occur if one or more of the following conditions are true:
* A version of Roxio Easy CD Creator that is earlier than version 5.02d is installed in your computer.
* The AutoPlay feature is turned off in the registry.
* Your CD-ROM drive is using an outdated driver.
* The Restrict CD-ROM access to locally logged on user security option is turned on.
* The CD drive is using an outdated driver.
* The CD-ROM driver is not incompatible with Windows XP.
Instructions for correcting any of these items are located at the link above.
Good luck
Sep 05, 2011 | IBM ThinkPad R51 Notebook
IBM thinkpad R51 won't boot and the blue screen with unmountable-boot-volume comes up and i cannot bypass it.
Sounds like at least a corrupted OS, but most likely a bad hard drive. I'd try reloading Windows (if that's your OS) first, which should take well under an hour; if reloading takes excessively long, then the system is probably having a hard time formatting the hard drive due to physical bad sectors and the easiest thing would be to replace it. The R51 uses good old ATA/IDE 2.5" 9mm height hard drives, which are not available in most stores any longer, but you can probably get the same size or larger ones on eBay for pretty cheap and replace it yourself. Expect to pay about 50 cents to 75 cents per gigabyte - anything more would be considered tourist prices...
Sep 01, 2011 | IBM ThinkPad R51 Notebook
My cd rom stopped reading disks. Is there a way to fix it?
First would be to try to clean it with a CD/DVD cleaner disc. If this did not help, next is to try to clean the lens with a lint free cotton cloth. If this either did not work, then the last resort is to replace the drive.
Jun 20, 2011 | IBM ThinkPad R51 Notebook
My IBM R51 laptop can't read any other cd/vcd
its either its a lens problem or that was how the CD/DVD Drive was made.
There are some drives that doesn't play white face discs, that is, they select disc and don't play all CD's, so maybe yours fall under this category.
How long have you been using your laptop and has it ever played Cd/Vcd's before?
If it plays them before, then it means your drive's lens is weak, but if it has never played them before, then it means that's how the player was made.
Which ever way, you still have an option of replacing the drive if you wish.
Take care.
Apr 14, 2010 | HP Compaq nx6115 Notebook
CD-R/DVD Drive with "missing or corrupted driver"
You might be best off to take your computer back in time.
Start > Help and Support > Undo changes made to my computer > Restore my computer to an earlier time > Pick a date at which time the cd was working properly. This will fix the driver problem..
Please let me know if this works for you, or if you have problems doing it.
Mar 16, 2009 | IBM ThinkPad R51 Notebook
Thinkpad R51 CD/DVD Driver missing
Download "DRIVER MAX" it will automaticlly find devices, and find the drivers for them, then you choose what to update. And best of all it's free.
Feb 24, 2009 | IBM ThinkPad R51 Notebook
CD-RW DVD Rom cannot read any disc
clean the lens of the drive and try. else it is a hardware problem. reach a computer service shop for hardware fault
Dec 29, 2008 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
Sep 13, 2007 | IBM ThinkPad DVD_ROM Ultrabay (73p3270)...
IBM ThinkPad DVD_ROM Ultrabay (73p3270) Internal DVD Drive Logo
213 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
