Question about ASUS P5VD2-MX SE Motherboard
My ASUS P5VD2-VM SE have power but the PC wont boot, the fan is not spinning but the green light that indicates that it have power is on.. i check everything including the CPU compound but nothing happens... WHAT SHOULD I DO? Living in a country like Philippines, buying a new motherboard is very expensive.. PLZ help me.. i would consider it as a greatest debt to you.. THANKS..
Nic61
  • 1073 Answers
SOURCE: no audio driver of P5VD2-VM motherboard
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5VD2-VM%20SE
I can not provide you with the drivers, but i can provide you with a link so you can download them yourself.
Good luck
Posted on Dec 11, 2008
Wraiith303
  • 39 Answers
SOURCE: ASUS P5VD2-VM SE support for intel core 2 Duo E8400
Doesn't boot correctly?
If the CPU isn't supported, in my experience, the pc doesn't boot at all. If this is the case, you will have to buy a new MB to support your CPU. Sorry.
Posted on Jan 07, 2009
sodeep
  • 3267 Answers
SOURCE: Asus P5VD2-VM SE don't detect sata hdd
What processor are u using & which OS have u installed? Try using WinXP_ServicePack-3.........sodeep
Posted on Mar 20, 2009
SOURCE: P5VD2-VM SE Video Controller
we want to video driver
Posted on Mar 28, 2009
wayneard
  • 1901 Answers
SOURCE: I have an Asus P5VD2-VM SE motherBoard But Cant
The Front Panel connector is in the lower right corner if you view the MB with the CPU at the top. There are 4 pins on top of the connector and 5 on the bottom. It should be labeled F_PANEL. The connections are:
(PWRLED)
Top Row first: Power LED +
Top Row second: Power LED -
(PWRBTN)
Top Row third: Power Button
Top Row fourth: Power Button Gnd.
(HDLED)
Bottom Row first: HD LED +
Bottom Row second: HD LED -
(RESET)
Bottom Row third: Reset Gnd.
Bottom Row fourth: Reset
Bottom Row fifth: No Connection
The pdf manual will not allow me to copy and paste info so I will lead you to the manual so you will have it to help solve this problem and perhaps future ones.
Go to this site:
In the upper left it has a search box that says "Input Model to Search".
Type in your model number. Click on Search Info.
A verification page will come up. Click on the model number link. You will then get a small window to select your operating system. Do so. Click Search.
You will get a list of available downloads with Manual at the bottom. Click the little + next to Manual. Scroll down to the appropriate language manual. (I assume English. It is the next to last one listed.)
Click on Global (DLM) or Global or China. A download window will open. Select SAVE. Choose the folder to save it to. (My Documents will do.)
When the download is complete click OPEN FOLDER on the download window. The file should be highlighted. Double click on the file to extract the pdf file from the zip file. Once opened, SAVE it as the pdf file where you will be able to reference it in the future.
The front panel connector pinout is on page 1-35.
If you have problems, use the Comment button to reply.
Thanks for using Fixya.
Posted on Aug 25, 2009
Testimonial: "Thanks , Helped Alot Sorry for Late Answer."
I have ASUS P5VD2-VM SE - Motherboard when i turn off power supply and start my pc again, it display a messege always "Cmos Checksam bad date and time not set" I replaced old cmos battery with...
Oh, you need to go into your BIOS, for that Motherboard, you should press alt+f2 while it boots up and that should load you into BIOS (or it might be called Setup). Once you're in there you need to change your Date and Time to the current date and time. Hope that helps!
Dec 14, 2010 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Motherboard asus P5VD2 SE S NO 87MOAD273471 VIDEO DRIVER
Select your operating system. Right click the (+) sign beside VGA to expand the available video drivers: (take care to download correct file)
ASUS P5VD2-VM SE Downloads
Mar 07, 2010 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Mar 20, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Lost driver
U can download the driver from these sites
http://www.driversbay.com/drivers/bios-motherboards/asus/p5vd2-vm-se/microsoft-windows-2000/
http://drivers.softpedia.com/get/BIOS/Asus/ASUS-P5VD2-VM-SE-BIOS-0302.shtml
Feb 04, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Jan 07, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Audio driver
hello, you can downlaod the driver in this links below.
http;//www.driver-pro.com/asus
http://drivers.softpedia.com/get/BIOS/Asus/Asus-P5VD2-VM-SE-BIOS-0221.shtml
Dec 18, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Replacing Asus CUV4x Motherboard with Asus p5vd2-vm-se motherboard? I have my old computer that i want to replace with new set of motherboard. My old computer has the following specification: Asus CUV4x...
Hi eibral2345, sorry but there is no chance the motherboard, Asus P5VD2-VM-SE will run the Samsung memory. It’s the old style 3.3V PC133/100 SDRAM. The new Asus motherboard,
P5VD2-VM-SE uses Single-Channel DDR2 - 667MNz or 533MHz memory. Here is a link to the specs of the Asus CUV4X: http://www.pcstats.com/articleview.cfm?articleid=314&page=3
Here are the specs for the Asus P5VD2-VM-SE MB: http://www.asus.com/products.aspx?modelmenu=2&model=1787&l1=3&l2=11&l3=369&l4=0
Will the new Asus board fit in your case? It should!
The larger measurement is the height of the board.
The Height + Width of the new board is smaller than the older board.
Have more questions?
Good luck eibral2345!
Mike
Sep 26, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
ASUS P5VD2-MX SE Motherboard Logo
219 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
