Question about Kenmore 20.6 cu. ft. Upright Freezer 24092
It sounds like the compresser or something clicks on for 2-3seconds then off and 20 seconds later it clicks on again on off on off
  • Michael Youngman
    Michael Youngman May 11, 2010
    What's the model and make of your unit? Smaller units usually don't have high or low pressure controls, so knowing what you have would be good info for me to look at your schematic.
  • 523 Answers
Over load and relay is bad try a new one if that dont work go to parts store and get a 3 in 1
Posted on May 11, 2010
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Jan 15, 2013 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Door was left ajar and it wiil not freeze
sounds like the freezer probably over worked the compresser pull fridge bottom cover off and look for frost or the condenser fins might be on back if you see frost on either one you need to turn it off and let the frost melt then start it up again
Nov 07, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
This unit was purchased new 61 months ago. First instance of any problems, ever, today it seems food isn't being kept frozen solid. We suspect the compressor is having a problem. There was no sound...
Yes it is a very big concern.It sounds to me like your condenser is dirty and the compressor gets hot and goes off on overload.You can tell by putting your hand NEAR the compressor.Be careful as the compressor can be very hot
Sep 14, 2010 | Frigidaire Freezers
TEMP ON FREEZER IS NOT COLD ENOUGH WHEN SET TO -23 KEEPS RETURNING TO -9. there are three buttons on the top of the fridge, one with a speaker sign, one saying SUPER and the third with the degree sign....
Sounds like you need to do a 12 hour defrost. If the evaporator is caked with ice, the thermistor(temp.probe.) will also be covered. the true temp wont be read in this state. Defrost and then retry. Take note of temp for a period of time. See if it ever goes to -20 as selected. If so then at a later date it goes off again, there is then a defrost issue. Suspect the door was left open accidentally.
Jun 04, 2010 | Freezers
Have a small Kenmore freezer (31" high x 24" deep by 21" wide). It works fine as far as freezing, but it never cycles off. Just keeps on going and going, driving me crazy. I also continually hear a subdued...
the wooshing maybe the oil/freon migrating thru out the internal system...
The cycle depends on 2 things... t'stat operation and timer. The timer usually shuts off freezer every 6 or 8 hrs for 20 to 30 mins. But the t'stat (once it reaches desired temp. should shut off freezer every 15- 20 mins. for an average 10 -15. So 15 mins off min 15 mins on (that is if the doors is not open) you get my point something like that...
but the way you describe to me it sounds like the t'stat. set it at 1 if it dont shut off and you are absoultely sure you got zero degrees (use a temp. reader) then replace the t'stat
hope this was helpful
let me know if this didnt work then plan B
Mar 09, 2010 | Freezers
Compressor click
Possibly. However it sounds like the compressor is running hot which could be the relay assembly sticking with the start windings in the circuit.
Eric
Jan 24, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore Upright Freezer Works Sometime
try a new start relay and overload kit specifically for the make and model freezer you are working on. if compressor can be seen ,the numbers on it can be used to get correct oem start cap, relay ,and overload. if your unit is having starting problems that will usually fix it. if however, the stat is failing to bring it on a new stat is called for. but it sounds like it is having starting problems since you said it was off a long while then still struggled on the overload to start then finally did. if the new start components don't work then new freezer time. compressor replacement is to expensive anymore. good luck
Oct 27, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Kenmore 20.6 cu. ft. Upright Freezer 24092 Logo
87 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
