Question about ASUS P5L-MX Motherboard
Cpu high temperature, cpu shutting down - ASUS P5L-MX Motherboard
  • ASUS Master
  • 32,281 Answers
The CPU is shutting down because it is overheating (ie thermal shutdown) and won't boot up again until it has cooled down. If this problem is not fixed, eventually the CPU will fail completely.
Check the CPU fan to see if it spins freely. Also check the power supply fan to see if it spins freely. If the CPU fan has failed, then replace the CPU fan. The CPU fan and heat-sink assembly may be clogged with dust, if so loosen the dust and vacuum to remove the dust.
Posted on May 11, 2010
3 Suggested Answers
colliewob
  • 778 Answers
SOURCE: cpu high temperature problem
Overheating problem
Remove case side and clean all fans
remove fan from heat sink usually 4 screws or little clips
Do NOT remove heatsink stuck on with heat paste
clean vanes in heat sink replace fan
use stiff brush and vacuum cleaner to clean outside of power supply
vacuum out case include all vent holes
reboot computer should work ok
replace case side
Posted on Dec 01, 2008
bronk50
  • 27725 Answers
SOURCE: shut down automatically while playing
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no?MOISTURE in the air line dust causes static to build up in a computer causing it to overheat any many other problems
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the shutting down
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Posted on May 21, 2011
Computer idles high then shuts down
When you say "idles high" do you mean you hear fans spinning faster or louder? If so, a fan spinning at higher than normal speeds is indicative of components/chips being run aggressively causing them to run at much higher temperatures. You may want to look into getting temperature monitoring software like CPU-Z to monitor the temperatures of your CPU and GPU. These components are the most common ones to be running at high temperatures. If any fan has failed on them the secondary fans (if there is one) will run at much higher speeds to compensate. Your PC may have a safety precaution to automatically shut down if certain temperatures are reached to prevent permanent damage to the components. Are you getting any blue screens before it shuts down?
Oct 16, 2013 | E-Machines eMachines Desktop PC
TOO HIGH TEMPERATURES AT MY LAPTOP ACER ASPIRE 5735Z
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Aug 01, 2012 | Acer Aspire Computers & Internet
Sometimes when I start my laptop (usually when my USB broadband device is connected), the screen will start flickering and the laptop will make a whining noise for about a minute or so before shutting...
Indeed your problem seems to be a temperature problem, especially if this happens after a working period and the laptop gets hot. Let's start with the easy solution:
Shut down your laptop and remove the battery. Use a soft brush (and if possible air under pressure) to clean up pedantically the air blinds all around the laptop. In case of using air under pressure leave the laptop to "rest" (and the temperatures and humidity to balance) for about 15 minutes. Check for your problem again after this.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Oct 05, 2011 | HP Compaq Evo n610c Notebook
A reason the high temperature cpu mercury
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Jul 11, 2011 | Mercury P4VM800M7 Motherboard
I have an e-machine T2792. It boots up fine then runs for 10 to 20 min. then shuts down. Could this be my cpu going bad? Thank You Scott
CPU, the motherboard and the rest of the chips in it is subject to wear and tear. This is in addition to the high temperature it is operating with. The sudden shut down is cause by a failure of one component (usually the Processor) who's burned out.
Sep 12, 2010 | E-Machines eMachines Desktop PC
Laptop shut downon its own
Your fan has failed! Your cooler not working properly, clean your cpu-fan. Your CPU is over-loading temperature is too high without an working fan! This is your Problem!
Sep 03, 2009 | Lenovo 3000 C200 Notebook
Computer keeps shutting down.
Do the fan's spin when you power the PC on? All of the fans should spin up for at least a second upon initial boot. The CPU fan and video fan (if you have an external card) will spin the entire time the PC is on and vary in speed depending on temperature.
Try booting the PC with the side of the case off and note and fans that aren't spinning. The temperature to shut off the CPU is really high. If the temperature is getting hot enough to do this, you should notice a failure in a fan right away.
Mar 09, 2009 | Computers & Internet
Cpu high temperature problem
Overheating problem
replace case side
Nov 29, 2008 | ASUS P5PE-VM Motherboard
High temperature CPU!
NEVER not use your laptop on a flat surface. Buy something to prop it up with. Then get a small fan and sit it by the laptop. This should help. This laptop breathes from the bottom.
May 30, 2008 | Acer Aspire 3000 Notebook
Shut down problem
if it gives you 60 secs warning , abort the shutdown by ---- shutdown /a---- command....and check for any servivice termination from administrative tools > services... check if all the automatic strted services are running
Jan 26, 2008 | Microsoft Windows Server Standard 2003 for...
ASUS P5L-MX Motherboard Logo
627 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
