Question about Canon LASER SHOT LBP 3300 Printer
Load custom paper in manual feed slot
The printer would not print the document. the dialogue box shows "out of paper: load custom paper in manual feed slot", even though the printer is full of paper.
SOURCE: Printer will not print
I had the same problem and to fix it there was a blue tray I had to pull out (the tray for the photopaper). Once it was pulled out so it was about flush with grey part beside it, the printer worked again. (The photopaper tray is just above where you put the regular paper.)
Posted on Mar 26, 2009
  • 58 Answers
SOURCE: hp p1006 wont load/feed paper
Mine does the same thing. The solution I have used on several occasions is to load it as full of paper as possible without forcing it under the guides. Lift the lid to reset the jam function, then when it begins to try to print, push the top one or two sheets of paper into the printer. If it will grab them and print then it will be ok for the whole stack of paper. Adding more paper before it gets too low also seems to help.
Posted on Jun 05, 2009
  • 2976 Answers
SOURCE: Paper won't feed into printer
Make sure the paper doesn't have a curve in it. Also, fan the pages to make sure they aren't sticking together. Load shiny side up. Try taking about 10 sheets out
Posted on Jun 29, 2009
  • 360 Answers
SOURCE: Samsung scx-4521F giving me document jam error
hello please check it properly.some time their have a small piece of paper.
or clean adf unit & service.
Posted on Sep 09, 2010
sabuv
  • 113 Answers
SOURCE: Canon LBP 3300 printer A4
these instructions r for win xp
go to printers and faxes select canon lbp3300, right click and select printing preferences set out put paper size as A4.
Posted on Apr 16, 2011
Testimonial: "thank you. it is very good."
Printing custom sizes on hp deskjet 3015
In MS Word, go to page setup then modify the paper size of the document.
Next, Press CTRL P to open the print dialog box, then select properties. Modify the paper size of the printer.
Hope this helps.
Apr 25, 2014 | HP LaserJet 3015 All-In-One Printer
Manual feed tray bypass
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Jul 25, 2012 | HP LaserJet 4250n Printer
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
What does it mean when your brother printer 8480 DN says load MP Tray?
That means that you have selected the manual feed tray in your computer as the destination. Either put a piece of paper in the pull-down slot or change the destination in your print dialogue box
May 13, 2011 | Office Equipment & Supplies
My Brother HL-5240 printer constantly has the paper light on even though there is paper loaded
You probably printed a document that was forced to the manual feed. Place some paper there and it should print. Go to your printer preferences and set the default tray to tray1 instead of Auto.
Jan 31, 2011 | Brother HL-5240 Laser Printer
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
Printer is saying manual feed insert paper. Will not print
To load paper or other media in the Manual Feed Slot (directly above the Paper Tray)
You can load envelopes and special print media one at a time into this slot. Use the manual feed slot to print or copy on labels, envelopes or thicker paper.
1. Slide the paper guides to fit the paper size.
2. Using both hands put one sheet of paper in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the machine feed the paper in a short distance.
Note: When you put paper in the manual feed slot, please remember the following:
■ The side to be printed on must be face up.
■ Put the leading edge (top of the paper) in first and push it gently into the slot.
■ Make sure that the paper is straight and in the proper position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
■ Do not put more than one sheet or envelope in the manual feed slot at a time or you may cause the machine to jam.
■ You can remove smaller sizes of printed paper from the output paper tray more easily if you lift the scanner cover using both hands as shown in the illustration.
You can still use the machine when the scanner cover is raised. You can return the scanner cover to its home position by pushing it down with both hands.
If you would like to disable Manual Feed Mode, check that the manual feed mode is not selected in the printer driver.
Here is a copy of the User's Manual for the Brother MFC-7820N.
Jul 07, 2010 | Brother MFC-7820N Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
Epson Stylus Pro 7600 - Oversize Printing
Select the proper page size in the page setup dialogue box and again in the various print dialogue box sub menus. Also make sure your printer is selected and you are using the correct drivers.
If all of these things are in place you should get a long list of paper types in the pull down menu when you attempt to print.
May 11, 2009 | Epson Stylus Pro 7600 InkJet Printer
Canon LASER SHOT LBP 3300 Printer Logo
623 people viewed this question
old marine
old marine
