Question about HP Deskjet F340 All-In-One InkJet Printer
It says offline, then i go into control pannel and to my printers and click on use online it still says offline; online. what do i do? nothing works. i googled everyway i could describe it. it just basically says offline; online. but how do i get rid of the first offline?
    Sergeant:
  • 279 Answers
I would try at this point: powering it off, deleting it from your printer list, then uninstall it, and then restart your computer. When your computer is back up and running again, just turn on the printer and see if it installs from windows automatically. If it does not install, then do you have a disk to install it from?
Regardless of if you DO or DO NOT have a disk then try this (printer should be ON):
Enter "device manager" in your Windows search area
Then look for your printer under imaging devices or printers, depending on your Windows version, (click
on the "+" to open)
Then right click on your printer
select properties
In the new window that opens up (GENERAL should be the tab it opens up to), does it say "this device is working properly"?
Click on the second tab DRIVER
Then click on UPDATE DRIVER
save changes
You might need to restart.
Hope this helps.
Posted on May 11, 2010
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
How do i get my samsung ml-2510 printer back online? it is offline for some reason - was working in the past. tx!
Follow the step:
  • Access "Control Panel"
  • Access "Printers and Faxes"
  • Right Click your Printer
  • Select "Use Printer Online"
Mar 01, 2011 | Samsung ML-2510 Laser Printer
Printer says it is offline
Click on start then control pannel and go to printer and faxes right click on it select propertise and check for option to make printer online .
it will be resolved
Sep 05, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer Offline Message
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Get more information to fix printer offline error :
http://printers.iyogi.com/errors/printer-offline-message.html
Hope this information helps you.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Printer stoped printing says offline
follow following steps
1) check if your prnter is getting power properly
2) if you are using network printer(printer at some other computer) check if computer with which printer is attached is working fine.
3) if all above things are fine power off printer and power it on.
4) right click on printer in control pannel printer, you will see online click on online and it will be done.
if you find any issue let me know
Sep 30, 2009 | HP Photosmart C7280 Laser Printer
Printer offline
OPEN UP YOUR WEB BROWSER AND CLICK ON "FILE". SEE IF THERE IS A CHECKMARK NEXT TO "WORK OFFLINE".....IF SO, JUST CLICK ON IT AGAIN TO MAKE THE CHECK MARK DISAPPEAR AND BE ABLE TO WORK ONLINE AGAIN..........OR YOU CAN GO INTO THE START MENU, OPEN CONTROL PANEL, GO TO PRINTERS AND FAXES, FIND UR PRINTER,,,,RIGHT CLICK ON IT AND SEE IF PRINTER IS ONLINE OR OFFLINE..
Sep 22, 2009 | Office Equipment & Supplies
HP deskjet D2300 series printer is showing offline .Power is already given to the printer.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
My printer says it is offline and will not print
check the settings for printer in control pannel and set it to default and edit the status as online
May 08, 2009 | Office Equipment & Supplies
I have a HP Officejet 6300 and it is showing as Offline
go to control panel, then printers and faxes, then right click on it and click "use printer online"
hope this helps!
Jan 25, 2009 | HP DeskJet F380 All-In-One Printer
Printer Offline
here are the steps to do:
- click start icon
- goto control panel
- under control panel click printers folder
- then under printers folder there is an icon for photosmart c6100 printer - right click that icon then set as a default printer
- then right click the icon again and select use printer online
- after that you can see you printer has a checkmark and the status is ready.
Jul 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Deskjet F340 All-In-One InkJet Printer Logo
146 people viewed this question
Seeker5211
Seeker5211
